M2 Technical Topics > Cosmetic Modifications > LED Bulb swap for NON-LCI Tails
      06-30-2018, 12:08 AM   #67
425M2
Drives: 2017 BMW M2 - Mineral Gray
2017 BMW M2  [0.00]
Great thread, thank you. Ordered the LED lights off Amazon. Looking forward to installing them!
Update: Installed! Super easy to do, inexpensive, and look great! My kind of mod. Thanks again ChrisK!
ChrisK4449.00
      11-03-2019, 04:03 AM   #68
lamh
Drives: 2017 M2 BSM 6MT
Originally Posted by andrewc89 View Post
I own these and they work great:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Don't think they require any coding to work. I coded them in anyway just to avoid hyperflash and error messages.
Has anyone tried the BA15S of the same brand (Tuincyn) for the tails?
https://www.amazon.ca/dp/B0725VQZS3/..._zvQVDbV0VS6C0
I'm in Canada and they're easier to get so wondering if anyone has had any luck with them, with or without coding.
      11-03-2019, 09:23 AM   #69
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
No, but I've had the P21W's as front indicators in both my M2 and my 328 for over a year now and have had 0 issues. For $20 I would just give them a try and see. If the front indicators are solid quality I don't see why the same brand wouldn't make a good tail light bulb.
      11-05-2019, 04:19 PM   #70
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Which P21W did you use for your fronts? It looks like there are 2 variations of Amber/yellow in the amazon listing - 1156BA and 1156BAU:
https://www.amazon.com/TUINCYN-Repla...ve&sr=1-2&th=1
      11-13-2019, 12:06 PM   #71
tenkies
Drives: 2017 M2 LBB 6MT
You want the 1156BAU. The posts on the stock bulb are not 180 across from each other. They are offset at 150
mssVT98141.50
      11-13-2019, 01:47 PM   #72
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Thanks! I guessed correctly.
      11-18-2019, 05:58 PM   #73
tenkies
Glad you got the right ones. Not to make things confusing but the rear tail bulbs are not the same a the fronts. I'm pretty sure the prongs are 180 version if you're looking to change those. Also make sure to change the bulb type to LED if you have bimmercode
      11-19-2019, 05:36 AM   #74
3t3p
New Zealand
455
my rear lights are pretty dim when reversing, I usually upgrade my cars to LED just for more light when reversing in the dark.
Is this easy to achieve/get to the rear light cluster?
      11-19-2019, 12:47 PM   #75
tenkies
It's not that bad. You could probably replace them in 30 min.
      11-19-2019, 01:59 PM   #76
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Yeah, for the tails I just got the ones listed by the OP of this thread, and then the 1156BAU for the fronts. Swapped everything, coded it to LED, all good. Hardest part was probably getting the back of the taillight off, since some of the clips were a little finicky and I didn't want to break any of them.
      11-19-2019, 02:02 PM   #77
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Yeah, getting the light cluster out was easy - just remove the two nuts, wiggle a bit to loosen it, then pull it straight out. Like I said above, the hardest part was probably getting the back of the taillight off, since some of the clips were a little finicky and I didn't want to break any of them. Ultimately I probably didn't need to worry - they don't have to move very far to unclip. I didn't even pull the wiring harness off, just swapped the bulbs and put everything back in.
      11-23-2019, 10:15 PM   #78
lamh
thanks. I went ahead with replacing both fronts and tails and looks great. is coding necessary if I'm not getting any errors or hyperflashing or anything?
      12-12-2019, 09:41 AM   #79
MZWIE
The issue with this is the cost. Each LED is $20.
      03-01-2020, 07:20 PM   #80
heimbo
Drives: m2
Just did the bulb upgrade and coded via bimmercode, but still getting a brake light malfunction for both sides. All lights seem to be working just fine. Any suggestions are appreciated.
      03-01-2020, 07:59 PM   #81
AndrewC1989
The lights will work regardless of coding, the coding is just for the bulb errors. I would recode everything you changed in the tail light back to bulb and then back to LED to see if that fixes it.
      03-01-2020, 09:05 PM   #82
heimbo
Drives: m2
I tried your suggestion and still getting the error. I ended up buying a set from Sirius that says it has "built in resistors" because the others were out of stock. I wonder if that could be causing this issue.
      03-01-2020, 09:15 PM   #83
AndrewC1989
Definitely could be. I would try a different set.
      03-02-2020, 12:08 PM   #84
AlpsRider
AlpsRider's Avatar
2865
I'm not trying to be a salesman but I have 2 sets of LEDs from my M235i. I spent quite a bit of time selecting the best ones. I'd be happy to pass them on for a minimal price. They are just sitting in my garage in baggies.
      03-05-2020, 10:44 PM   #85
heimbo
Drives: m2
I switched to a different set by sirius and so far so good. For others, don't bother with their "anti-hyper flash" version as it's more expensive and was throwing a MIL even with proper coding.
AndrewC198910931.00
      03-07-2020, 07:44 AM   #86
McGary911
McGary911's Avatar
Drives: 2017 LBB M2 DCT
I went with the Sirius ones out of the gate back in 2017 and they've been perfect ever since. Super bright too. When I tap the brakes on a dark road I can see everything light up behind me.
2017 LBB ///M2 DCT
2013 Porsche Boxster S
      04-14-2020, 12:53 PM   #87
Joaco135
Joaco135's Avatar
Drives: 2020 M2C LBB
Still have this sets? Very interested..
      08-02-2020, 04:42 PM   #88
asciimike
Drives: 2017 M2
2017 M2  [0.00]
Looks like Sirius no longer makes the LEDs in the link provided, and we're stuck with a choice: white + lenses (CK/EK series: https://www.siriusledlights.com/coll...ght-1156-white) or red + no lenses (KG series: https://www.siriusledlights.com/coll...light-1156-red).
What have people who have done this mod recently been using? The picture in OPs first post has me a bit scared to try the KG bulbs (no lenses), since it seems to be too diffuse and light up the interior.
The Tuincyn ones recommended wouldn't be here until sometime in October, so looking for something a little faster...
