BMW M2 Forum > BMW M2 Discussions > List your good, inexpensive mods
      10-19-2016, 10:13 AM   #89
Glounk
Glounk's Avatar
Qatar
115
Drives: M2 6mt MG
Originally Posted by ClothSeats View Post
What did you do with the door seals?
http://f87.bimmerpost.com/forums/sho....php?t=1265176
      10-19-2016, 10:16 AM   #90
Lincoln30
Lincoln30's Avatar
Drives: 2017 BMW M2
2017 BMW M2  [0.00]
The door seals cut down on some of road noise that gets in the cabin from front tire area. It's 228i part that fits in the open space between the inside of the fender and door frame in front of the door hinges.
2016 750i X-drive
2017 GMC Sierra Denali
1997 MB SL500, 19"AMG replicas
Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2
      10-21-2016, 01:15 AM   #91
winterrogue_F87
Queen of Motorsports
winterrogue_F87's Avatar
Drives: BMW 2016 M2
2016 BMW M2  [0.00]
2015 BMW 228xi  [0.00]
Brake cover for about $25. You can get anything you want. I just got another one that says Rogue.
Instagram @winterrogue_F87
Tai Winter Targaryen
Appreciate 4
      10-21-2016, 07:32 AM   #92
ChrisK
ChrisK's Avatar
Drives: '19 M2C
Originally Posted by pup73 View Post
BMS clutch stop $10
ASD bypass module ~$55
Knockoff CF mirror caps $60
LED turn signal bulbs $25
Coding!
Which turn signal bulbs did you buy? Any video of what they look like?
www.ReTuneTheDeTune.com
      10-21-2016, 09:52 AM   #93
Chuck W.
Chuck W.'s Avatar
354
Drives: '95 Porsche 993 Cab
I also posted this in another section of this board.... but it fits well here too;
To hard wire your radar detector or dash cam you can easily and inexpensively tap into the mirror housing.
I have a dash cam in both our 2012 535I and 2016 M2 and also hard wired a V1 radar detector in the 535 mounted with a Blendmount. On the 535I I tapped into the mirror for power on one and the overhead console for the power on the other. The mirror is much much easier.
I used shawnsheridan posting on another forum to install the F10s. When I opened the rear view mirror's housing on the M2 (very easy) I found the same the 10-Wire Connector Plug inside it. The +12V (Switched off the ignition) on the Brown/Green wire and Ground on the Brown/Black wire.
I used the wire taps and fed the wire at the top of the mirror housing. Good to go.
2022 X5 40I - Ours
2016 BMW M2 LBB 6 Sp / ED Pick Up on 07/12/2016 - Her's
1995 Porsche 993 Cab - Mine
2001 Toyota Tundra SR5 Ext Cab - Hay Hauler
Appreciate 5
      10-22-2016, 01:57 AM   #94
Smiley1175
Smiley1175's Avatar
281
Where did you get the cover from?
      10-22-2016, 03:35 AM   #95
winterrogue_F87
Drives: BMW 2016 M2
2016 BMW M2  [0.00]
http://www.i-cbl.com
      10-24-2016, 03:20 PM   #96
TheAdamKramer
Post M2 Charity Giveaway
We're doing a BMW M2 giveaway for charity, and thought you guys might be interested? You can see more about the giveaway here – http://crowdrise.com/bmwm2
It was hand painted by street artist Greg Mike, and it is such a beauty – holy crap!
luvmybmmr305.00
toastie213.50
AlexCirci496.50
      11-07-2016, 06:20 AM   #97
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
This thread appears to have lost steam when everyone witnessed the unholy thing done to that poor AW in the name of charity... Try to get past that and keep the light mods/hacks coming. This has been one of my favorite threads to follow, I have already ordered many of these bits for my MG one month away.
Can't wait!!
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
      11-07-2016, 08:53 AM   #98
shemeld_135
shemeld_135's Avatar
Drives: 2020 SO - M2C
2020 BMW M2C  [0.00]
2016 BMW M2  [10.00]
Just got theses 4 bucks shipped lol
https://m.aliexpress.com/item/32712048698.html
      08-29-2018, 08:49 PM   #99
GregoryK
GregoryK's Avatar
503
Drives: M2 '18
Old Tread....but never too late.
