08-21-2017, 05:15 PM | #23 | |
this is the way
18142
Rep 8,520
OWNER'S MANUAL |
08-22-2017, 01:11 PM | #24 | |
Rep 258
So basically this car does not have adaptive cruise control? |
08-22-2017, 01:31 PM | #25 | |
Rep 82
3. The MPE sounds a bit too exaggerated for my taste. You will loose the metallic zilling of the engine, being covered by the exhaust. |
08-22-2017, 01:36 PM | #26 |
Rep 1,761
Drives: S2000, MacanS, M4CS
considering many other MT cars I used to DD in heavy traffic, this M2 would probably be a cake to DD because everything is so light. so easy to drive; Clutch is light, shifter is light, it even matches the revs for you... why so many complaints?
2020 ///M4 CS, Alpine White, DCT
2018 ///M2 LCI, Metallic Orange, 6MT, Exec Pkg, Apple.. Sold Instagram: Tommys911 |
doug_9992541.50 |
08-22-2017, 02:08 PM | #27 | |
Rep 203
The camera is part of the executive package and is used for low speed warning/braking, not for the cruise control system. The front end has no radar sensors. |
08-22-2017, 02:10 PM | #28 |
Rep 1,086
Because over the course of 60-90 minutes pushing your legs in and out a thousand times gets really tiresome and causes excessive clutch and brake wear. If you're lucky, you'll get ankle cramps too, so stay hydrated!
08-22-2017, 03:06 PM | #29 | |
Rep 4,254
///M Power
gtaM2390.50 |
08-22-2017, 04:34 PM | #31 |
Rep 6,635
Why would you buy an M2 and then just sit in a Corolla instead? Why not just cut out the M2 at that point? An M car in the garage is a waste. Might as well drive it if you're going to buy it..
08-22-2017, 05:50 PM | #32 |
Rep 642
08-22-2017, 07:26 PM | #35 | ||
Hanapaa!
393
Rep 449
Konig, I believe your initial 5 questions have been answered so I'll move on to this one.
This is also not a complaint, but sharing an observation as compared to my 370Z. While the M2 clutch is noticeably lighter then the Z's, the pedal travel is longer, not just below the engagement point, but after it engages as well. Also the Z's shifter does not have that rubbery feel like the M2's and the gates are much more clearly defined. Even with it's longer travel, I prefer the M2's clutch, but I have to say, the Z's shifter is superior to that of the M2. |
08-22-2017, 11:26 PM | #36 | |
Rep 45
08-23-2017, 02:19 PM | #39 |
Rep 45
08-23-2017, 02:47 PM | #40 |
Rep 255
08-23-2017, 04:15 PM | #41 |
Hanapaa!
393
Rep 449
08-23-2017, 04:29 PM | #42 |
Rep 45
I had an order in for an M2 since about July (I had not received an allocation at all). I was browsing auto trader earlier this week and came across a 2018 listing. I called the dealership and confirmed they had it. I stopped by and inspected the car and sure enough it was a 2018 with the new instrument cluster and lights. I found out that someone had ordered this car and decided not to go through with the purchase, so I swooped in and was able to get it.
08-23-2017, 05:08 PM | #43 | |
Rep 6,635
08-23-2017, 05:17 PM | #44 |
Rep 45
Very close to the specs I ordered. DCT with the executive package. Only deviation was the Apple Car play (I have android). I do have to admit... I was smiling all the way to work this morning even though I was mostly stuck in traffic. I can't wait to take it out this weekend, should be great.
