02-18-2017, 07:17 AM | #1 |
Rep 1,418
Increased Battery Discharge
Did some searching, found some explanations but what I don't understand is why my battery tender was not enough to solve my problem.
I don't DD my car and I don't drive in winter however, since I miss the car so much, I've taken her for a spin here and there when weather permits-albeit short drives. Because I decided I would do this this winter, I made the mistake of not connecting a battery tender thinking I didn't need to. As a result battery died on me the other day. So I connected my battery tender and left it for a full day. Next day it read that the battery was 100%. However, I go to start it and I get these two messages one after the other! I don't get it....do I just have a s**t charger, a heavy paperweight (battery)or is just a good long drive in order? |
02-18-2017, 08:29 AM | #2 |
Rep 1,133
Don't know, but the battery is quite large 900CCA, so it should take awhile to go down, but it should be under warranty so I would bring it in and see what is going on.
However, if you can start it, check the running voltage and see if its 14 volts or so. Now it will depend on how far down the battery is, but it should come up to near that voltage I think. I will say that the charging system on these cars is very different than any other car I have owned. If you get a new battery is needs to be programed into the car as a new battery or it will not get charged properly. Let us know what you find out its important information especially for those who don't drive in the winter. |
02-18-2017, 08:40 AM | #3 |
Rep 1,418
Will do. I had my last car for about 5 yrs. same routine. No winter driving except for the odd opportunity during winter...no tender...no problem! The problems I'm experiencing now with only 2000+ km are the same problems I only encountered in my 4th year with the previous car. Granted I'm sure there is more 'phantom ' electrical draw with the m2 vs my 2009 but geez...:
02-18-2017, 08:54 AM | #4 | |
Rep 1,133
Batteries that sit for long periods can sulfate which can/will damage them, so it's important to not let that happen. Add in all the parasitic draw and sitting for a month or more and it might be bad for these batteries, but I am interested in what you find out, again thanks for posting this..... |
tutankhamon163.50 |
02-18-2017, 09:35 AM | #5 |
Rep 2,505
Take it to the dealer. My 2011 M3 sat for a month or even two months at a time with no problems. I never used a battery tender.
M3 Adjuster7905.50 |
02-18-2017, 01:25 PM | #6 |
Rep 418
[QUOTE=Dabozo;21293647]
As a result battery died on me the other day. How long did you let it sit between drives? If I can't get a drive in on a weekly basis I back the car out of the garage and let it run for half an hour. Hopefully I am keeping the battery charged this way. |
02-18-2017, 05:34 PM | #7 | |
Rep 1,418
[QUOTE=Destroya;21294903]
I did some voltage testing - keep in mind I had the tender hooked up prior. Therefore the resting voltage was 13.39v and the running voltage was 14.88v. Shut down after a bit and got the same warning and car shut down all accessory power. Came back 2 hours later and resting voltage was 12.71. Went for a nice drive, returned, shut ignition off and no warning this time. Checked voltage and it was 13.78v. So perhaps a long..ish drive was all that was necessary. I've left the battery tender unplugged tonight. Will check voltage in am to see if battery kept most of its charge. |
02-18-2017, 06:39 PM | #8 |
this is the way
18139
Rep 8,518
You can view the system voltage via the hidden menu. Look on YouTube for videos on how to get into the hidden menu.
With the engine off and no lights on go to the system voltage display in the hidden menu. The voltage should be around 12.4~12.6v, if it's slightly below the battery is not fully charged. Once you start the car it should display 14.5~15v. Not all battery chargers are great, a lot of them are terrible and can indicate the battery is fully charged when it is not. Some chargers also go bad so I would not rely entirely on that. To really figure out what's going on you'll need a multimeter that has the min/max function and understand how to use it. Otherwise just take it to the dealer. |
Dabozo624.50 |
02-18-2017, 09:02 PM | #10 |
Rep 203
I had a 135i before my M2. I took a 3 week vacation once while I had it. When I came back and started my car the settings had been reset. The car still started and was OK, but I guess it went into some low power mode. It was a bit odd.
02-19-2017, 08:24 AM | #11 | |
Rep 1,133
[QUOTE=Dabozo;21295816]
02-19-2017, 08:29 AM | #12 | |
Rep 1,133
02-19-2017, 09:15 AM | #13 | ||
Rep 1,418
[QUOTE=Zippster;21297736]
02-19-2017, 09:28 AM | #14 |
youtube.com/rodoabadtv
155
Rep 248
Drives: 2017 Dinan M2, 2023 X3MC
My M2's been in my garage this whole winter. I usually start it once every two weeks before I clean the dust off and that usually last for like 15-30 seconds depending on how much I want to hear the cold start. Never really used a battery tender. This Saturday I drove to Chicago Auto Show because hell it was like 65+ and it was just fine.
02-19-2017, 06:00 PM | #15 | |
Rep 1,418
[QUOTE=Dabozo;21297871]
I'll keep my eye on it but perhaps I dodged one and all is back to normal. Anecdotally, my neighbour who has owned bmw's for a long time saw me messing with my battery and he told me he has had issues with his batteries with every car! |
02-19-2017, 07:13 PM | #16 | |
Rep 1,133
[QUOTE=Dabozo;21299888]
Maybe something was left on that drained it. At any rate if anything happens I hope you get it covered under warranty. I bet replacing a 900CCA battery at a dealer will cost plenty. |
Dabozo624.50 |
02-19-2017, 08:54 PM | #17 | |
Rep 3,968
Ctek makes some nice chargers and they are not expensive.
02-19-2017, 09:04 PM | #18 | |
155
Rep 248
http://www.shopbmwusa.com/PRODUCT/46...TTERY-CHARGER/ |
02-20-2017, 03:08 AM | #19 | |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-20-2017, 05:42 AM | #20 | |
Rep 3,968
https://www.amazon.com/CTEK-56-864-Automatic-Battery-Charger/dp/B006G14FK8 Use the snowflake mode and connect under hood. Pm me with any questions. |
02-20-2017, 09:15 AM | #21 |
Rep 399
Drives: 2017 BMW M2 6MT
I've had my car parked for 3 months now, drove it twice in that period and had no issues. Car is not hooked up to a battery tender and all is fine.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold |
02-20-2017, 09:26 AM | #22 |
Rep 3,968
All is not fine. You will find that your battery needs replacing much sooner because of this.
BMWM5NYC496.00 |
