05-22-2018, 10:07 AM | #1 |
4496
Rep 1,862
Drives: powered by bootmod3
bootmod3 New Feature Release - Import OTS Maps, learning experience ***
Hey guys,
We've mentioned this feature in the past as something we've been working on adding and it is now available in the editor. OTS maps that we provide as FREE which are basically OEM like calibration data can now be used as really great reference points if you have a desire to learn how to tune on this platform. In the S55 case you can import the GTS, CS and CSL OTS maps. On the N55 EWG you'll have access to the M2 map and on the S63tu to the Comp Package (600hp) map. We'll be adding others where required as well for those looking for any further references. As an example, you can open your Stock Tune first in the editor, do "Save As" to make a copy of it for custom tuning reasons (stock tune itself cannot be edited). Once you create a map, name it as you wish and proceed to the editor to import one of these OTS maps that you find most appropriate/intriguing and go from there. Editor will highlight tables changed in 'red' between your stock and the imported map. If you click on any given 'red' table you can hover on and off the button called 'Original' and see changes in your original (stock) map and if you hover off you'll see the imported changes in bold. Let us know if any questions at all Here's a quick vid we put together to demonstrate how its done:
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
05-23-2018, 11:37 AM | #2 |
Rep 1,466
Isn't this feature useless for us M2 owners? There is only an M2 stock map that we could import.
I understand that for other EWG N55 owners, seeing the M2 map might be interesting, or for M3/M4 owners, seeing the GTS, CS and CSL maps might be interesting, but for M2, we only have 1 map available. Am I wrong?
2018 ///M2 LCI, LBB, 6MT...
05-23-2018, 12:02 PM | #3 |
4496
Rep 1,862
Yes...unless we have a learning map such as from an OEM N55 EWG that isn't as turned up as an M2 and you could compare the approach that way
05-24-2018, 12:27 PM | #4 |
Private NumNuts
522
Rep 321
This would have been an awesome tool if we had the ability to see the paid OTS stage 1, 2, etc. maps and use them as a baseline to compare to the stock map for tuning. As is, it doesn't really provide any value for M2 owners.
06-05-2018, 09:42 AM | #5 |
Rep 104
How do you turn off cold start? I select it to "off" and save the changes. Does that do it or need to reflash? I tried both and cold start still happens. BTW, i am just choosing my ots maps: stg 2 93 gas v5, not sure what im missing.
I do have cold start rpm as "OEM", not sure if that needs to be amended. |
06-05-2018, 12:14 PM | #6 |
Rep 1,644
06-05-2018, 12:56 PM | #7 |
24190
Rep 190,805
Tags |
bm3, bootmod3 |
