BMW M2 Forum > BMW M2 Discussions > M2 Competition - Electric vs Manual Seats
      07-21-2020, 06:18 PM   #23
19x
19x's Avatar
Drives: 2021 M2C
Originally Posted by NathObeaN View Post
I think it's the cumulative affect. Yes, I wouldn't be able to tell the difference in weight purely when comparing seats, but a kg here and a kg there and it all adds up so if I can save on unnecessary weight (and it costs less), why not? For me however the biggest concern was height difference (I'm a tall guy). Appreciate the feedback though and certainly don't disagree with your point.
The cost saving and height concern make sense. For that, I just opted for a slicktop (no sunroof) in my prior M3's. In my experience, the most headroom can be gained by eliminating the sunroof. An extra 2 inches or so. Especially useful when I tracked and autocrossed with a helmet (for reference, I'm 6"1' or 185 cm). That extra few inches made a world of difference.
When it comes to weigh savings, the most important thing to consider is not how much weight is coming off, but where the weight is coming off from. If I had to choose between -50 lbs for no sunroof vs -100 lbs for lightened seats, I would choose no sunroof every time.
      07-21-2020, 06:25 PM   #24
chris719
Drives: '08 M Roadster
I've not found any evidence that the manual seats sit lower. Would be happy to be corrected, though.
      07-21-2020, 06:32 PM   #25
Moflow
Moflow's Avatar
Drives: 2020 M2C 6MT
Even though I have a sunroof, I’m inclined to agree. You have to remove a lot of weight before it becomes obvious imho. WHERE the weight is located is much more important, whether you’re lowering the center of gravity, changing the weight distribution or even just shifting the polar moment of inertia. Those things all need a lot less of a change to be felt.
19x459.50
      07-21-2020, 06:41 PM   #26
19x
19x's Avatar
Drives: 2021 M2C
I don't know about M2's, but in older generation M3's, the manual seats were definitely lower (at their lowest setting) than power seats. My friend owned an 02 M3 with manual seats and those were over an inch lower than my power seats in 04 M3.
      07-21-2020, 07:13 PM   #27
chris719
Agreed, but I mean on the F8x platform. I haven't come across any measurements, just anecdotes.
      07-21-2020, 10:22 PM   #28
gmhl10
Drives: Not a M2 CS
I used to have an E46 M3. The car originally came with the power seats. It was nearly 80 lbs per seat. I swapped them out for Recaro Pole Positions, aluminum brackets, steel mounting base which weighed about 25 lbs per seat. Definitely, considerable weight savings to be had there. I couldn't tell you if they made a difference though since I never autocrossed that car prior to the seats, only after. Not to mention, I had other modifications on it that reduced/added weight.
Not sure how heavy the M2 seats are, but I'm sure they're lighter than the E46 M3 seats since they had that stupid air bladder thing in them.
      07-22-2020, 01:41 PM   #29
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
What I've learned, at least with Audi and more likely with BMW also is; US-spec seats are slightly heavier than their Euro-spec counterpart because one, the available manual control option and two, the US has a mandatory requirement for side-impact airbags, to every front seat, which is not required, in the rest of the world..
So, FWIW, you're looking at a 10lbs difference between a typical North American bound seat and the ROW, since most manufacturers take advantage at the opportunity to save a back and lighten the weight, hence, they don't bother adding side impact air bags, on a model, case by case basis.
      07-23-2020, 06:02 AM   #30
AUSf22
2690
Drives: 2020 M2C HS & Ferrari Roma
No wonder the US M4 GTS did not get the bucket style seats!
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes
OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit
OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust
      07-23-2020, 08:55 AM   #31
prompt
Car Designer
prompt's Avatar
292
Drives: M2C
I have manual seat on my M2C
I can take some measurement if we want to compare seat position
