10-11-2019, 10:33 AM | #1 |
Rep 204
Brake Dust
Getting a lot of brake dust from the front brakes, really hard to keep the wheels and calipers clean. Assuming this is normal, but wanted to do a sanity check?
10-11-2019, 01:50 PM | #4 | |
Rep 7,594
Drives: '19 M2C
Ceramic coat the wheels ASAP! Much easier to keep clean after.
www.ReTuneTheDeTune.com
10-11-2019, 05:54 PM | #5 |
Flavor of the month
924
Rep 740
Drives: BMW F87 M2C
Standard complaint with OEM brakes, multiple manufacturers have that issue. Aftermarket pads will prob be a lot less dusty depending on brand.
10-11-2019, 09:37 PM | #7 |
Rep 596
20 spoke wheels, brake calipers that don't allow a thick sheet of paper to go between them and the inner barrel of the wheel let alone a wheel brush.
It takes me a good hour to wash just the wheels to my satisfaction. it's rough lol I keep my car in neutral and open the trunk and pull the car so I can get the spots blocked by the caliper. They look great for about 10 minutes! |
10-11-2019, 10:44 PM | #8 |
Rep 336
10-12-2019, 07:34 PM | #9 | |
Rep 67
I had the wheels coated along with the car when I took it to the detailer. The wheels still get nasty and collect dust, but very easy to clean. Plus I swapped to 437’s, so they clean quickly too. |
ChrisK4452.00 |
10-12-2019, 08:18 PM | #10 |
6643
Rep 4,145
Drives: '18 M2 6MT
The cheapest fix is replacing the stock pads with Akebono's, which dust a LOT less, and are much easier on rotors as well. Obviously you'll sacrifice some performance, but if you're not tracking your car you should be fine.
10-13-2019, 02:16 AM | #11 |
Rep 24
Drives: 2020M2 Comp, Porsche Macan GTS
Does anyone know if EBC is making pads for the M2C big brakes yet? Had a set of their Yellow Stuff pads on my Porsche and they were amazing. Low dust and incredible performance.
10-13-2019, 12:44 PM | #12 |
Rep 2,924
Only way out is: ceramic brakes
Currently: '22 Ferrari F8 | '24 Mercedes G63 | '24 Porsche GT3RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4 Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen |
10-13-2019, 01:08 PM | #13 |
Rep 395
Drives: F87 M2C
Do they not already? Checked the website and it looks like they do. I don't know what the pads actually look like so I can't make sure.
Past: 2011 Acqua Minerale Blue Hyundai Genesis Coupe 3.8 Past: 2017 Alpine White 440i F32 Current: 2020 Long Beach Blue M2 Competition PC Build: 5950x/6900xt |
10-14-2019, 01:35 PM | #14 | |
Rep 843
But yeah it's unfortunately way too normal. |
10-15-2019, 09:02 AM | #16 |
4972
Rep 10,200
I got an iK Foam Sprayer (one of the little ones) and some Brake Buster (citrus based, non-acid) to go along with my wheel brushes and pressure washer. The 666Ms are very similar, spoke-wise, to the 788as, so I feel your pain.
The car washing part doesn't take long at all - the wheels are another story, but honestly I don't mind. I find it therapeutic.
10-16-2019, 07:53 PM | #17 |
2531
Rep 1,908
On related note . . . why do brake rotors form a layer of rust before the car can even be completely dried after washing?! As quickly as you pump brakes for the first time there is a layer of 'rust dust.' Infuriating! Is there a way to prevent this nearly instant rust formation?
///AVM |
10-16-2019, 11:01 PM | #18 |
Rep 395
Drives: F87 M2C
Hyde's Serum Rust Stopper is one product I know of, never tried it myself. I think there are some wheel cleaners out there with similar effects. I've never cared to try them out.
///AVM2531.00 |
10-17-2019, 09:31 AM | #20 |
Rep 2,138
I realized last night that the gray 2NH calipers along with the ‘black’ 788m wheels do an amazing job at hiding all the brake dust.
Swiped the caliper and wheel edge with my index finger only to find a ridiculous amount of coated brake dust layer. |
10-21-2019, 08:22 AM | #21 |
Rep 218
True! but after cleaning them up for the first, you'll be able to tell the difference.
10-21-2019, 10:31 AM | #22 |
2531
Rep 1,908
Short of, perhaps, ceramic brakes – which I have never owned and cannot attest – it seems nothing can prevent brake dust. Heck, as per my prior post, rust on the brake rotor starts to form before the car is even dried after washing. The second you apply the brakes after washing, there is layer of ‘rust dust.’
What I can share is just how easy it is to remove the pad/rotor dust IF you pre-treat the wheels. Some report ceramic coating, which I have not tried. I utilize Swissvax cleaner fluid to decontaminate the wheels, then applied Autobahn wheel wax with non-stick PTFE. I wish I could say it works so well that all you need to do is rinse the wheels with hose to remove the dust . . . no such luck. I can attest that decontamination/Autobahn application makes cleaning VERY simple via wetting with hose gentle wipe with microfiber cloth rinse. Clean as new. Quick tip: although the dust comes off very easily with above protocol, the microfiber cloth with be all but useless after wiping wheels. Do not use quality/microfiber cloths. You can purchase packages of 50-100 small microfiber cloths from most local auto stores (e.g., Autozone, O’Reilly, etc) and even Walmart for about $20. Not what I would use for paint detailing, but perfectly soft and applicable for wheels. Given the quantity you get for the price, very reasonable to use a single cloth per wheel, then toss. ///AVM |
