09-17-2016, 05:51 PM | #23 |
Rep 226
Great job OMG I want that roof, my hesitation though is the safety aspect of it. Does anyone know is the roof as strong as OEM??? my car will be a DD. The roof is pure porn, If I were only using my car for the track I would pull the trigger immediately. Guess until more info about the roof specs comes out, so I can make an informed decision, I will just have roof envy.
09-18-2016, 02:03 AM | #24 | |
Rep 226
09-18-2016, 12:23 PM | #25 | |
Rep 3,022
M2 Arrived!
Family 5er |
pup73516.50 |
09-18-2016, 11:55 PM | #26 |
Rep 3,157
what's the weight saving in comparison?
and what's the damage?
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
09-19-2016, 12:43 AM | #27 |
Rep 226
I will get answer hopefully Monday or Tuesday from German Motors Collision Center. It's a BMW authorized factory repair center and they repair/replace carbon fiber roofs on M3's here in San Francisco. They should have specs and tolerances for doing this type of work. Also mainly what the labor cost will be.
TMP349.00 CommitConfirm474.50 |
09-19-2016, 01:10 PM | #28 | |||||||||||||
9578
Rep 10,875
This is a complete replacement. You remove your original BMW roof panel, and install this in it's place. This roof weighs in at 7.5lbs. We'll have the metal roof panel in hand today to weigh it. Our E90 carbon roof provided a 60% weight savings over stock, to give you an idea: http://ind-distribution.com/blog/?p=666 Quote:
Thanks! This roof will be available in both weave patterns. Quote:
That's about right. The very low end would be about $1,600 for labor, and the high end should come in at about $2,400. A typical qualified body shop can perform the install in the $1,800~$2,000 range. Quote:
That sounds like an ideal place to perform the work! Here is a blog entry we posted some years ago, about an E90 M3 carbon fiber roof install: http://ind-distribution.com/blog/?p=666
TMP349.00 |
09-20-2016, 10:15 AM | #29 |
9578
Rep 10,875
The weights are in!
OE BMW: 18.5lbs RKP: 7.5lbs The RKP roof therefore yields a 60% weight savings over the factory BMW roof panel, providing a reduction in weight in the most critical area of the car.
09-20-2016, 12:15 PM | #30 |
5368
Rep 3,789
09-24-2016, 03:11 AM | #31 |
Rep 3,022
Imran, Any plans to fit this for us in the UK?
M2 Arrived!
Family 5er |
09-27-2016, 10:55 AM | #33 |
Rep 1,835
Drives: 2020 X4M CS
Im wrapping my roof w high quality 2x2, i cant spend 2gs to save 10lbs even if it is stiffer and does slightly lower the COG.
That being said, beautiful piece and I envy those ho have the liquidity to buy this... Question does anyone make Carbon fiber hoods or trunk lids? Or the C/F Front lip on the Armitryx green M2???
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
10-03-2016, 03:47 PM | #35 | ||
9578
Rep 10,875
PM Sent!
10-08-2016, 07:46 AM | #36 |
2006 TIME Person Of The Year
9720
Rep 6,445
A true badass would put the carbon roof on their car painted.
10-24-2016, 10:22 PM | #37 |
Rep 3,157
Is there any information on the weave pattern? will it match up with the M carbon parts?
10-28-2016, 12:39 AM | #38 |
Rep 3,157
no one from IND cares to reply?
10-28-2016, 01:09 PM | #39 |
1765
Rep 7,650
It is available in both 1x1 and 2x2(M perf) patterns
01-22-2017, 01:25 PM | #40 |
Rep 151
I double much structural load if any at all goes into the sheet panel of the roof. There is probably an extensive structure around and under the panel to handle actual loading.
01-27-2017, 09:43 AM | #41 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
Fitment is great and quality is excellent! It's survived the crazy rain we had here in socal (probably mild rain for the rest of you). also it stood up to the light hail we had without any damage or leaks. Purchased and installed thru eas.
Had antenna and roof strips painted as well The car really should have come this way from BMW. |
01-27-2017, 10:31 AM | #42 | |
9578
Rep 10,875
UltraMagneticAL925.50 |
01-29-2017, 05:18 PM | #43 | |
Rep 240
Agree that should have been an option, nice work.
'02 E39 M5-Gone
'07 E60 M5-Gone '07 E64 M6 Cab-Gone '17 F87 MG M2-Gone '19 F87 SO M2C |
06-13-2018, 09:44 AM | #44 |
9578
Rep 10,875
We completed a video to show the process of another RKP carbon roof panel install.
Full car feature: http://f87.bimmerpost.com/forums/sho...4#post22957164
Dog Face Pony Soldier9719.50 RN_202156.00 |
