07-26-2022, 12:28 PM | #67 |
The Seeker
13863
Rep 3,325
Evan@Tischer
Can you get these yet bro? If you can you should advertise more, you always have the best prices (and fantastic service). |
Evan@Tischer3374.00 |
07-26-2022, 12:32 PM | #68 |
3374
Rep 22,756
I've been holding off on advertising these as they've been back-ordered - I will be posting them up just as soon as inventory is available. (they can be ordered through our site at this time, but we don't currently have an ETA on when we'll see them just yet)
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts! |
///MPhatic13862.50 |
07-26-2022, 12:50 PM | #69 |
3024
Rep 13,764
uh....I already have a set and shared the info on the PN I've used to put these on my M2 CS. If others want to go with 196, be my guest, but 545 also fits perfectly fine on my trunk, and it will fit nicely on my M235iR trunk as well.
~loud noises~
07-26-2022, 01:05 PM | #70 |
Rep 754
Drives: 09 //M3 e90 Interlagos Blue
Some nice folks used a jackhammer to install their 50th Anniversay roundels to their M2s, because they ordered the wrong PNs.
BMW Enthusiasts rely on Bimmerpost for accurate technical information to avoid the excessive costs of repairs and Mods. This is especially true as ///M cars approach $90-100k prices. Of course, any adhesive only roundel will fit hood/trunk alike. So you lucked out. Not much difference in size between 74mm and 82mm. BMW could have made roundels the same size with the same rear mounting across platforms. But that makes too much sense. Cheers |
07-26-2022, 01:17 PM | #71 | |
3024
Rep 13,764
Whether 196 or 545, both fit and if you put them side by side I guarantee you 9/10 no one would notice the difference. Just sharing for those that don't want to wait until August. I ordered Sunday, and they're already dispatched from APM today. Also, 4 are in stock at APM.
~loud noises~
07-26-2022, 01:17 PM | #72 | |
Rep 6,939
Drives: 2018 M2 AW DCT
And as you saw in a previous post GETBMWPARTS does not have any inventory on 50th Anniversay roundels. |
07-27-2022, 03:47 PM | #74 |
Rep 754
51117886545 is indeed 74mm. It looks like BMW added the smaller 74mm roundel on the hood for the G8X M3/M4 and the larger 82mm on the trunk for the G82/G82 M4, with the 74mm for the G80 M3.
That is backwards for most BMWs over the last 20+ years. HaHa Cheers |
DanG10664.50 |
07-30-2022, 10:45 AM | #77 |
Rep 754
Thanks to updated photos on the Paddleshifterz site and eBay for various 50th Anniversary Classic M roundels, there are a range of PNs that fit a F87 M2.
51148087188 - 82mm (HOOD) No Pins/Perimeter Adhesive Only - 3 Alignment Holes 51148087189 - 82mm (HOOD) No Pins/Entire Rear Surface Adhesive Only - 2 Alignment Holes 51148087190 - 82mm (HOOD) - You have to break off the 2 pins, so get 188/189 instead. 2 Arrow-shaped Pins/Entire Rear Surface Adhesive 51148087195 - 74mm (TRUNK) 2 Pins/Perimeter Adhesive 51148087196 - 74mm (TRUNK) 2 Pins/Entire Rear Surface Adhesive 51117886545 - 74mm (TRUNK) 2 Pins/Perimeter Adhesive Some vendors ship what they have in stock, versus what is the best fit for your vehicle application. NOTE: Be prepared to add some 3M double-sided tape in a pinch. I ordered my BMW E9X M3 and F30 335i roundels as a mystery box from a US BMW Retailer. So I will see what arrives. I will probably order extra similar roundels with different PNs to compare the rear mounting. I also ordered aftermarket 5 x 120mm 68mm wheel center caps from eBay from a US seller to check the quality and fitment. I added the steering wheel emblem. Cheers Last edited by nyc_dude; 08-03-2022 at 07:51 PM.. |
08-03-2022, 06:39 PM | #78 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
I wanna see them on the LBB M2, I'm curious if it'll look good
08-03-2022, 07:36 PM | #79 | |
3024
Rep 13,764
~loud noises~
08-03-2022, 08:01 PM | #80 |
Rep 754
Yes 190 has arrow-shaped pins...not 545. Copy and Paste Typo.
