BMW M2 Forum > Regional Forums > AUSTRALIA > MCS F80 (M2,M3,M4) 3-Way Coilovers
      03-11-2023, 05:10 PM   #1
MR RIZK
MR RIZK's Avatar
758
Drives: AW M2C
Don't miss out on a rare chance to get your hands on a lightly used set of MCS 3 WAY coilovers designed specifically for the F80 platform.
These top-of-the-line coilovers from Motion Control Suspension (MCS) outshine other alternatives like Moton, JRZ, and AST. What's more, the rear dampers come optioned with dry breaks/quick disconnects, a $1,000 additional cost, allowing you to route the rear canister to different locations without the need for extensive bodywork modifications. Additionally the rear has been optioned with the lower spring cups to invert the damper to allow easy rebound adjustment without jacking the car or removing wheels. This setup fits perfectly without requiring any body modifications.
These coilovers are currently installed on my M2C, but I can quickly remove them post deposit/sale. They're suitable for M2, M3, and M4 and can be provided with or without springs and camber plates. The rear configuration is optioned as a coilover, unlike the OEM divorced setup.
Do your research and don't miss out on this fantastic opportunity!
NOTE: Image in Ad is near identical to my setup besides missing the rear quick disconnects and spring type. Photos to come or reach out if you have any questions via pm.
Detailed information can be found here:
https://www.motioncontrolsuspension....s-guide/3-way/
https://www.motioncontrolsuspension.com/buyers-guide/
At a high-level the specs are:
  • 18 Clicks of High-Speed Compression Adjustment
  • 10 Clicks of Low-Speed Compression Adjustment
  • 18 Clicks of Rebound Adjustment
  • Gas Pressure of 100-275 psi
Setup has less than 10,000kms with supporting paperwork to substantiate this.
The setup costs over $15k depending on exchange rate and duties. Chasing $12.5k as essentially near new.
Inclusions:
  • Pair of Front 3W Dampers
  • Pair of Rear 3W Dampers
  • Rear Optioned with Dry Breaks + Lower Spring Cups
  • Pair of Front Step Bushes
  • Pair of Rear Upper Damper Mounts
  • Pair of Vorshlag Camber Plates
  • Swift Springs Front and Rear – 60mm
  • Swift Stainless and Delrin Thrust Sheets
  • Eibach Helper Springs Front and Rear
  • Spring Perch Adjustment Tool
