04-28-2017, 10:26 AM | #1 |
Rep 1,541
My PC build
My son and I put together a new build. Pic isn't that great, sorry. I'll have him take new pics with the SLR.
Corsair 740 case Asrock Fatality K6 6700k MSI 1080 Ti Armor OC Closed loop liquid cooling for CPU and GPU.
07-21-2017, 08:42 PM | #3 |
Rep 1,850
So this is an assembly of some off the shelf components the way they were meant to be put together. Let me grab a picture of the 30 piece sesame street puzzle I just finished, you guys are gonna be really impressed.
For real though PC builds should be banned from the internet unless they involve custom fabrication, liquid nitrogen or phase change, or they're just ludicrously expensive. |
07-22-2017, 10:36 AM | #4 | |
Rep 1,541
Sidewinderpb328.50 jkoral1016.00 |
07-27-2017, 03:11 PM | #5 |
Stand-up Philosopher
73
Rep 184
Anthony235715.00 |
07-27-2017, 08:16 PM | #6 |
Beefcake
3769
Rep 711
Looks great. My only suggestion would be to double check the orientation of the fans. The direction of the fans create a neutral pressure region inside the case. It's not a huge deal but it helps with keeping the inside of your case clean if you had a bit of positive pressure (More intake fans than exhaust).
07-28-2017, 10:56 AM | #7 | |
Rep 1,541
Still need to get a filter for the rear 140 intake fan.
07-29-2017, 08:41 PM | #8 |
Rep 42
Drives: '12 135i ///M-Sport
Should probably ban car builds that don't involve custom fabrication too by that logic.
Anthony235715.00 |
08-13-2017, 06:45 AM | #9 |
Rep 3
That's something sweet! how much did it cost you to build that rig?
Anthony235715.00 |
08-13-2017, 06:58 AM | #10 |
Rep 3,235
I'd be concerned about the effect the top and bottom fans have on proper cooling and air flow. I work extensively in the world of data centers. The servers, storage, networking, etc all have fans which pull air from one side and expels it out the opposite side. I've never seen fans on all four sides of any the equipment I have worked with. Even the densely packed equipment.
08-14-2017, 10:47 AM | #11 | |
Rep 1,541
MB, CPU, RAM was carried over from our old setup. Fans, cooling, case, video card were new. Video card was the most expensive single cost at $700. All the fans and cooling were probably close to the same price
08-14-2017, 10:50 AM | #12 |
Rep 1,930
Nice build.
I read people complaining about the low clock speeds on the MSI 1080ti versions. Should check it out on the msi forums. I'm happy with my MSI 1080 though. You're missing a NVME SSD which will complete this build. |
08-14-2017, 10:56 AM | #13 | |
Rep 1,541
Top and bottom fans are exhaust. Intake fans (front and rear) bring in cool air from the outside and cool the memory and MB components. The still, relatively, cool air is exhausted over the radiators to cool the video card and CPU. Also keep in mind that the PSU and drives are in a seperate sealed off section of the case behind the MB. This setup also helps create positive pressure and keeps the inside of the case pretty dust free. The CPU and video card generate the most heat so if coolers were set to intake then the hottest air in the equation would be circulated IN the case and then exhausted. I thought of it the same as a car intake system (intake, intercooler, turbo, exhaust ). That was our logic anyway. I'd really like to get a new MB with black/white accents now....
08-14-2017, 11:06 AM | #14 | |
Rep 1,541
I get 1950mhz out of the box. MSI says boost clock should get 1650mhz. The problem with the MSI 1080Ti Armor is the stock cooling is a joke. Before I did the liquid setup it would easily hit ~85-90* on stock clocks. Which then caused the card to automatically underclock itself, but even then it still ran hot. You can read all the reviews on newegg about this. Lots of us posted on the MSI forum about this too, but they locked the threads.... This was the catalyst of getting a new case and cooling setup
R3dliner934.50 |
08-14-2017, 12:45 PM | #15 | |
Rep 1,930
My gaming x 1080 does pretty well with a stock fan but you are making me think to go the liquid route. Are you running a Corsair cooler? |
08-14-2017, 01:05 PM | #16 | |
Rep 1,541
I quit looking into it once I went with the liquid cooling. I'm running the corsair 280 cooler for the CPU and a Thermaltake 240 for the GPU. The NZXT GPU adapter requires a round heatsink/pump and I couldn't source a corsair locally that would work since corsair has gone with the square heat sink/pump on their new models. If your stock fans provides adequate cooling (without being too loud) and you don't want to OC the card high then it's not worth it. My setup allows me to run 9 (PSU fan is the 9th) fans total with very low noise.
