04-10-2022, 11:04 AM | #1 |
Rep 38
DCT Oil Change
When did you change the transmission fluid in your DCT m2?
BMW states "lifetime". Keeping this car for a long time and a fluid change seems cheap in the long run compared to fitting a new gearbox in the future. Currently 48000km on the clock. Dealer states around 1000€ for labor fluid, filters and new tray. Seems reasonable. |
04-10-2022, 11:25 AM | #2 |
Rep 3,712
This is a great video to get familiar with all the parts needed and the process. F87source posted this for me in a different thread b/c my shop is doing this job for me this coming week, very helpful.
I'm doing the fluid (replacing with Redline DCTF), both filters, and the pump bc all those parts are cheap. Also, going back with the Fall Line DCT pan bc I track my car (another F87source recommendation): https://www.turnermotorsport.com/p-5...m-dct-oil-pan/ If you haven't or don't plan to track your car a bunch, the pump and Fall Line pan aren't needed. My car has 40k miles and ~70 track days, so it was time! |
04-10-2022, 11:26 AM | #3 | |
Rep 38
04-10-2022, 03:26 PM | #5 | |
Rep 7,508
For track is even say half that.
04-10-2022, 06:27 PM | #6 |
Rep 7,508
I just noticed this after rereading the post, but if you use redline DCTF (very solid fluid imo, and I will be going to this fluid personally in my next transmission fluid change) I would keep intervals really really low. Because it is an ester heavy oil and esters oxidize rapidly so it is not a good fluid for long term use. So 50k km for street use or ~4 years tops maybe even less (and UOA will confirm) whatever comes first, and for the track 25k km or maybe 2 years whatever comes first (it is best to get a UOA to confirm everything is ok). But oil is cheap, dct's aren't so it is best to replace fluids regularly as preventative maintaineance.
04-11-2022, 01:41 PM | #8 |
Rep 80
I do DCT fluid and filters every year. However, I primarily track the car, so the intervals will always be shorter. I don't think it NEEDS to be done every year, but like many have stated in this thread, it's cheaper to maintain, than it is to replace!
$1000 does seem a bit high though.. Parts usually run me about 300-400, and it should only be about 2 hours in labor. FWIW, I replace with OE stuff from FCP and its never been an issue. Hope this helps! |
04-13-2022, 09:28 PM | #10 | |
Rep 350
In Canada I was around $1000CAD in parts for pan, drain plugs, fluids, lower filter and canister filter. I recently saw that RockAuto now appear to have a gasket that you can buy for the pan without requiring the replacement of the entire pan but I'd already purchased by that point (and also wasn't aware of the Turner version either . . . .). |
05-21-2022, 05:37 AM | #11 |
Rep 33
Does the oil for DCT have a "part number"? If so, can someone please write it down here? I want to make sure they don't put the wrong DCT oil in my car.
I assume it's this: 83 22 2 446 673 - https://www.hubauer-shop.de/en/advan...3&inc_subcat=1 Correct?
Disconnected.
05-21-2022, 07:37 AM | #12 |
847
Rep 1,962
ThatBlueM24.50 |
05-23-2022, 06:49 AM | #13 |
Rep 8,972
Interesting that VAG group used to say DSG was oil was "lifetime" but since masses of failures they now specify DSG oil and filters every 40k...
If I had DCT I'd change it 40K too. |
05-26-2022, 01:42 PM | #14 |
Rep 3,712
Something else to add to this, my DCT was overheating on the track (270F) and running ~240F on the street. You don’t get idrive warnings until 250-260F, so didn’t realize I had an issue until my most recent track outing.
We changed the pan, filters, pump, fluid, and all that stuff, but everything looked fine and great in my DCT and none of my lines were clogged. So, we changed the thermostat ($125) since it looked like in the temp logs it was never opening, and now everything is great and temps stay at 180F! |
F87source7328.50 |
05-26-2022, 01:59 PM | #15 | |
Rep 7,508
05-28-2022, 01:53 AM | #16 |
Rep 33
Can anyone link to any official BMW documentation for changing the oil + filters in the F87 DCT?
Specifically I need a PDF for pan bolts tightening sequence, and torque specs for all the bolts that get undone while changing oil. Examples of what I need: Pan bolt tightening pattern - need one for F87 DCT. I know it's probably the same, but I need the official docs for F87. If you scroll down to "PROCEDURES" part of this post: https://f10.m5post.com/forums/showpo...88&postcount=1 - you will find the torque specs. However I would like an official BMW spec sheet, for the F87 DCT P.S. Why are these things so damn difficult to find on the internet?
Disconnected.
05-28-2022, 02:54 AM | #17 | |
Rep 7,508
then you will need ista for the rest.
ThatBlueM24.50 |
05-28-2022, 06:18 AM | #18 | |
Rep 33
If yes I'll just get a 1 day subscription to get what I need.
Disconnected.
05-28-2022, 06:36 AM | #19 | |
Rep 7,508
ThatBlueM24.50 |
05-29-2022, 08:19 PM | #20 |
Rep 350
I don't have my laptop with ISTA with me now to grab or verify the screenshot again but I did have a look at it yesterday and from memory your example looks the same or very similar.
How do you intend to run the fill/level adjustment procedure? Wouldn't you want to use ISTA to run that process and you'd have access to the diagram then too? |
06-28-2022, 08:19 AM | #21 | |
Rep 129
Fluid coming out looked very clean and did not seem thinned. I did not drop the pan and/or replace the filters, just a fluid flush. The pan and filters seem to catch most of the clutch material. My rear diff fluid did not look that good. You MUST use ITSA to fill. I was able to drain ~3.3L by opening the drain on my M2 that hadn't been run for a day or so. Filling before the ISTA procedure, I was only able to fill ~<2L. When using ISTA, I was able to pump in another 1.5L-2L. I did notice a slight difference in shifting performance but I did CS Trans flash at the same time. I will likely be going back to stock and report back then. Changing my rear diff oil made a much bigger impact and subdued my concerns of my trans going bad. I bugged my local dealer about rear diff fluid multiple times 12K, 24K, 36K and it didn't look like it's ever been changed. Including the 2K initial service. |
swampfox941186.50 terrywang94.00 |
07-03-2022, 10:35 AM | #22 | ||
Rep 14
