BMW M2 Forum > BMW M2 Discussions > M2 on U-Haul Trailer Tongue Weight?
      08-06-2020, 02:14 PM   #1
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Does anyone know offhand what the tongue/hitch weight is on an M2 loaded onto a U-Haul trailer? I'm trailering my M2 to a trackday next month behind an RV and planned on renting a U-Haul trailer. The RV is rated for up to 8000lbs towing, but I believe the hitch weight is only 500lbs. I want to make sure I'm not blowing this number out when hooking it up. Anyone have any idea?
Thanks.
      08-06-2020, 06:39 PM   #2
brandontrek
Drives: E46 M3, S54 E36/8 M Coupe, X5d
From experience with them, it will be a lot. The trailers are already front heavy for safe towing. You might have to back it onto the trailer due to the low front bumper.
      08-06-2020, 07:53 PM   #3
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I planned on putting some 2x8s on the front to raise the front tires up a bit. I'm pretty low though, on KW V3's and have a front lip. I may try to source another trailer.
Thanks for the info
Motorcity BMWCCA Member
Instagram | YouTube
      08-06-2020, 08:04 PM   #4
brandontrek
Thanks for the info
The approach angle isn't bad at all, it is these when you are trying to strap down the front wheels.
If you can, source a normal car trailer.
This was when i picked up a Speed3 project many years ago, look at how much of the car is past the wheels:
      08-06-2020, 08:31 PM   #5
Anthony1s
756
Drives: 2018 Mineral Grey M2
Can you back the car onto the trailer? Being a front-engine car, it would move the weight to the rear of the trailer.
Edit: Nvm. M2 doesn't have the big of a f/r weight distribution difference. Might not change anything.
      08-06-2020, 08:35 PM   #6
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Definitely do not back the car on the trailer. It will make the trailer tail happy and quite dangerous.
See this thread: https://www.bimmerpost.com/forums/sh...php?p=26434217
And...
      08-06-2020, 08:39 PM   #7
Daytona_550
Good visual on weight balance:
      08-06-2020, 09:35 PM   #8
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
And...
Did you happen to get a tongue weight with the M2 loaded? Looks like your hitch was good for up to 750lbs. Mine is only 500.
Ya, I wouldn't load it backwards, I know better than that.
Instagram | YouTube
      08-07-2020, 06:32 AM   #9
Daytona_550
Sorry, I did not, but IIRC, when you reserve the trailer on the U-Haul website, it will ask for details on the tow vehicle, hitch rating and about the vehicle being trailered. I believe they calculate what they need and tell you if you have a working combination. The website won't allow the reservation to proceed if, for example, the tow vehicle is not enough to pull the trailer/car. It's been a few months since I reserved mine but I think it also checks out your hitch rating.
      08-07-2020, 07:59 AM   #10
Anthony1s
756
Just to be clear, I was asking if loading it backwards was a good idea, not suggesting it. I don't know anything about towing, just had an idea.
I supposed the areodynamics of a backwards car aren't the best.
      08-07-2020, 08:14 AM   #11
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Yeah, it kinda does that, but it doesn't ask for any specs if you select that you're towing with an RV, which has me worried.
      08-07-2020, 02:05 PM   #12
DriverDaily
Drives: M2 Competition
I'd be more concerned about the weight distribution. I think the center of gravity needs to go between the trailer wheels and the hitch.
