M2 Technical Topics > Cosmetic Modifications > M4 seats swapped into my M2
      01-25-2023, 09:18 AM   #89
macRS
Drives: BMW M2 lci
Originally Posted by Drifter2090 View Post
Got my comp seats installed! Thanks for all the good info here, it made it very easy.
Are these in an OG M2?
      01-25-2023, 09:20 AM   #90
Drifter2090
Drifter2090's Avatar
910
Drives: E90 M3 | E92 335i | E90 335d
Yes in my 2017 OG m2
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD
JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD
SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD
AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD
      02-15-2023, 11:21 PM   #91
MotoGear TV
Drives: F87 M2 & E90 M3
How did you get the badges to light up?
      02-16-2023, 06:34 AM   #92
Drifter2090
910
I followed this post, was super easy.
Did you find some seats for a video?
This post
      02-16-2023, 03:41 PM   #93
tharaka
Drives: X3 M40i
I put heated M2C seats into my OG M2 and somehow lost seat heating
      02-22-2023, 10:50 PM   #94
MotoGear TV
This post
Quite possibly lol, just trying to do all the research ahead of time
      02-23-2023, 05:33 AM   #95
Drifter2090
910
Did you swap over the grey modules?
      02-28-2023, 08:11 AM   #96
zcp
zcp's Avatar
297
Drives: 04 M3, 23 Ariya, 23 Pro-4X
Selling mine if anyone is interested!
Located in VT.
https://f87.bimmerpost.com/forums/sh...1#post29881821
      03-02-2023, 05:57 PM   #97
SM2
SM2's Avatar
Drives: 2015 Audi S6 | 2017 BMW M2 | 2
I was hoping the m4 rear side pieces would work looks like I’ll need to use the original part? 🙄
      03-08-2023, 01:43 PM   #98
Sebass
Sebass's Avatar
Drives: 2017 BMW M2
2017 BMW M2  [0.00]
bump
      03-08-2023, 07:36 PM   #99
M2OG
Drives: a car
Question for those who have done this swap. I want to reupholster the entire seat so with that in mind I'm looking for damaged seats to save some cash. What I'm finding are some with bend seat rails. Should that be a concern? Or can I swap the rails from my existing seats? Thanks in advance!
      03-08-2023, 10:57 PM   #100
OGM2
Drives: F87 M2 AW DCT MPS,N180 4Runner
This guy swapped his original rails onto M4 seats.
M2OG400.00
      03-10-2023, 07:35 PM   #101
SM2
SM2's Avatar
Did you use the M2 rear side pieces underneath the seat belt?
      03-11-2023, 02:34 AM   #102
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
Yes you re-use original ones as M4 do not fit
SM2733.00
      03-19-2023, 08:21 AM   #103
SM2
SM2's Avatar
Originally Posted by MikeF87LCI View Post
Managed to get the install completed this week. Thanks to everyone that contributed
Have now swapped the M4 logo for the correct m2 M2 ones 👍
Tap into the main connector going into the Junction box(JBE)?
      03-24-2023, 07:46 PM   #104
SM2
SM2's Avatar
Working on re-stitching some parts.
Relicate
TEX210
1394 & 8842 leaning towards switching to 8842.
      03-31-2023, 08:46 AM   #105
Jack@AUTOID
Jack@AUTOID's Avatar
1773
Drives: G87 M2, G42 M240i, F87 M2, E36
So you need to add an extra pin into the yellow connector that plugs into the bottom of the seat.
This is pin 7, you'll see a terminal in that location for the seat side but obviously not on the vehicle wiring harness.
The part for the terminal is 61130005197, crimp one of these on to a good length of wire. The wire can then be routed to follow the oem wiring harness. I did this while the seats were still out. Removed the plastic trims at the edge of the carpet, ran the wire up the edge of the car to the footwell.
Removed the lower trim panel under the dash and utilised the feed for the footwell lamp. So the footwell light has 4 wires, one earth brown or brown with a trace. Two others that are mainly white with either red or blue trace (these feed ambient light either white or the orange) and then the final wire is red or red with a trace (sorry can't remember exactly) forgot pics also. This one you can tap into for your seat illumination.
Tidy up wiring, secure in place with zip ties if needed and re fit panels. Then repeat for the other side.
So now the seat light works at the same time as the footwell light. So when a door is opened or the main full interior lights are on.
This is not quite the factory method as this would be wired into the FEM control unit.
But my method I found fairly straight forward as I could keep them separate on each side as the other way would need both wires running to one control unit.
I would recommend doing this with the battery disconnected and the seat out. Any more info give me a shout.
Hey bud, plan on doing this to mine but I have manual OG seats at the moment. Did you go from electric to electric or from manual?
Currently Driving: '23 G87 M2, '22 BMW M240i xDrive, '18 F87 M2, '98 E36 318is
@AUTOID | WWW.AUTOID.CO | SALES@AUTOID.CO
      04-03-2023, 12:03 AM   #106
MikeF87LCI
MikeF87LCI's Avatar
Drives: BMW F87 M2C
I went from electric to electric, so not sure what’s involved completely installing electric from scratch
      04-07-2023, 09:25 AM   #107
bmwstephen
Drives: 95' M3, 17' M2
It is a matter of transfer the cushion and upholstery to your manual seat frame then. that would be a lot easier to do.
      04-09-2023, 07:58 AM   #108
SM2
SM2's Avatar
Switching the blue stitching getting closer to finishing the driver side.
      04-11-2023, 03:58 PM   #109
SAinSurrey
Thanks all for all the fantastic information. Finally got the seats fitted and loving them. Always wanted a lighter interior to contrast with my mineral grey exterior.
Rear lower seat cushion is a bit of effort to install as said on other threads and needed some serious strength to get the outer sides to clip in.
Kattanah137.50
      04-13-2023, 12:32 PM   #110
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
Made a DIY on how to do the seat emblem lighting wiring for anyone needing help!
https://f87.bimmerpost.com/forums/sh....php?t=2008606
