06-30-2016, 12:26 AM | #67 | |
Rep 19
06-30-2016, 02:46 AM | #68 |
S0THPAW
8717
Rep 7,846
So when I have the switch @ 'auto' , no instrument lighting... when switching to fully on(max to the right) the instruments light up like we want it.
How easy can it be to code the latter for the 'auto' mode? I will ask my dealer today when I'm there. Cheers Robin |
06-30-2016, 03:36 AM | #69 | |
Rep 1,514
I still think even with the orange backlight it doesn't help that much with visibility during daylight. Slightly off topic but while talking about the switch being on 'auto' anyone else notice their lights seem to come on and stay on quite often while it's still daylight, not even overcast or anything? |
06-30-2016, 04:09 AM | #70 |
Rep 2,234
Good God, talk about people blowing something out of proportion. When the ambient light levels darken to a level that makes it harder to see the dials, then move the switch from the "auto" setting to the "side lights" setting. How difficult is that?
06-30-2016, 06:40 AM | #71 | |
Rep 2,523
'22 X5 4.0 M Sport Black Sapphire/Tartufo ?22 Tesla Model Y Performance Midnight Silver/White Last edited by DrKevM5; 06-30-2016 at 12:55 PM.. |
06-30-2016, 08:37 AM | #72 |
Rep 486
06-30-2016, 01:04 PM | #73 | |
Rep 13,107
However, that does not resolve the issue, because the light sensor still decides autonomously over the backlight intensity when you switched the light switch to the right. The light sensor controls the dimmer: 'very low backlight' when the light sensor considers that there's sufficient light, to 'strong backlight' in full darkness. But you know that already, do you ? But unbeknownst to yourself, you're spot on with your "blowing something out of proportion" claim: the light sensor is disproportionately underperforming, so we gotta find a way to blow it out of proportion, allowing to operate the backlight dimmer at maximum intensity regardless of the lighting conditions.
///M is art ↔ Artemis
06-30-2016, 01:38 PM | #74 |
Rep 195
I am a trained human factors engineer and an M2 owner. I agree that the gauge cluster is extremely difficult to see in certain lighting conditions. The specific conditions that I have issues with the gauges is when driving towards the sun, with trees closely along side the road that limit the available light to reflect off of the gauges.
I think the gauges are likely under the recommended contrast ratio under these lighting conditions, while they are above the recommended contrast ration in most other lighting conditions. While there are guidelines for the contrast ratio on gauge displays, these guidelines can't take into account each of our unique experiences because our eye-brain interpretations of the contrast is unique. I do not beleive that increasing the illuminace of the gauges by turning on the red/orange of the backlighting will lead to a noticable increase in our perceptions of contrast due to the specific characteristics of the lighting conditions that cause the issue. The backlighting would need to provide a greater degree of contrast than the red/orange can to provide effective readability. My recommendation to the designers would be to use white backlighting, or numbers and tick marks with higher reflectance to provide the contrast needed. |
06-30-2016, 02:00 PM | #75 | |
Rep 1,668
The best solution IMHO would be a permanent bright white daylight illumination of the gauges. Like the white LED temperature numbers for the airco. (daylight condition) Bright red for the needles. (supreme contrast) -The vissability would be hugely improved -The matching color would be the icing on the cake |
07-02-2016, 06:10 AM | #76 | |
Rep 2,234
The same situation occurs on my M135i. It's not an issue. I just put the side lights on. |
07-02-2016, 07:06 AM | #77 |
Rep 1,514
07-02-2016, 08:10 AM | #78 | ||
Rep 13,107
M2:
07-02-2016, 08:35 AM | #79 | |
Rep 13,107
Dr. Ing. h.c. F. Porsche AG
07-02-2016, 08:45 AM | #80 |
Rep 2,234
The reason Porsche place the ignition on the left hand side of the steering column stems from Le Mans. It would save time if the driver can jump in the car and shift the gear into 1st with his right hand, and start the car with his left hand.
07-02-2016, 09:01 AM | #81 | |||
General
17488
Rep 25,115
My car made front page of Bimmerpost
07-02-2016, 10:09 AM | #82 |
Rep 2,234
07-02-2016, 03:57 PM | #83 | |
Rep 836
The real issue, and that which cannot be captured by a single still image, is the transition of human vision from bright sunny day/road to dark/dim instrument cluster. I would imagine that most people do not have vision that instantly transitions. That's where the problem lies. It is impractical and unsafe to allow for your eyes to adjust. In the absence of adjustment, the cluster is difficult to read. Impossible? No. Difficult, yes. Regardless, I would consider it a safety issue for those that feel dependent upon their speedo/tach for driving. |
07-02-2016, 08:18 PM | #84 | |
Rep 715
07-03-2016, 02:21 PM | #86 |
S0THPAW
8717
Rep 7,846
07-03-2016, 02:21 PM | #87 |
Rep 3,341
07-03-2016, 04:35 PM | #88 |
Rep 2,856
Fully agree! First thing I spotted when I drove the press car in April...
Luckily you can code it so that it stays on. MR |
