09-20-2021, 09:00 PM | #1 |
20287
Rep 8,586
I just bought this for my OG
Was wondering what others think of the inside finish? Does the inside need to be trimmed or is that not a issue for airflow? Also the adapter is clearly marked V1 and the Box says V2 and that's what I ordered Anybody that's familiar with this inlet know if the adapter to the turbo is Version 1 or a V2 ?
09-20-2021, 09:27 PM | #2 | |
Rep 7,470
I also do recommend washing out your silicone hose with distilled water it does look a bit dusty.
///M TOWN20287.00 |
09-20-2021, 09:28 PM | #3 | ||
20287
Rep 8,586
I got your PM but was to quick to reply
F87source7310.50 |
09-20-2021, 11:50 PM | #4 |
@_sunbish
284
Rep 611
Your pic shows that the aluminum piece has a sticker indicating V2. That to me, looks like a V2. That's the one you'd want.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5 |
///M TOWN20287.00 |
09-21-2021, 03:28 PM | #6 | |
20287
Rep 8,586
Installing it on Sunday, I cannot wait to feel the difference, I am installing my new Charge Pipe as well
09-23-2021, 09:22 AM | #13 |
24350
Rep 191,156
09-23-2021, 01:45 PM | #15 | |
20287
Rep 8,586
Yeah MST said it was marked wrong and sent me this picture accordingly
09-30-2021, 01:36 AM | #19 |
20287
Rep 8,586
Installed the MST Version 2 inlet
Best way to install it is to remove the PCV hose from the valve cover and pre attach it to the billet fitting that attaches to the inlet Otherwise it's almost impossible to install because you cannot access one screw With enough finesse I got it to fit together with the intake and have it situated so it's not really touch anything Heads up MST pre installed the PCV fitting incorrectly causing it to be impossible to attach the set screw that holds it together Results we're having to start over and fix their ridiculous oversight An aftermarket intake is overrated for sure I am impressed with the MST Inlet so far
09-30-2021, 02:00 AM | #20 | |
Rep 7,470
///M TOWN20287.00 |
09-30-2021, 02:03 AM | #21 | ||
20287
Rep 8,586
Mine had a wiring harness, or some sort of a hose in the way, there's no way I could've done it any other way in my situation Point taken though because those little tabs inside that sucker are very delicate
09-30-2021, 02:11 AM | #22 | |
Rep 7,470
But yes those pcv hose clips are very brittle, I believe a fuel hose connector remover tool or something similar would be key to easily removing it.
///M TOWN20287.00 |
