M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > DINAN Stage 4 review...UPDATED WITH DYNO GRAPHS POST 56
      04-10-2017, 08:57 AM   #45
auf Deutsch
auf Deutsch's Avatar
2017 BMW M2  [0.00]
Originally Posted by omasou View Post
You should update your user name to grumpylittleoldman, as every post is negative. At least the ones I have read.
Since you have not been following along...Why don't you take a second and search his post history and you will find answers to most of your questions.
He's been banned from the clubhouse so we won't be hearing from him anymore unless he creates a new account.
retired: 2014 435xi|MPPK|335 bhp|3/5 stars
      04-10-2017, 01:45 PM   #46
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
auf Deutsch Just out of curiosity, what are the improvements in speed on the 0-60, 60-120 ranges?
      04-10-2017, 02:00 PM   #47
auf Deutsch
2017 BMW M2  [0.00]
I can't give you an honest answer. If I were DCT, I could take video of the speedo. It's just too hard (and dangerous) while shifting. 0-60 should be sub 4s easy with either transmission.
C&D has a press car. They should be performing an instrumented test. Unfortunately, they never do rolling tests.
      04-14-2017, 12:48 AM   #48
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Originally Posted by auf Deutsch View Post
Originally Posted by SeanWRT View Post
Congrats! Really nice to see it's worth the wait and money. You definately need dyno numbers to complete the party
You made me kind of regrat that I ordered and installed everything except for turbo. The lack in power at top end is killing me over these days...
I'm able to use the last couple 1000 rpm as it pulls to beyond the 7000 redline all the way to 7200 fuel cutoff. I now know what the E9x guys are talking about as it pertains to winding out the engine except in this case, we also have the low end torque associated with FI...best of both worlds.
Keep an eye out for incoming email with dyno attachment in the coming weeks.
Sure do it asap before it gets warmer. Do it making sure you use the same fuel and gear and dyno shop isn't manipulating numbers with different correction factors. And don't forget make various overlays.
Congrats for being the 1st independent globally with a Stage 4 dyno before and after.
Lemania 2320
      04-15-2017, 11:32 PM   #49
filet.M2c
filet.M2c's Avatar
784
Drives: M2c / mach e
You can't run e85 with the dinan tune, correct? Anyone have experience running a JB4 along w/ dinan to allow for this? AZ doesn't get the greatest gas but I do have access to e85, which made a huge difference back in my N54 135i
      04-15-2017, 11:57 PM   #50
SeanWRT
SeanWRT's Avatar
3179
Dinan turbo is similar to pure stage 1 in flow capacity.
Pure+JB4 has been popular. Whatever tune works for pure should work for Dinan as well.
Lemania 2320
      04-16-2017, 11:12 AM   #51
filet.M2c
filet.M2c's Avatar
784
Is this true? I was under the impression that the dinan turbo was larger than stock, while pure stage 1 is just a modified compressor wheel with the stock turbo housing.
      04-16-2017, 11:52 AM   #52
SeanWRT
SeanWRT's Avatar
3179
Dinan modifies compressor only like ps1.
Ps2 modifies turbine and compressor.
All of them use stock housing.
Lemania 2320
      04-17-2017, 04:50 AM   #53
auf Deutsch
2017 BMW M2  [0.00]
I have a dyno session TENTITVELY scheduled for Monday, the 24th at Fabspeed.
No Boost4021.00
      04-17-2017, 12:17 PM   #54
Fabspeed Motorsport
Fabspeed Motorsport's Avatar
Drives: BMW M235i
Awesome write up. I'm excited to bring it in for some dyno runs!
