12-30-2016, 12:07 AM | #23 |
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
Can you post a few pics from farther away? Showing the whole rear of the car from a few angles? You have the exact combination I am looking at doing, MG with carbon fiber diffuser and the black angle tips. Thanks!
Current Car | 2018 ///M2 MG 6MT
Previous Car | 2003 E39 530i Sport |
12-31-2016, 05:00 AM | #24 |
Rep 324
12-31-2016, 07:15 AM | #25 |
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
Thanks for the pics. Just ordered a set for my MG M2.
12-31-2016, 10:16 AM | #26 |
this is the way
18345
Rep 8,553
12-31-2016, 03:35 PM | #27 |
Rep 4,186
i don't remember to tell u the truth. it was a powdercoating company in the northern suburbs.
-JLT- |
01-02-2017, 09:19 PM | #28 | |
Rep 1,419
01-03-2017, 12:18 PM | #29 |
Rep 7,594
Drives: '19 M2C
Don't use one with spraying the WD-40 from the back side. If you do, you will twist the spring clips and damage them inside the tip.
Like I did
www.ReTuneTheDeTune.com
01-03-2017, 01:09 PM | #30 | |
Rep 240
Thanks
'02 E39 M5-Gone
'07 E60 M5-Gone '07 E64 M6 Cab-Gone '17 F87 MG M2-Gone '19 F87 SO M2C |
01-03-2017, 01:31 PM | #31 |
Rep 7,594
Drives: '19 M2C
Don't use the band clamp and twist the tip. That twisting of the clips inside will break the tip. I'll post a picture when I get home today.
01-03-2017, 04:18 PM | #32 |
Rep 7,594
Drives: '19 M2C
This is what happens if you don't use WD-40 on the tips and only use the band wrench.
01-03-2017, 04:20 PM | #33 |
Rep 7,594
Drives: '19 M2C
Here is an image of the car without tips.
///M TOWN20030.00 |
01-03-2017, 04:44 PM | #34 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
What size are those Cyba tips? 90mm?
01-09-2017, 11:48 AM | #37 |
Rep 1,419
01-11-2017, 05:22 AM | #38 |
Rep 324
arquitecto535.50 |
01-13-2017, 02:28 PM | #39 | |
Rep 61
and never used a drop of lubricant or had ANY damage. Looking at those pics looks like major sustained torque was applied. Once you break them loose with a a1/4 inch turn use one hand to pull and the wrench hand to keep slight torque on the tip and they slip off. I'm sure WD-40 wouldn't hurt but I've never used it. YMMV Last edited by OBXBMW; 01-13-2017 at 07:45 PM.. |
01-16-2017, 10:04 AM | #40 | |
Rep 7,594
Drives: '19 M2C
03-01-2017, 11:31 AM | #41 |
Rep 236
Drives: 2017 M2 6MT
Hi Glounk,
I was hoping to get you feedback on the tip install. I just installed my M4 tips. The retaining clips look like they are for slant internal tips as the clips are offset. The top clip is further toward the top of the tip and the bottom clip is 1" deeper. Looking at the pic, it looks like you pushed the slip on tip all the way to the top clip. Did you just push in the bottom clip (can't see the bottom retaining clip in the pic) to clear the internal tip? Did this torque the tip upwards? It looks straight to me. Did it damage the bottom clip or make it difficult to take the slip on tip off? If I only push the slip on to the bottom clip, they stick out further than I'd like and they don't lock in enough. Thanks in advance. |
03-01-2017, 02:01 PM | #42 | |
Rep 236
Drives: 2017 M2 6MT
I was able to wiggle (side to side) past the bottom pronged clips and the tips pushed all the way to the bottom lip are on straight. Now the tips set back further like in your pics and will not easily slip off like before. Thanks for the pics. That helped. |
03-02-2017, 06:09 PM | #44 |
Rep 236
Drives: 2017 M2 6MT
I got mine from bmwpartspros @ $50 each.
Tip Removal: One more thing that I learned... with all this back and fourth about the tip removal. I had mine installed and the installer used a crescent wrench, adjusted it so that the size didn't hit the exhaust (just the slip on), put the crescent wrench behind the tip and tapped away. Being on a lift made it easy for access but I thought I'd share the tool used and his method. By far the best method I heard with my research and seeing it in person. |
ryem31042.00 |