I received the 5 x 120 mm (68 mm dia) wheel center caps from an eBay seller in Beverly Hills, CA. Good quality plastic tabs that are not brittle and the emblem has a clear plastic film to protect the finish until installation. It has the raised chrome highlights around the inner BMW emblem. I just need to order the steering wheel emblem...it is not sold separately. I should have the 50th Anniversary hood/trunk emblems by the end of next week for an BMW E9X M3 and F3X 335i M-Sport. I will measure to see if the pin spacing is different across PNs, explaining why there are so many similar PNs. Cheers |
DanG10664.50 |
08-03-2022, 08:15 PM | #81 | |
Rep 754
https://www.studie.jp/endo/126394/ The best exterior color matches are White, Black, Red, and Light Blue. I have an Estoril Blue BMW F30 335i M-Sport and it should look great. I will also run them on a darker Interlagos Blue E9X M3. We are hoping IND can custom paint the roundels to replace the white with black or a dark blue. That will look great on all BMW exterior paint colors, even dark blue. For easy one/off I will try to scrap off the adhesive on the rear 74mm trunk roundel and just use the 2 pins to attach it. Then you have to find a match to your wheel finish for the wheel center caps. Cheers |
shaneguags1192.50 |
08-03-2022, 10:59 PM | #82 | ||
Rep 1,244
DanG10664.50 |
08-04-2022, 05:20 AM | #83 |
7494
Rep 12,310
This picture might have sold me on these roundels, thanks for that! Looks really nice
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-04-2022, 11:38 AM | #84 |
Rep 754
Three things to consider:
- IND might make available custom painted 50th Anniversary roundels so you can replace the white with black or dark blue. So wait on that. - For Custom blacked out roundels IND has a blacked out carbon fiber roundel with matching floating wheel center caps - You can run the OEM 50th Anniversary Roundels and do something custom for the wheel center caps (IND), if the wheel finish is black or gunmetal. The M2 roundels use an adhesive, so it is not so easy to swap them out regularly. But you can use 3D double-stick tape. A Mod is a Mod. +5 HP Cheers |
DanG10664.50 shaneguags1192.50 |
08-04-2022, 03:16 PM | #85 | |
Rep 1,244
08-13-2022, 10:45 AM | #86 |
Rep 754
Anyone receive a mystery pack of 50th Anniversary Roundels yet from BMW Parts Pros? Please add your PNs in the post.
Waiting for my backordered 50th Anniversary Classic ///M Roundels kit.... Cheers |
09-02-2022, 12:49 PM | #87 |
Rep 123
Drives: 2021 BMW M2 Competition
Garage List 2018 BMW X5 35d [0.00]
1970 BMW 2002 [0.00] 1991 BMW M5 [0.00] 2005 BMW 330 ZHP [0.00] 2021 BMW M2 Competi ... [0.00] |
Ordered Yesterday!
Thanks to everyone here for the great information and part numbers. I called my local dealership, BMW of Lincoln to check on pricing and availability for the front and rear 50th Anniversary Roundels. They checked the inventory in Germany and there are many in stock so they ordered them for me. Delivery is to be in 2 weeks, no more than 3 weeks.
Here is what I ordered using part numbers provided here. Front 82mm - 51-14-8-087-189 - $40.12 Rear 74mm - 51-11-7-886-545 - $39.78 You can call Ryan at 402-479-7591 and he will help you. If you want to order them online you can visit their Webstore for OE BMW and Mercedes Benz parts at www.bmwdirectparts.com **This BMW center has won the BMW CCA top Regional Dealership award several times and offers a cost plus 10% discount on most all parts. These Roundels show as 20.40% off list. They will ship and match/beat any OE BMW dealer price. I'm not affiliated other than I buy a lot of parts, and some cars, from them. |
DanG10664.50 No_curebimmer637.50 |
09-02-2022, 06:11 PM | #88 |
Rep 754
Delivery times on these 50th Anniversary Roundels are unusually long. It's like they put them on that auto transport ship full of gorgeous Porsches that sank in the Atlantic.
ECS Tuning has some PNs, but shipping is $50 for a $50 roundel. BMW Parts Pros shipping delay from Germany is 4 weeks plus. Paddleshifterz DHL + US Postal Service shipping is 2 weeks. IND has most kits in stock and will ship the fastest. Labor Day Sale!! Bonus Ceramic Coating Option. My Paddleshifterz order shipped in 3 days and then nothing for a week. Parcel just showed up at LAX in Customs 8 days later. OktoberFest must be starting earlier each year. BMW Parts Pros backordered from Germany for a month. It is 107F in LA this weekend, so pulling off the adhesive won't require must finesse. 50th Anniversary wheel center caps and steering wheel emblem (Amazon/eBay) are lonely. Cheers |
DanG10664.50 |
