02-23-2017, 02:00 PM | #1 |
Rep 176
When stopped and engine is warmed up...
When you are stopped/ in neutral and the engine is completely warmed up, can you "feel" the engine running somehow inside the cabin? I don't mean engine noise but global car vibration.
I can clearly feel the engine is on through footwell and seat slight vibrations, and it seems there is like a one second cycle when it vibrates slightly more. Would like to know if you feel the same before going to the dealer. Really don't know if it is normal or not. I thought this engine was super smooth and would be almost impossible to feel it when idling. Someone on this forum already said it could be the oil hoses but after going around the car "feeling" it, it doesn't seem to be the culprit. Car is still breaking in (300 miles). Regards |
02-23-2017, 02:14 PM | #2 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Well, you have an ICE with reciprocating mass. What do you expect?
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-23-2017, 02:17 PM | #3 | |
Rep 2,948
Also keep in mind the M2 has much less sound proofing material compared to regular cars. |
02-23-2017, 02:20 PM | #4 |
Rep 176
02-23-2017, 02:28 PM | #5 |
484
Rep 821
I like my performance cars to burp, crack, rumble and shake. It's all part of the fun.
02-23-2017, 02:32 PM | #6 |
Rep 176
Not complaining...
When accelerating I find the engine a masterpiece. Many months ago I had an M2 for testing for 3 days, and also a M135i and dont recall this idle vibration. Just wanted to check if it is normal or not. |
02-23-2017, 04:38 PM | #7 |
Rep 787
it is really hard to say whether what you are experiencing is normal or not. It could be the normal vibration you get from "exploding dinosaurs" (as gmzanatta puts it). Or it could be you are feeling something more than normal. Can't tell unless you compare back to back with someone else's M2.
Lp01109.00 |
02-23-2017, 04:47 PM | #8 |
Rep 39
I have to admit that the mild vibration - at idle - from the M2's (6MT) shift knob and pedals caught me off-guard at first. My 2004 4-cylinder Acura TSX, even at 12 years and 130,000 miles, had less vibration at idle. I expected the M2 would be smoother.
But now that the initial surprise has worn off, I couldn't care less. This car is amazing the way it drives, sounds and revs. |
02-23-2017, 04:53 PM | #9 |
Rep 1,718
02-23-2017, 05:53 PM | #10 | |
this is the way
18120
Rep 8,513
Lp01109.00 |
02-24-2017, 02:33 PM | #12 |
Rep 123
True. This car sounds way more "mechanical" than my m235. The first month I was worried about every little noise.
02-24-2017, 03:11 PM | #14 |
Rep 176
02-24-2017, 04:07 PM | #16 |
this is the way
18120
Rep 8,513
Exactly, and I'll bet you can feel it in the steering wheel and armrest. As the hose warms up it moves, sometimes perfectly against the chassis. Other times it may be slightly on the chassis. That's why the vibration varies so much. What you are feeling is the oil or coolant flowing thought the hose, think of the water lines on a washing machine. They move a lot as water is turned on and off, now imagine what's going on as hot oil or coolant is being pumped through the hose. I'm not saying this is 100% conclusive the issue you have, but I'd be willing to bet on it.
03-02-2017, 04:56 PM | #18 |
Rep 176
Today realized that the vibration is sunstantially reduced when I change to sport or sport+ (always in neutral).
Could it be some kind of exhaust ressonance that is reduced when flaps are open? Spoke today with the dealer and agreed that they will analyze the thing upon 2000 km service (I spoke about the possibility of being caused by loosen pipes but meanwhile I found this about sport mode making the vinration almost disappear) Regards |
03-03-2017, 08:51 AM | #19 |
484
Rep 821
Hehe. Flaps.
03-03-2017, 09:05 AM | #20 | |
Rep 787
03-03-2017, 09:33 AM | #21 | |
Meh
926
Rep 781
Drives: M3CS & Cayman S
as for feeling engine vibration - it's to be expected in a sports car. I'm sure the motor mounts are a little stiffer than average to prevent excessive drive line flex under load and cornering. however the m2 engine is pretty smooth, so it wouldn't hurt to mention what you're feeling at your break in service |
09-09-2023, 02:02 AM | #22 |
Rep 204
