07-19-2017, 08:47 AM | #1 |
Driver
391
Rep 650
Invisible Limp Mode..
a few days ago i ran over a plastic bag on the highway... there were too many cars around to risk braking or swerving, i did the rear view mirror check hoping the bag would fly right out but it didnt, i then had a burning smell for a few days, i figured out that some of the bag had melted to the mid pipe so i scrapped off the residue with a putty knife and the smell is now gone, but now for the past few days i noticed the car is running sluggish, at first i just thought it was the weather conditions or even bad gas but now im well into another tank of 94 octane from a different gas station and it still feels heavy, basically i can describe it as the car feels very heavy in comfort mode and in sport + mode it feels almost like it did originally in comfort mode? is there any sensors the bag could have messed up to cause this? is it possible some of the bag is trapped somewhere? my gut says the car is running rich, there are no lights/warnings, temperature is in middle, oil is 100% etc etc opinions? bone stock car with 15K km
07-19-2017, 11:43 AM | #3 | |
Rep 539
I hope this helps...
07-19-2017, 12:40 PM | #5 |
Rep 287
Does the car sound any different... eg rougher exhaust tone?
Would be good to get a quick scan done for codes... use a scanner that can read BMW level codes or install BMW Rheingold on a laptop.
F87 ///M2 - Journal
E46 ///M3 - Journal M2 Topics: Sport Mode Default | Comfort vs Sport on MPG | M2 Alcantara Dash Install | Air Filter DIY |
07-19-2017, 12:46 PM | #6 | |
Driver
391
Rep 650
edit: for my previous car i had an obd2 bluetooth adaptor and used the android torque app hmm i wonder if that will work Last edited by gtaM2; 07-19-2017 at 12:53 PM.. |
07-19-2017, 01:02 PM | #7 |
Rep 187
Drives: 2017 M2
Check your air filter. It would have been caught there if it was sucked up.
07-19-2017, 01:44 PM | #9 |
this is the way
18136
Rep 8,516
The only sensors I'm aware of on the exhaust are the pre-cat and post-cat lambda probes. It doesn't however sound like the bag was anywhere near them. Just take it to the dealer and ask them to inspect your exhaust and check for error codes etc.
07-19-2017, 02:38 PM | #11 |
bad ***** poster _
278
Rep 270
Maybe there was glue in the bag and it got on your wheels and now the wheels are sticking to the pavement. That's my guess, sticky glue wheels.
07-19-2017, 02:58 PM | #12 |
Rep 642
07-19-2017, 07:21 PM | #13 |
Rep 3,295
The Grammar Grammy Strikes Again!
But I agree, some skipped lines and tabs go a long way to make a post easier to read. Mike
07-19-2017, 07:27 PM | #14 |
Rep 3,295
But you said that the Sport Plus mode feels like Comfort mode, so you have lost some performance by you butt dyno? I think it would be odd for something on the outside to effect things like that. It is unlikely that any part of the bag got above the under pan and just a piece burnt off on the exhaust. When in doubt go the dealer to have your under warrantee car checked out!
Mike
07-20-2017, 10:49 AM | #16 |
Rep 4,253
a plastic bag cannot cause performance issues unless by some miracle it is sitting on top of the air filter in the intake box.
///M Power
07-20-2017, 05:49 PM | #18 |
Driver
391
Rep 650
now i notice the exhaust valves are not opening in sport + mode car sounds the same in comfort mode..i guess something is messed up with the exhaust but i wonder why that wouldnt throw a warning? anyhow i booked an appointment with the dealership, in hind sight i probably should have done that instead of posting in here, for those that offered suggestions much appreciated
07-21-2017, 09:12 PM | #19 | |
Rep 812
Formally known as BMWM3NYC
07-22-2017, 06:13 PM | #20 |
Rep 139
I run over shit all the time in my M2. I even hit dirt roads hard when trucks are driving like their f150 is gonna fall apart. The shooting range I go to has a pretty sick dirt road. These cars are solid. Just run more stuff over to knock loose anything you might have stuck from previously running things over.
07-23-2017, 05:31 PM | #21 |
Rep 561
When I was growing up my dad drove over a plastic bag and it got stuck and somehow ruined the transmission
I always try to avoid driving over bags because of that. |
