02-23-2017, 09:40 AM | #1 |
Rep 1,660
Frontal collision enabled
I have this enabled using the "early" setting. According to the manual a warning and possible auto-braking may be initiated in the event of a detection.
The issue is that no audible warning, haptic feedbacj or actual brake application is happening. All I get is the RED CAR symbol. This is not worth much unless you happen to be looking down at the instrument cluster. Perhaps I do not understand how it's supposed to work. |
02-23-2017, 09:50 AM | #2 | |
Rep 429
M3 Adjuster7905.50 AlexCirci496.50 |
02-23-2017, 10:17 AM | #3 | |
7906
Rep 11,785
Personally I would recommend you switch to medium or late. But whatever setting you have it on.. it will work and it can and will hit the brakes if warranted. I'm not sure any of these systems are 100 percent reliable .. |
02-23-2017, 10:30 AM | #5 |
Rep 2,948
I have mine set on late, early and medium are too sensitive for narrow streets around my town.
The system does work though - the red car is a warning that it is triggered but not active. If it has to auto-brake, it will beep, scream, shout and shake, and trust me, you'll know it's doing it. |
M3 Adjuster7905.50 |
02-23-2017, 12:38 PM | #7 | |
Rep 656
I have only seen the red flash twice and one was at a stop light transitioning to a green so I rolled up on a accelerating car and saw it |
02-23-2017, 01:10 PM | #8 | |
Rep 2,948
I think it's just misreading the incoming car as a wide car in front of me, so as we approach with what the sensor deems a high speed (remember, add the two speeds when traveling in opposite directions) it triggers the system. Set to late I've had no issues at all. |
02-23-2017, 01:17 PM | #9 |
Rep 1,418
02-23-2017, 01:30 PM | #10 | |
Space Force - 4 Star General
11463
Rep 3,264
Mine was set to early from the start and it auto braked on me once. That was all it took for me to switch it over to late. |
02-23-2017, 02:09 PM | #11 |
Dinosaur supervisor
3030
Rep 4,214
02-23-2017, 02:27 PM | #12 |
Rep 1,418
I do! I'm not one of those jackasses that tailgates everyone. But I do like to drive fast when it is safe and I think the car is calculating my rate of speed and distance to the car in front (vs simply calculating just the distance to the car in front of you )and that triggers The alert. Even though I have it set to late I do feel it comes on too early sometimes so I think that has something to do with your speed and a safe braking distance? Some sort of formula.
MdMcoupe39.50 |
02-23-2017, 03:31 PM | #15 | |
11463
Rep 3,264
02-23-2017, 03:47 PM | #16 |
Rep 3,888
I doubt it knows the difference between them braking and you accelerating and why should it? Should be a simple matter of determining the closing distance.
02-23-2017, 04:31 PM | #17 |
11463
Rep 3,264
Conceptually, I agree with you. However, it seems that a car with brake lights on in front of me will trigger the system where as a car in front at the same distance without brake lights will not. It could be that the system is perceiving the deceleration of the car in front better than I can and is reacting to that where I'm reacting to the brake lights. Whatever the case, the technology is pretty cool. I'd love to see the code behind it!
02-23-2017, 04:50 PM | #18 |
Rep 13,097
Spiral down narrow parking floors after taking delivery of the car: the sensor fears that you're gonna crash into the curb of the parking wall: beep-beedee-beep + brakes automatically slammed + swear words go through your mind.
Get onto the highway from a highway entry, accelerate to get up to speed of the flow and cross lanes behind cars, heading towards the first lane: beep-beedee-beep + brakes automatically slammed + swear words go through your mind + a few faces inside cars nearby likely thinking "erratically throwing out the anchor: you mad, bro' ?". Been there, done that + changed the default setting "Early" to "Late". Nannies are less intrusive now.
///M is art ↔ Artemis
02-23-2017, 06:43 PM | #19 | |
Rep 1,418
It's a great system for sure but yes, definitely needs to be set to 'late'. Set to 'early' if you just pulled an all-nighter perhaps...and I don't mean binging! |
02-24-2017, 08:03 PM | #20 |
11463
Rep 3,264
OK, I can also report that 100% without a doubt, frontal collision avoidance braking and warning are disabled at low speeds. I tested this by getting a little over zealous pulling into the garage and hit my toolbox. Dont worry, no tools or M cars were hurt in the test...
M3 Adjuster7905.50 MFan_Ken31.50 |
02-24-2017, 11:59 PM | #21 |
Rep 396
Interesting. My Volvo is the opposite. "City safe" auto braking is designed to avoid low speed nose to tail collisions such as when queuing for an intersection and you are watching the cross traffic. The guy in front goes then changes his mind. This system is deactivated at higher speeds.
I've tested it by mistake by trying to sneak into my garage while the door is still going up. Camera still sees the door while the nose tries the sneak in underneath. The car objects to this and a violent automatic stop results. |
02-25-2017, 08:23 AM | #22 | |
7906
Rep 11,785
I pull into my garage all the time like this. Lol. Very happy I don't have this nanny... clearly it seems to be a mandate in the us. Every manufacturer is advertising it like it's brand new tech that is exclusive to their vehicle! |
