06-18-2018, 04:12 AM | #1 |
Rep 128
M Mirrors
I know there are other threads with this subject. But since, if I understand correctly the M2 Comp mirrors won't fit "Old" M2 I want the best looking third party carbon M Mirror covers. Can you give some advice? And pictures please.
Current: M Roadster Silver/Black (Fun car), BMW 330ti Compact (Trackday), Mercedes C220d AMG Estate (Everyday)
Previous: BMW M2 DCT M Performance Suspension/Stage2, Porsche 993 Carrera 2S, Porsche 993 Carrera 2, Porsche 964 Carrera 2 Cab,Mazda RX8, Porsche 930 Turbo, BMW M3 E36, BMW M3 E30, BMW M5 E34, BMW 325iM Coupe |
06-18-2018, 07:01 AM | #2 |
Rep 471
wait for the M2 C. is the same car are the are OEM M mirrors \ guess we can just buy the cover part only
http://f87.bimmerpost.com/forums/sho...g=1277&slide=6 Last edited by AGM2; 06-18-2018 at 07:04 AM.. Reason: pic update |
06-18-2018, 10:13 AM | #3 | |
Rep 6,939
Drives: 2018 M2 AW DCT
06-19-2018, 02:17 AM | #4 | |
Rep 128
I read that those are the same as M3/M4 and does not fit M2 org?
AGM2297.50 |
06-19-2018, 08:18 AM | #5 | ||
Rep 471
06-19-2018, 09:20 AM | #6 | |
Rep 1,339
Mirror covers will be also different and will not fit the cover as plug and play. If you want the M2C side mirror, you will have to buy the entire side mirror set and retrofit them. |
06-19-2018, 10:07 AM | #7 | |
Rep 471
06-19-2018, 05:44 PM | #8 |
Rep 2,577
It needs more than cover to fit M2C mirror to M2 original. But it's still a bolt on replacement. Way easier than fitting M3/4 mirrors which we've done many, where you have to fabricate the mounting parts.
Lemania 2320
06-20-2018, 02:34 AM | #9 |
Rep 128
Do I understand correct?
M2c mirrors does have the correct size and do fit, but mountings is different?
06-20-2018, 08:13 AM | #10 | |
Rep 1,339
As SeanWRT mentioned, F8X M3/M4 mirror will require some fabrication in order to fit the side mirror to M2. However, M2C side mirrors are pretty much plug and play. Just have to remove the interior door panel to disconnect and remove wires to pull the stock one out, then you can fit M2C side mirrors. No need of fabrication. Mounting is the same, just the shape of the mirror shell is different from current M2. |
06-20-2018, 09:06 AM | #11 | |
Rep 128
You mean I have to change complete housing including?
I was aiming at change only cover with "ears". Quote:
06-20-2018, 09:14 AM | #12 | |
Rep 1,339
If you just wish to change the cover that fits M2, you would have to find a aftermarket cover like Autoid/ AutoTecknic, etc. |
WedgeSalad280.50 |
06-20-2018, 10:00 AM | #14 | |
Rep 128
Thanks, that clarifies all.
Unfortunately, complete mirrors w housing cost about 800€ each Quote:
06-20-2018, 01:03 PM | #15 |
Rep 757
I've had the misfortune of having to replace a standard M2 mirror and it comes in three (3) parts, the body, the back cover, and the mirror itself. I've not checked RealOEM but do we have the mirror part numbers from the M2C?
With only a few of them on the street just yet, I'm wondering about parts availability?
'17 M2 DCT Long Beach Blue
06-21-2018, 09:05 PM | #17 |
Rep 6,939
06-24-2018, 05:40 AM | #19 |
Rep 4,203
I just ordered the painted to match Chinese units.... thought they might be slightly less obvious on my MG and technically that is the way the M's come
06-24-2018, 09:27 AM | #20 |
Rep 1,899
06-24-2018, 02:11 PM | #21 |
Rep 4,203
nioh_lbbm21716.50 |
06-24-2018, 02:14 PM | #22 | |
Rep 1,899
