07-18-2018, 07:30 AM | #23 | |
Rep 3,699
I was able to drop 20mm in the rear and 15mm in the front (rear rake track setup) without comfort impact. Handling is much better. Much less dive, squat, and roll, and I can still attack the curbs on track. Last edited by ZM2; 07-18-2018 at 07:42 AM.. |
QM287.00 |
07-18-2018, 12:55 PM | #24 | |
Rep 11
07-18-2018, 01:11 PM | #25 | |
Rep 3,699
This won’t be a popular opinion here: a lot of guys like to run stiff setups on track, but suspension setup is always a compromise. Stiffer helps in some corners, but hurts in others, plus you lose time by not being able to use the curbs as much. You also spend a bunch of time fiddling with damper and bar settings, and thinking about spring rates, when you should be focused on where your driving sucks on track and could be better. I use my M2 for a fun track day car and to learn new tracks. I hop in the race car when it’s time to get serious and start playing with suspension setup on track. |
07-18-2018, 01:53 PM | #26 |
Rep 11
@ZM2 appreciate your feedback, I know stiffer is not always = better performance wise, I would consider Dinan coilovers as an upgrade to stock as long as it generally benefits performance of the suspension while driving close to the limits, from my experience with E46 M3, most of the coilovers will sacrifice comfort while shorted springs + stock shocks will sacrifice performance, for instance one the favorite choises for well rounded setup among e46 community was a combo of Koni/Bilstein shocks and Dinan springs
ZM22821.00 |
07-18-2018, 06:25 PM | #27 |
Rep 312
Just installed Dinan HAS today. Can't speak for the track but initial impression on the street is that there so far appears to be no degradation in comfort. Instead, I would agree with ZM2 that this setup actually makes the car more compliant and more comfortable at least over small and medium bumps. There is generally less bounciness. Definitely less body roll in tight corners. I'm lowered 1" front and 3/4" rear on stock 19's.
07-24-2018, 04:10 PM | #28 |
Rep 199
I am running the Ohlins with 80 N/mm front and 160 N/mm rear and at 20 clicks it is still more firm than stock....but really super planted and no more bounce over larger road undulations....awesome. On the track I ran them at 3 clicks all the way around...again awesome.
If you want softer than stock you may need to go 70/140 which is about as soft as Ohlins recommends given the valving.
07-25-2018, 07:30 AM | #29 |
Rep 583
07-25-2018, 09:20 AM | #30 |
Rep 2,515
The Dinan coilover conversion is magical
07-26-2018, 07:52 AM | #31 |
Rep 312
Did your front height settle at all after the install? I'm supposed to be lowered 1" upfront but still seems like it should be a bit lower. I'm wondering whether I should expect it to settle or whether it's not actually at 1". It's only been a bit over week.
07-26-2018, 11:13 AM | #32 | |
382
Rep 731
07-26-2018, 11:44 AM | #33 | |
Rep 3,699
chief1richard382.00 |
07-26-2018, 04:00 PM | #34 | |
Rep 2,515
QM287.00 |
07-27-2018, 03:11 PM | #35 |
Rep 415
I run the Bilstein PSS10’s on mine. I like that compression and rebound are both adjusted with one adjustment knob opposed to 2 separate ones like the KW V3’s I ran on my last car. From another memeber I believe the spring rates are around 500 F and 800 R on the Bilstein.
Both are great coilovers and can get you where you need comfort wise. I’ve found on both that the car is technically firmer however due to the better matched damper/spring they work much better together and offer better compliance which in turn gives a certain amount of comfort. |
JTO245276.00 |
