M2 Technical Topics > Track / Autocross / Dragstrip > Track Setup Q&A - Signature Performance Wheels
      11-02-2016, 08:18 AM   #23
Signature Wheel BMW
Signature Wheel BMW's Avatar
Drives: Signature BMW
More Weight Data from Customers Here... Evidence Alert!!!
REAR SV101 19x10.5 = 21.60lbs
REAR SV103 19x11.0 = 21.55lbs
Just to give you an idea, Stock 437M REAR 19x10 is 23.40lbs
Also, our 19x8.5" were compared with other 19x8.5" wheels in very similar price range. Forged vs Flow Form vs Cast. On the track, weight and strength matters. Don't compromise and join the Signature Movement.
A lot of people put higher quality wheels for the street and cheap weak/heavy wheels on the track. That makes no sense, you're not going 135mph and hitting 1G cornering on the street (at least we hope not).
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
      11-05-2016, 07:57 PM   #24
kenneth
kenneth's Avatar
125
Drives: 335i Sedan
how much for 18 (101)?
SB, Terra, 6MT. Only a few mods here and there.....nothing extreme!
      11-11-2016, 03:01 PM   #25
Signature Wheel BMW
Signature SV102 Brushed Aluminum - 20x9.5 ET20 and 20x11 ET44. MPSS 265/30/20 and 295/30/20.
Owner: kitw
      11-22-2016, 08:53 AM   #26
Signature Wheel BMW
This set of Signature Brushed Black SV103 18x10.5 ET25 front and 18x11.5 ET44 rear is going on an F80 M3 for a dedicated track set. This was ordered with our anti-slip knurling bead tread, this feature to prevent tire slippage which throws the wheel out of balance due to hard braking/acceleration.
      11-30-2016, 08:10 AM   #27
Signature Wheel BMW
A lucky M2 owner in Dubai is getting a set of SV104 in brushed black tinted. 19x9.5 ET30 19x10.5 ET40
      12-08-2016, 01:30 PM   #28
Signature Wheel BMW
SV104 Mounted...
      12-10-2016, 05:11 PM   #29
Signature Wheel BMW
So how much does the new Signature Monoblock SV104 19x11.5 weigh??? Remarkably 20.5lb. Typical M2 setup would be around 19lb front and 20lb rear.
As a track focused forged wheel company, Signature puts strength before feather weight. The SV104 is engineered to incorporate both.
      12-24-2016, 01:48 PM   #30
Signature Wheel BMW
More M2 photos... Owner use 275/30/19 and 295/30/19, less ECU intervention and more traction. No rubbing.
      12-24-2016, 01:55 PM   #31
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
Since this is just rebranded BC Forged wheels, why should you get these over the original wheel?
      12-24-2016, 02:30 PM   #32
Signature Wheel BMW
That's a great question for our customers who purchased from Signature.
      12-24-2016, 02:45 PM   #33
Signature Wheel BMW
Follow us on IG if you want to see this Huracan build once completed. Aiming to be the next 1-mile Lambo speed record holder.
Hint: White Signature SV104 with anti-slip knurling bead tread to hold the 2,000+HP.
IG: https://www.instagram.com/signaturewheel/
      12-29-2016, 02:29 PM   #34
Signature Wheel BMW
Check out this beautiful ESS-VT2-625 E90 M3 with brushed bronze SV104.
IG: https://www.instagram.com/drvmkrz/
      01-18-2017, 09:02 AM   #35
Signature Wheel BMW
M2 Track Setup
champ_87 's SV104 in brushed aluminum with antislip knurling bead tread. Track ready!
M2 Fitment:
19x9.5 ET30
19x10.5 ET40
      04-12-2017, 12:11 AM   #36
Signature Wheel BMW
Signature SV104 Brushed Aluminum - 18"
Signature Full Forged SV104 - JWL/VIA Certified - 18" - 18LB front and 19LB rear
Customer's IG: https://www.instagram.com/__joeparker__/
      04-30-2017, 12:02 AM   #37
Signature Wheel BMW
Signature SV104 - Brushed Aluminum
M2 Setup - Signature Full Forged Monoblock SV104 - Brushed Aluminum - 19x9.5 ET30 and 19x10.5 ET40
      05-07-2017, 09:54 PM   #38
Signature Wheel BMW
Signature SV103 - Rose Gold
If you're going to track, might as well look good doing it. Signature Fully Forged SV103 track set for an F8x.
      08-10-2017, 06:42 PM   #39
casestudy83
casestudy83's Avatar
21
Drives: 2018 M3
How much for this set
      03-14-2018, 11:33 AM   #40
MTornberg
Drives: BMW G11 LCI 740 d M-Sport xD
Mine are ready to bite the tarmac....
9,5x19 ET25 with 265/30
10,5x19 ET40 with 295/30
      03-16-2018, 01:20 PM   #41
Signature Wheel BMW
MTornberg Looking good, Mike. Can't wait for mounted photos.
      04-02-2018, 10:44 AM   #42
MTornberg
If all works well, it'll be this week!
      04-04-2018, 11:38 AM   #43
Signature Wheel BMW
Track Series SV502
Here's Track Series SV502 in Gunmetal. Track Series is purpose built forged wheels for track and aggressive road usage. Clean cut and unnecessary weights removed.
*GT350R Ford Performance Racing School
      04-13-2018, 11:54 AM   #44
MTornberg
Signature SV501
Tags
bmw m2 track wheel, bmw m2 wheel, m2 offset, signature wheel