      04-24-2017, 12:21 PM   #55
auf Deutsch
2017 BMW M2  [0.00]
Just got back from my dyno session at Fabspeed Motorsport. SeanWRT will upload the graph which includes the stock run, with Fabspeed DP, and stage 4/DP combo. The peak numbers are as follows:
stock: 319/361
DP: 337/384
stage 4/DP: 382/408
Before anyone says "you should be hitting 400 whp", consider the following....The stock numbers are lower than what others have typically gotten (330-340). This particular dyno is a "heartbreaker" as noted by @[Fabspeed Motorsport].(contact:274731)
I can agree with this as I got 349 whp on my original dyno completely stock at Evan's Tuning in Allentown. A second reason is that we did the pulls in 4th gear which isn't ideal. 5th gear is the closest 1:1 ratio. Unfortunately, the dyno was being temperamental and for some reason, this wasn't possible. I'd guess higher numbers would be achieved using 5th gear.
Appreciate 6
BruceM985.50
SeanWRT3179.00
No Boost4021.00
filet.M2c784.00
      04-24-2017, 01:29 PM   #56
Fabspeed Motorsport
Drives: BMW M235i
Here is the dyno sheet below!
Appreciate 6
DETRoadster11462.50
No Boost4021.00
BruceM985.50
stefan2354.00
      04-24-2017, 01:55 PM   #57
auf Deutsch
2017 BMW M2  [0.00]
~3700 to ~5700 is 50 whp over stock. After 5700 it seems to increase to 75 whp over stock up to 6500. Shame about the software glitch that showed over 2000 HP after 6500. I think it would've held to ~350 to redline.
      04-24-2017, 06:01 PM   #58
stefan
stefan's Avatar
Drives: M2 Comp
Power profile looks pretty solid for a turbo motor!
///M Power
No Boost4021.00
      04-24-2017, 07:44 PM   #59
SeanWRT
SeanWRT's Avatar
3179
60+whp gain out of 6psi feels just right.
It confirms the result n54tech has been getting for years that compressor modified turbo, aka stage one, unlocks 20-30whp of peak power on top of a FBO EWG car. Enlarging turbine side (stg2 turbo) should free up more, but spool up would be noticeably effected.
Huge congrats on your perfectly balanced build!
Lemania 2320
No Boost4021.00
      04-24-2017, 09:41 PM   #60
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
stock: 319/361
DP: 337/384
stage 4/DP: 382/408
Nice. What kind of boost are you seeing? Does it hold all the way to red line or is there some tapering off?
FBO-PS1 and stuff
      04-25-2017, 04:22 AM   #61
auf Deutsch
2017 BMW M2  [0.00]
Thanks Sean. It has the same lag as stock.
Don't know how much boost. It feels like it holds to right about redline.
      04-25-2017, 10:03 AM   #62
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
Thanks for sharing! It looks liek you've got an awesome setup. Your ///M must be a blast to drive.
      04-25-2017, 10:35 AM   #63
filet.M2c
filet.M2c's Avatar
784
Well then I'm curious how this would stack up against an M2 with FBO+ps1. Based on what the PS1 has demonstrated on other N55 applications, it seems the results would be very similar to the dinan setup.
      04-25-2017, 11:29 AM   #64
auf Deutsch
2017 BMW M2  [0.00]
Bobby "King of DP sales" at Fabspeed drove it, said it's really fast. I can't argue. It's not twitchy or peaky which was a goal. Just smooth, progressive acceleration throughout the RPM band, almost like a super MPPK oem tune. For me, it's $6k (including $$$$ labor) well spent.
BruceM985.50
DrKevM52274.50
      04-25-2017, 11:49 AM   #65
Fabspeed Motorsport
Drives: BMW M235i
Bobby "King of DP sales" at Fabspeed drove it, said it's really fast. I can't argue. It's not twitchy or peaky which was a goal. Just smooth, progressive acceleration throughout the RPM band, almost like a super MPPK oem tune. For me, it's $6k (plus $$$$ labor) well spent.
He's not kidding. This thing definitely boogies. M3/4's better watch out for this guy.^^^
DrKevM52274.50
emargul204.50
      04-27-2017, 08:17 AM   #66
Fabspeed Motorsport
Drives: BMW M235i
Mike in Marketing here - here's a dyno video!
