11-29-2016, 07:03 PM | #23 |
Rep 1,153
11-30-2016, 01:41 PM | #26 |
Rep 1,418
I'll be doing eibachs with 10mm all around in springtime. Hopefully I'll see a pic of this setup before then...
I had H&R spacers on previous car...Very happy with them. |
11-30-2016, 04:44 PM | #27 |
Rep 105
12-01-2016, 01:12 PM | #30 | |
Rep 1,406
Drives: 2020 SO - M2C
Really debating giving up the iPad so I have something to do this weekend lol |
12-02-2016, 09:55 AM | #31 | ||
Rep 796
I didn't realize how sunk the wheels were until I did this |
shemeld_135652.00 |
12-02-2016, 10:18 PM | #32 |
Rep 1,418
12-03-2016, 08:54 AM | #34 |
Rep 1,406
12-19-2016, 10:14 AM | #35 | |
Rep 69
12-19-2016, 11:40 AM | #36 | ||
Rep 347
I will receive my modified spacers tomorrow and then install during the Christmas days. I did try the 10 mm up on the front axel. Did not like it.. I will also try out the 6 mm on front. Am I picky...yes I am Will make pictures accordingly. Cheers |
12-19-2016, 08:51 PM | #37 |
Rep 96
I have 12mm up front and it could use more. 15mm would be perfect. This is with coils and -3 camber up front
Rear I tried 12mm and it was hideous. Stuck out way too much. No spacers in the rear is just right. 5mm if u really want to but not hub centric so not worth it. 12 or 15 front 0 rear Perfect |
12-25-2016, 01:29 PM | #38 | |
Rep 105
01-27-2017, 02:09 AM | #39 |
Rep 844
Burger tuning spacers look legit. It seems like they are established for the BMW brand.
http://www.burgertuning.com/BMW_wheel_spacers.html |
BAN_M2C4180.00 |
01-27-2017, 02:55 AM | #40 |
Rep 844
Turner tuning looks legit too. They seem to have been around the longest and claim to be the best.
https://www.turnermotorsport.com/BMW...-wheel-spacers |
01-31-2017, 09:14 PM | #41 |
Rep 46
I just saw this thread, but guys, do yourself a favor and steer clear from 10mm spacers because they won't "properly" fit our m2. The hub centric lip (I think that's what it's called) itself is slightly longer than 10mm, which means your 10mm spacer will not sit flat against the brake rotor. 15mm should be fine, but definitely not 10mm.
01-31-2017, 09:55 PM | #42 | |
Rep 240
'02 E39 M5-Gone
'07 E60 M5-Gone '07 E64 M6 Cab-Gone '17 F87 MG M2-Gone '19 F87 SO M2C |
01-31-2017, 10:28 PM | #43 |
Rep 46
Have you removed them? When you do, take a look of the inside of the ring. My front wheels, yes, both, came loose when I thought they were properly torqued. I'm leaving off some details here, let's just say I drove pretty hard , and both wheels came loose after a short drive. When the spacers were removed, there were bite marks on the inside of both spacers. I believe the bite marks came from the hi centric rings biting into the spacers when torqued. I could be wrong, but I feel obligated to put this information out there.
01-31-2017, 11:29 PM | #44 | |
Rep 715
