BMW M2 Forum > Regional Forums > USA - NY/NJ/PA/CT > Feeler: Swap my Vorsteiner FF-103 for your wheels...
      07-22-2017, 10:57 PM   #1
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
I have a set of Vorsteiner FF 103's perfect and aggressive fitment for M2, M3, M4. 3 Are currently getting redone by a great wheel shop and 1 is being replaced. The wheels have less than 3000k miles on them and will be better than new. They are wrapped in Nitto NT05's with under 1000 miles...(Colored lines still showing on front.
I Love the wheels and get tons of compliments. but tbh it seems so does everyone else and now a year afterbuyimg the wheels they seem to be the most popular wheels on F Series F Cars
Specs are as follows:
Front 19"x 9.5 et 22 (shipping weight 17.5 lbs)
Rear 19" x 10.5" et 34 (shipping weight 20.xlbs)
To do the math between the wheels being .5" wider than stock (6.25" wider wheel base all around, than the offset is 8mm wider front 6mm wider rear, which brings the wheel each 14,x wider front and 14mm wider rear each side , totalling 28mm+ wider wheelbase both front and back add to that 15mm spacers all around +30mm ftont/rear brings you to about 58mm wider both wheelbase front and rear. Add that to the wide stance and soft rubber of the Nittos and the lighter unsprung weight of the the flow formed wheels...The wheels look great, dont rub at all on H & R Springs, greatly improve handling, and Im sure have a minor increase in accel with the lighter wheels...
Tires are 245/35/19 and 275/35/19
Id like to change up the look...depending on what you have we can trade wheels and not tires or wheels +/- cash...
These wheels are about $2200/set
Any interest...Im open minded...
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
