BMW M2 Forum > Pricing / Ordering / European Delivery / PCD > Week 37
      10-20-2017, 08:52 PM   #375
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
Originally Posted by jjclyde View Post
I feel a Thursday afternoon delivery comin' on!
My car arrived at the dealer before dawn on Thursday. If yours does the same - and you've requested your CA to get on it - seems like a Thursday afternoon delivery is do-able.
I hope so...
BTW - I could see when my car was delivered via the UnitedRoad website. If your car is released to UnitedRoad (not the only trucking company BMW uses), you can see it there. Click on Delivery Receipt, enter last 8 of VIN (that's right last 8, not last 7).
When were you able to search your car? Did it leave the port on Monday, or since your dealer is fairly close, most likely it left Wednesday I'd have thought...
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
      10-20-2017, 10:27 PM   #376
jjclyde
Drives: 2021 M2C HS 6MT
Originally Posted by Nezil View Post
I hope so...
Your dealer is closer, no? Mine was in Orange County.
Entered VPC 10/2 (Monday) (Info from Genius)
Exit VPC, released to trucking 10/4 (Wednesday) (Info from Genius)
Saw on UnitedRoad website 10/5, morning (Thursday). Didn't think to check before then.
Arrived at dealer 10/5 3:35am. (according to UnitedRoad Delivery receipt - see my post in the wk33 thread)
Delivered 10/6 (Friday)
      10-20-2017, 10:29 PM   #377
importriders
Just checked, and you're right! Customs release for my car is already done.
I'm in Southern CA for business Wednesday and Thursday next week, so I'm really hoping I can pick up on Thursday afternoon or Friday morning. I have to be back home by 5pm on Friday, and it's a reasonably long drive from Southern CA to Northern CA. Need to be on the road by 11am Friday ideally.
If not, I'll just have to make a separate trip down.
I had a 3 day port to dealer time. Morning Courier docked on Friday and I took delivery Monday in LA, car was in my garage that same night. If its anything like how mine went you’ll be picking up well before Thursday.
You can save a day depending on what you want your dealer to do. I wanted shipping plastics left on per the advice of my xPel/ceramic installer. He insisted that I tell the dealer to not run the car through the wash as it will only add swirl marks.
      10-21-2017, 11:07 PM   #378
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Picked it up today... spent more time getting the deal done and then showing the car to my dad than actually taking pics of it.
Walked into the dealership to this:
Then revealed... hope it wasn't nasty / dirty on the inside of that blanket.
Already did a mod though... Parking sensor disable button
S1monQc223.50
      10-22-2017, 02:15 AM   #379
hoyasaxa
Drives: GTI | 982 4.0
Looks great! I am super into that mod, although not to turn off the sensor. The LCI turns off almost immediately. But I'd like to be able to see what's behind me sometimes without shifting into reverse.
How did the DIY go?
2014 228i (lease return) | 2018 ///M2 - ED Thread (sold) | 2023 Cayman GTS 4.0 (ordered)
      10-22-2017, 02:40 AM   #380
ZPrime
I INDIC8
ZPrime's Avatar
2018 BMW M2  [9.50]
How did the DIY go?
I'll have to double check it, but I'm pretty sure that you can't see the camera without reverse. The screen comes up and shows you the backup sensors, but no camera display. You can fiddle the knob to the camera icon on the screen, but it won't turn on. At least that is what I remember from playing with it after dinner tonight.
As far as DIY, took me around 30 minutes, but some of that was figuring out how to release the module, and then some more was figuring out how to safely pop off the switches and swap them (I put the OEM Sport/Comfort switch into the normal 2er module instead of living with "Sport / EcoPro"). Would be a lot quicker without that detail.
Pop up the shifter surround (pull at the corners, assuming 6MT). Didn't take a lot of force for me. Once it is up, get the stick out of the way, and reach around the front edge of the module - there's a tab, push it toward the back of the car and that should allow you to work it up and loose. Remove the plug (squeeze on two opposing sides) and you're free. If you don't care about the rocker switch label being wrong, reverse the procedure with the new module and you're done.
If you're going to swap the rocker switch, you'll want several small picks or awls, I suppose small flatheads would work; that's to release the plastic trim from around the face. The little silver accent will fall out after this. Work carefully on each tab and don't lift them too far. I went from the ESP edge of the module and worked my way down. Once it's off, I poked a straight pick into the visible hole in the rocker and pushed in while prying upward. That popped off just the one side a little bit, and I took the pick and poked across the gap to the other plastic eye that is under the switch, pushing it wider and off of the center support post, while trying to work it loose with my other hand. Popped off pretty easily. Be careful with picks so you don't trash the button edges too much, but the silver accent frame and plastic face trim will help hide stuff.
