02-12-2017, 12:17 AM | #23 |
Living the aloha
240
Rep 449
I didn't realize this was an actual technique. I had always figured why waste some of the view on your side mirrors on looking at your own car? So turning the mirrors out a little just made sense.
This should be taught in driver's ed. |
M3 Adjuster7904.50 SliChillax486.00 |
02-12-2017, 03:01 PM | #24 |
Rep 3,293
Nice diagram. Its been the same basic idea for years but great to see younger drivers getting the information. Remember a quick head check is also a powerful tool unless you're a Jedi, but even then....
My M2 is my first car with Lane Departure warning. MY 2013 A8L did not have it nor blind spot warning. Our 2015 Q7 has the Blind spot warning but not the lane departure warning, go figure. It is VERY nice on that behemoth but I still turn my behemoth head and look! I was in a loaner A4 a few years ago which had the blind spot warning which I reproducibly confirmed and the dealer later confirmed DID NOT SEE SEMI-Trucks! VERY ODD. It saw other cars just fine, but if a Semi was there it saw NOTHING! So just as Luke Skywalker did, TURN OF THE NAVI COMPUTER and LOOK! Mike
02-13-2017, 09:45 AM | #25 | |
7905
Rep 11,785
The easiest way to make this adjustment and confirm it is in a relatively empty parking lot with a few parked cars to use as props. Go find two vehicles that are parked with a space that is empty in between them. Pull your vehicle into the space between them as if to park. Once ensuring that the aisle is free from traffic , pull ahead and out from between the two vehicles so that the rear bumper of your vehicle is just ahead of the two front bumpers of the vehicles on each side of you. This will pretty much place your car squarely in the parking lane, so -again- do this in an nearly empty lot free from traffic. ! Stop your vehicle in the aisle when the two vehicles are in your " blind Spot " and adjust all three mirrors. Use the center mirror to see directly behind you. Adjust the outside mirrors so that you can now fully find the vehicles in your blind spot and make sure that there are no gaps in what you can see behind you. You should be able to look from the center rear view mirror to your outside right side mirror and see continuously. Adjust mirrors so the same is the case for the left side. This usually requires setting your side mirror adjustment so far out that you cannot see the side of your own vehicle from your normal seated position. In many vehicles my settings end up at or near the limit of the power adjustment limit of the factory mirrors. You will be able to confirm that you can see without blind spots and now that anytime in traffic you can quickly check both mirrors - with very little movement - and have the confidence and readiness to make lane changes nearly at all times if you continually scan your mirrors while you drive. Save your seat memory setting (if available ) ...pull away from the parked cars .... and have a nice day ! |
bollinm25.00 |
02-13-2017, 09:55 AM | #26 | |
7905
Rep 11,785
But I agree with your 100 percent on turning your head with blind spots systems and rear parking distance systems also. I can't tell you how many parking lot accidents I have handled where BOTH parties said... " I can't be at fault.. my car has backup sensors and they didn't go off "!. . There is no battle of the sensors .. it's up to the driver to TURN THEIR HEAD... If I find a driver doesn't turn their head. (Because that's always my next question.. " so when did you SEE the other vehicle ? " .. ) they are getting at least 50 percent of the blame for the collision. My girl drives a Cadillac CTS coupe and i would say that it's blind spot detection is very impressive. That car has massive blind spots that you pretty much cannot eliminate with mirrors ( because the rearward visibility is so poor ) and it's necessary to have a system that's very well designed because a driver has to rely on the backup camera and blind spot detection when backing up in that vehicle. |
02-13-2017, 10:10 AM | #27 | |
Rep 3,003
Best place to do this is when parked in a parking lot. Gives the same result without moving your head. EDIT: corrected diagram. red circles are based off of memory and approximate position. Point is you want that line to transect the mirror not that exact spot. Last edited by omasou; 02-13-2017 at 06:33 PM.. |
02-13-2017, 10:40 AM | #28 | |
Rep 3,003
M3 Adjuster7904.50 |
02-13-2017, 03:07 PM | #29 |
Rep 2,200
Wow, a bunch of smarty pants. Thanks for the pointers, but thats not the point here. Its an option available on cars half the price of ours. I don't need a navigation, I could read a map prior or stick my iphone on my windhield; I don't need a rear camera or pdc, I could use my eyes and even take my head out the window when i have to back up to something real close. I don't need a heated steering wheel, I could wear gloves when I first start my cold car. I do not need tpms to display when I have a low tire, I have psi measurer that I could use to check my tires every couple weeks. I don't need brake assist, I don't need lane departure warning, its called paying attenntion while driving. Guess what thats what I did on my bare bones stock E92 with manual leatherette seats for 9 years. So you definitely missed my point here. You pay $57,000 for a car, it'be nice to have an option thats standard on $20,000 cars. Maybe a parent or gf or a close friend would need to borrow the car sometime and it could benefit them more than some of us.
02-13-2017, 06:47 PM | #30 | |
Rep 3,003
The $57K is buying you the 370HP engine, mongo size bushing, sport tires, etc. not things like blind spot detection. If it was included then the price would be $58K for an option that if we are like you would not want and be upset that we had to pay for it. So maybe BMW got that one right. I don't know and maybe others do but my guess as to why we even have lane departure, brake assist and probably even TPMS are to placate the insurance industry and b/c they are, again guessing, the 3 top reasons people get into accidents? Which is reinforced by the number of people that have been pleasantly surprised by their insurance rates for this car. |
02-14-2017, 05:34 PM | #31 | ||
Rep 2,200
02-17-2017, 09:00 PM | #32 |
Rep 3,003
Not saying it wouldn't. Saying what they did add was probably related to insurance. Not sure where the point of diminishing returns would be w/o blindspot or with. Guess would be w/o b/c we don't have it.
02-18-2017, 12:12 AM | #33 | |
Rep 2,200
02-21-2017, 10:09 AM | #35 |
Rep 188
Does the M2 have the "Welcome lights" or whatever they call the lights that are under the door handles. Or any lighting that shines down from the door onto the ground?
02-21-2017, 10:17 AM | #36 |
Rep 418
02-21-2017, 07:14 PM | #37 |
Rep 900
Lane departure warning without blind spot always seemed weird to me. Are people really more likely to doze off than they are to change lanes into someone?
02-24-2017, 02:35 PM | #38 |
Rep 2,588
02-24-2017, 05:47 PM | #39 |
Rep 3,888
You're getting the 2-series options because that's economy of scale to build this thing. Maybe half of the posts in this M2 forum are really 2-series general forum questions. I personally want extra crap like a HUD and blind spot and bird's eye view in my M2 and would have paid more for it. Want a better audio system as well. Can live without Apple Carplay, lane departure or ASD or even motorized seats.
ddnmkun153.50 |
