08-24-2022, 07:04 AM | #23 |
Rep 54
shaneguags1196.00 |
08-24-2022, 05:14 PM | #24 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
10-17-2022, 03:17 PM | #25 |
Rep 54
Quick follow-up:
Rogue mounts on DCT: I may remove these, on the fence. I just flashed the DCT to the CS package from kubax86 so I need more seat time. It was hard for me to tell which benefits more since I did it all at once, but, NVH was just a bit too much at times coming from the tranny and perceptibly different from the NVH introduced by the diff stuff. Turner Brace/Poly bushings on the diff: Def more NVH from this beyond the transmission whine, hear a lot more from the diff gears and such, but the combo of this with trans mounts resulted in my driveline slop being drastically reduced. Certainly, it is more visceral but any common drivetrain quirks/noises are definitely exaggerated. But at the same time, it feels so much better/tighter/connected all around that I feel it is more than fair trade off. Put at least 1k miles on since that, and today went with kubax86 CS flash package: Only a quick drive but the car feels transformed now with this all combined. The biggest thing for me is the DCT flash, which, smooths things out to near perfect. No jerkiness when cold/going slow in low gears. The steering is great too, lighter and more road feel in all modes, especially Sport +. I didn't dislike the heavy steering, but it did feel artificial and this feels more natural and communicative, and precise. Like others, the shift points in auto sport+ aren't aggressive enough (shifts too early) but it's closer to being right than the overly violent OG mapping which I never really liked. Curious if the tranny mounts helped you? If your DCT is on stock software, you may want to look into either kubax86's offering (cheap/easy) or xHP tho I don't know if the CS flash raises the line pressure the way xHP does which, if you believe this, seems a meaningful safeguard along with other improvements when you are going over the original map limits on available power https://www.xhpflashtool.com/blog/20...essure_on_dct/ |
shaneguags1196.00 |
10-17-2022, 06:59 PM | #26 | |
Rep 1,243
10-27-2022, 09:50 AM | #27 |
Rep 54
So here is what I wound up this week...
I gave a few days to the whole CS package. As a whole, I think it's a great spend, but ultimately not for me. It was like $200 for the whole thing and took all of 20 min once scheduled. The thing is the Sport+ auto shift map just really is disappointing. I decided to go with xHP for the trans because of the overall better configurability AND because I am on the latest i-Step, I get the updated benefits to what BMW did directly across the board and I can FDL code the CS Steering/Diff/DSC-MDM myself along with the GTS options for the same. So now, I have xHP which is great and fixes what I disliked about the shift maps across the board, smoothed out everything and CS Steering/Diff/DSC. Great combo. That being said, kubax86 was responsive and all you need is an eNet cable, a Windows 10/11 computer, and a battery charger hooked up and he'll send you the links to get eSys downloaded and ready to go. Very simple process. I read all about the BM3 GTS trans and people's complaints led me to not want to try it. xHP Stage 2 is perfect and does what I wanted it to do. Super smooth, adjustable torque kick (how hard/soft you want the shifts), etc. Pricey, but, overall being able to adjust things was what I really needed. |
10-27-2022, 06:14 PM | #28 | |
Rep 1,243
03-03-2023, 04:55 AM | #29 |
Rep 759
So are the changes (GTS or XPH) reversible back to stock?
'17 M2 DCT Long Beach Blue