      10-22-2017, 03:13 AM   #381
dtmpower98
dtmpower98's Avatar
Drives: F80 M3, F87 M2
Thalatta on 10/22 at 1:10am PST!!!!
2013 MW E92 M3
2018 MG F87 M2 (Sold)
2016 YMB F80 M3 (Sold)
Follow me on Instagram- @dtmpower98
      10-22-2017, 03:56 PM   #382
seetohey
Drives: 2018 M2 LBB, 6MT. Future: CTR
2018 BMW M2  [0.00]
Thalatta is approaching Hueneme, about 20 miles away.
      10-22-2017, 06:33 PM   #383
hoyasaxa
      10-23-2017, 10:34 AM   #384
bobert
Drives: manual shift cars
My week 37 ED car will depart on Tombarra tomorrow; scheduled for unloading at NYC (Newark) on Nov 8.
2018 M2: BSM, Exec, 6MT (ED on 10/5/17, re-delivery on 11/30/17) My BSM M2 European Delivery Story
2013 335i M-Sport sedan: BSM, 403M wheels, walnut trim, 6MT (gone)
S1monQc223.50
      10-23-2017, 11:48 AM   #385
seetohey
2018 BMW M2  [0.00]
Nice! I can't tell from the pic, did you get Michelins?
      10-23-2017, 12:18 PM   #386
bobert
No, I got Contis
      10-23-2017, 03:35 PM   #387
bim2er
bim2er's Avatar
Drives: '18 Mineral Grey M2
Thalatta Departed Port Hueneme
Looks like the Thalatta departed Port Hueneme at 2:50 AM PDT on 10/23 for Seattle.
'74 2002tii, Sienna Braun Metallic, Manual, Sold; '84 e28 533i, Burgundrot Metallic, Manual, Sold; '95 e36 M3, Avus Blau Metallic, Manual, Sold; '06 e60 M5, Silver Grau Metallic, SMG, Sold; '09 e82 135i MSport, LeMans Blue, Manual, Sold
      10-23-2017, 03:57 PM   #388
Nezil
Nezil's Avatar
1404
That's correct, but I don't think BMW has a VPC in Seattle so all of the cars are already off...
As far as I know, BMW only has VPC in Halifax, Baltimore, Galveston and Port Hueneme.
      10-23-2017, 05:34 PM   #389
bobert
They must have one in NYC/Newark/Jersey City for ED cars...
      10-24-2017, 10:04 AM   #390
seetohey
2018 BMW M2  [0.00]
Anyone with a car unloaded at Hueneme get a delivery date from the dealer yet?
      10-24-2017, 10:23 AM   #391
Nezil
Nezil's Avatar
1404
My CA is still working to a Thursday afternoon / Friday morning delivery, but it's not really in his hands. It depends how long the VPC process takes. My dealer is pretty close to the port, but my concern actually is that there were 1,035 BMWs on the Thalatta... that's a huge number of cars to VPC.
      10-24-2017, 11:19 AM   #392
jjclyde
There were 1176 offloaded from Fedora with my car. And my car got to my dealer in the time frame you'd require for your Thursday afternoon/Friday morning delivery.
What does Genius have to say about VPC progress of your car? I'm betting you'll make it.
      10-24-2017, 04:58 PM   #393
Nezil
Nezil's Avatar
1404
I've been sick all day with something like food poisoning, but I did manage to call the Genius line. They said it's scheduled to finish VPC tomorrow, and ship Thursday. I'm not sure if they know how close the dealer is but they said delivery Friday.
If the dealer actually gets the car Friday, I may be out of luck, but your description of events would lead me to believe if it ships Thursday, it will arrive Thursday. And if it ships Thursday morning like yours did, a Thursday afternoon pickup should be possible.
      10-24-2017, 06:53 PM   #394
dtmpower98
dtmpower98's Avatar
Is yours going to Rusnak?
2013 MW E92 M3
      10-24-2017, 08:55 PM   #395
JB330Ci
Drives: M2 LCI
How did the DIY go?
Yes, the sensors and beeping are turned off right after you shift to neutral from reverse for 08 LCI M2s. No need for this mod then.
      10-25-2017, 12:42 PM   #396
jjclyde
If you haven't already, I suggest you check on UnitedRoad - if your car shows up there before mid-day Thursday you've got a chance of making it. Hope you feel better ... taking delivery might help.
