02-17-2017, 05:17 PM | #1 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Max boost you're getting on a standard car
So I'm getting a peak boost of 15.5psi.
Firstly, is this about right and secondly, what are you guys seeing on a stock motor?
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
02-18-2017, 08:58 AM | #2 |
Rep 3,888
A Pure rep mentioned where depending on altitude, temp, and octane you can see up to 19psi stock, as the DME targets load rather than boost. Your 15.5 is prob normal for sea level on 91. That's the same PSI Terry got on his 4/22 dyno testing.
02-18-2017, 04:23 PM | #3 |
Rep 549
Drives: The Bus
Interesting thread so I tested this over the last 24 hours and my Awron report Max boost in Sport+ of 1.16 bar (16.82 PSI).
MY17 6MT, ITG panel filter (HMP-795), running 99RON Shell V-Power Nitro+ |
02-19-2017, 12:48 AM | #4 | |
484
Rep 821
I have an AFE Pro dry filter in the post, too. |
02-19-2017, 02:23 AM | #5 | |
Rep 565
Thanks for info |
02-19-2017, 05:17 AM | #6 |
Rep 549
Drives: The Bus
UK, South East, outside air temp 8C. on a dry crisp day. Did 100 miles in three chunks with max boost 1.15 bar in the AM, 1.16 in the afternoon. 1.16 in the evening. All in Sport+
02-22-2017, 02:37 PM | #7 |
Rep 565
I was out tonight and put 2 clean pulls down in 3 - 4th gear both runs. I got 14psi max. Outside temperature was 4.5deg C
02-22-2017, 03:55 PM | #8 |
Rep 549
Drives: The Bus
What's your elevation above sea level? Manual or automatic?
02-24-2017, 06:15 AM | #9 |
484
Rep 821
Interesting, I went out for an early morning run last Sunday and the peak I got was 14.8psi, and I know I have the same conditions and altitude as CommitConfirm.
I just need to test more
02-25-2017, 09:38 AM | #10 |
484
Rep 821
15.4psi today after dropping in my AFE Pro Dry filter. Shitty weather so no Sport+ on greasy, muddy B roads. Need to do some proper dry weather pulls but that's proving difficult in Feb.
02-25-2017, 08:32 PM | #11 | |
Rep 565
Check this Last edited by kiysersosae; 02-25-2017 at 08:39 PM.. |
03-08-2017, 04:46 PM | #12 |
Rep 565
Here is another graph showing max boost.. Outside temp was 7.5deg C and car was driven hard for about 15min when this was captured. I have installed the Fabspeed dp 200cel, forge intercooler and itg panel filter
I couldn't get intercooler above 26 or boost avouve 13.3psi |
03-17-2017, 01:19 PM | #13 |
Rep 549
Drives: The Bus
Not sure what you 'Auto' guys are doing wrong.... I managed 1.35 bar (19.58 psi) in Sport+ in my 6MT today
EDIT: Have you tried redlining it to 7000-7500rpm? Last edited by CommitConfirm; 03-17-2017 at 01:25 PM.. |
03-17-2017, 08:44 PM | #15 |
484
Rep 821
Been out for a few evening runs the last couple of days. Nice and dry with cool ambient temps, BUT didn't hook up Torque...
It's feeling very strong now at 1800 miles and seems to be adapting to the AFE filter. It's certainly very whooshy and hissy now. Love it.
gavinsan149.00 |
03-22-2017, 02:48 PM | #16 | |
Rep 244
Did you spec M2 in manual or dct ? |
03-22-2017, 05:29 PM | #17 | |
484
Rep 821
I went from a DCT to DCT. However I'll detail the differences in my comparison, because there are some key differences in the application.
03-26-2017, 11:45 AM | #18 |
Rep 549
Drives: The Bus
Managed 1.51 bar (21.9 psi) at a RWYB this morning.
11-28-2017, 12:13 PM | #21 | |
Rep 18
When I put it on Sport+, I get around 24.5 psi in the same conditions. Last edited by Mrt_M2; 11-28-2017 at 03:17 PM.. |
11-28-2017, 06:06 PM | #22 |
Rep 4,496
