02-26-2019, 10:25 AM | #1 |
Rep 877
Drives: OG M2
Which valve controller for MPE?
MPE is having the stupid valve controller issues; other than that I'm happy with the exhaust so I'm looking for an aftermarket controller. Which controller do y'all recommend? CG Precision v1 or v2?
02-26-2019, 04:19 PM | #2 |
Rep 775
This might be completely inaccurate for yourself but I struggled for weeks thinking my controller was 'broken', it turned out I was using it 'wrong'. Basically, I was double clicking the button as you would double click a mouse. Turns out you have to double press the button in slow succession... I.e... press for half a second, wait 1 full second, press for half a second again. See if this solves your issue
02-27-2019, 01:40 AM | #3 |
BMW Fanatic
331
Rep 1,076
Still a shitty system regardless of how you use it. Will never understand what BMW was thinking with the bluetooth module.
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
EvokeIns3.00 |
02-27-2019, 05:52 PM | #4 |
Rep 1,094
I looked into it as the BT system truly annoys me.
CGP V1 won't work, it's for a single valve and it won't control the M type actuators (OEM M2 uses single non-M actuator, MPE uses two M type ones. They look identical but are not interchangeable) CGP V2 might work except for the "auto" mode where the valves would be controlled by DME. Someone inquired with CG and they said M2 is not supported. I thought about controlling the valves from the DME by the drive mode switch but that way I would lose some config options (for example Sport+ mode with quiet exhaust). So at the moment what I'm looking at is either hacking the BT module in the trunk and adding a hardwired button to the center console or doing something creative with the BT remote. |
02-28-2019, 02:49 PM | #5 |
Rep 6,961
Drives: 2018 M2 AW DCT
I on’t understand the problem. My Bluetooth controller works 100% of the time. I have it handy in the ashtray mount.
02-28-2019, 11:27 PM | #6 |
Rep 877
Drives: OG M2
03-02-2019, 07:13 PM | #7 |
Chuggin' Along
333
Rep 588
03-07-2019, 04:35 PM | #8 | |
Rep 1
They were nice enough to leave the manual for the controller & Exhaust in the glove box as a teaser though. |
03-08-2019, 10:50 AM | #10 |
Rep 877
Drives: OG M2
03-22-2019, 05:11 PM | #11 | ||
Chuggin' Along
333
Rep 588
https://photos.app.goo.gl/p9pP4bQA96A6rvPVA The harness is what is needed to hook up the MPE to the trunk connectors and modules in the trunk: https://www.realoem.com/bmw/enUS/partxref?q=18302414898 |
10-15-2021, 11:53 AM | #13 | |
Rep 54
10-24-2021, 09:41 PM | #14 |
Rep 41
Drives: M2 M Performance Edition - 6mt
The batteries in my MPE valve controller finally weakened (after about 4 years) which caused the controller to only work intermittantly. After replacing them, it works fine.
I can also double click it fairly quickly. And I did remove the cigarette lighter and simply made the hole slightly bigger to fit the controller unit. Works great and looks great! |
03-21-2022, 03:09 PM | #15 |
Rep 14
Has anyone confirmed whether the VSC works with MPE?
Also: Is CG Precision still in business? Their website has zero contact info. I found this old post but the phone number doesn't work: https://f80.bimmerpost.com/forums/sh....php?t=1548379 |
03-31-2022, 07:59 PM | #16 |
Rep 17
I have found a solution to the finicky Bluetooth controller that can work like the CG Precision or can be wired into the cabin to use a toggle switch or a fancy billet button.
Hope this helps. https://f87.bimmerpost.com/forums/sh...5&postcount=64 Mark Last edited by Mped; 03-31-2022 at 08:37 PM.. |
03-31-2022, 08:32 PM | #17 | |
Rep 14
03-31-2022, 08:38 PM | #18 |
Rep 17
I think I've fixed it now.
https://f87.bimmerpost.com/forums/sh...5&postcount=64 |
04-14-2022, 01:26 PM | #19 | |
Rep 54
04-05-2024, 09:29 PM | #20 | |
Rep 1,944
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS Last edited by Damage Inc; 04-07-2024 at 11:46 PM.. Reason: a |