$15/ rattle can of LLB and Clear. Sanded and sprayed the front reflectors. Used a roll of 3M automotive butyl to stick them back in.
Looks just like an IND bought one but cost $130 less.... and was way more satisfying!
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
Appreciate 9
QM287.00
akkando5863.00
$M271.50
mssVT98141.50
bollinm25.00
gphung193.50
Kankles1484.50
      08-29-2018, 11:26 PM   #100
babym2
Drives: 18 M2 6MT
the BMS clutch stop is not good for clutch, your clutch is not fully disengaged when using, there are some reports of it ruining peoples cars if you search google
      08-30-2018, 02:34 AM   #101
ratedrkstevo
I so need this!!!
      08-30-2018, 07:04 AM   #102
LGWGN
Drives: 2001 M Roadster, '24 BSM M2
If this is true, I'd like to see the reports!
I've been driving with this for nearly 2 years and haven't had any issues. Clutch feels completely disengaged to me.
'01 M Roadster, '24 BSM M2
      08-30-2018, 08:49 AM   #103
Fear-Mongrel
Fear-Mongrel's Avatar
Drives: 2018 M2 LCI 6MT LBB
I haven't installed it, but plan to and I'd like to see those same reports. I ran three different Google searches, "BMS clutch stop problems", "BMS clutch stop ruined car" and "BMS clutch stop ruined clutch" and I found absolutely nothing, not even a single negative article or forum post. If there are reasons not to install this, I'd appreciate seeing whatever info people are looking at because everything I'm seeing is positive.
      08-30-2018, 10:23 AM   #104
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
This looks great, nice work. Do you mind expanding on your process? I.e. where you got the paint, adhesive, etc., and what grit sandpaper you used? Thinking about doing this myself.
Thanks!
      08-30-2018, 04:26 PM   #105
GregoryK
GregoryK's Avatar
503
Drives: M2 '18
Thanks!
Totally. The hardest part is removing the reflectors. For that follow the IND video.
Once off:
Cleaned the butyl off the car and the reflectors. Used lighter fluid and a scraper.
Sanded the reflector top and sides with 180 grit sandpaper. This included sanding off the raised graphic on the reflector.
Masked the non reflective area as I used the 3m "butyl on that later. See my pics.
Sprayed 2 costs of plastic "adhesive enhancer", make sure you hit the sides of the reflectors.
Sanded with 1000 grit.
Spayed 2 coats of sanding primer (this step is not required some say)
Lightly sand with wet 1000 grit. washed and dried with a hair dryer.
3 Coats of car body color. Wet 1000 before last coat.
3 coats of clear. Sand between required. I didn't.
Apply the 3M 1/32 thick butyl product and trim then stick back on the car.
As the clear coat will be soft for a few days watch for finger prints while install the adhesive material.
All the above can be bought from any online or local automotive paint supplier. Amazon sell kits but they are expensive compared to local guys.
Moulding tape:
https://www.3m.com/3M/en_US/company-...3241071&rt=rud
Hope this helps!
      09-02-2018, 10:38 PM   #106
crispy tofu
crispy tofu's Avatar
15
Where did you get the spray paint? I've been looking for that
dtmurf480.00
      09-02-2018, 11:39 PM   #107
joec1101
BMW Fanaddict
65
Drives: '18 F87 ///M2
Same here - I plan to install this as well, but would like to see any "negative" reports/reviews if they exist. The BMS unit comes with 3 shims; I believe you can remove one or more to get more travel, so it (theoretically) shouldn't be a problem...
      09-03-2018, 12:13 AM   #108
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
Cheap replica of the CF M Performance spoiler and difuser.
      09-03-2018, 11:49 AM   #109
Fear-Mongrel
I found this thread currently running here on the forum, this was helpful though not definitive...
https://f87.bimmerpost.com/forums/sh...1260588&page=8
      09-05-2018, 01:34 PM   #110
dtmurf
dtmurf's Avatar
480
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
Me too, thanks for the info!
'17 M2 DCT Long Beach Blue
