06-20-2017, 03:31 PM | #45 | |
1423
Rep 2,660
- Ryan
07-09-2017, 10:49 PM | #46 |
Rep 776
18x10 et33 EC-7
NITTO NT01 275/35/18 5mm front spacer
E92 M3 Clubsport
JRZ | TE37SL | AR1| Stoptech BBK (ST60/40) | Recaro SPG XL + Schroth 6 point | Raven Roll Cage | | Alex Alpine Tune | Turner Test Pipes | AFE Carbon Intake | Bimmerworld Solid Bushings and more... |
07-19-2017, 09:20 PM | #47 | ||
Rep 1,124
So far the only advantage I see with a square setup in the M2 is the ability to rotate all wheels to all corners of the car to even out tire wear. The downside is that a square setup means that each tire will rotate at the exact same number of revolutions per mile while the OEM tire rotations differ from front to rear. I also note that the recommended winter tire setup goes to 18 inch wheel, but with a wider width in the rear (by 1/2 inch or an inch). Therefore this is not truly a traditional square setup. Again, I'm not sure that it makes sense to go to a square setup in the M2 for track duty.
08-15-2017, 06:41 AM | #48 | |
Rep 177
08-22-2017, 01:38 PM | #49 |
Rep 3,943
08-23-2017, 01:03 PM | #50 |
Rep 776
et25 might be too aggresive. I have yet to try it
E92 M3 Clubsport
08-25-2017, 12:53 PM | #53 |
1423
Rep 2,660
The 18x10" ET25 is an aggressive square fitment, and would require negative camber to prevent rubbing the fenders. For track rats with adjustable camber plates used to stuffing wide compounds under their fenders, sure, the 18x10" ET25 is a worthy solution which will bypass the need for spacers for inner strut clearance (up front). Dialing in a healthy amount of negative camber is also "par for the course" to this type of enthusiast. However for the masses reading this, I would not sum it up as an easy or bolt-on fitment.
If an enthusiast is looking to run a square 10" fitment with extreme summer or r-compounds for track use, wheel fitments requiring negative camber should not be avoided for the simple fact that negative camber is required. Negative camber is not only important for wheel and tire fitment in this environment, but more importantly it is responsible for improving handling characteristics and promoting more consistent tire wear. Without dialing in the right amount of negative camber, enthusiasts will not be able to leverage those expensive track compounds they are installing. We have a variety of square and staggered fitments available, and we do not want to put every enthusiasts into the same box. Some are looking for a bolt-on solution for the occasional spirited drive or track day, while others are looking to run aggressive track compounds on a frequent basis, and prioritize grip/performance over anything else. Expectations and goals from one enthusiast to the next are quite diverse, therefore our wheel line must be as well. - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-25-2017 at 01:04 PM.. |
OLO-M237.50 |
08-25-2017, 01:04 PM | #54 | |
BMW Newb
581
Rep 903
Can you recommend a square 18" Apex wheel fitment that would not require camber, mainly daily driving with 3-4 track days per year? Looking for something that can support a square 265 width tire setup |
08-25-2017, 01:31 PM | #55 | |
1423
Rep 2,660
Ultimately I would encourage you to install adjustable camber plates up front. 4 events within a year without negative camber is enough to roast the shoulders of your tires. Shoot, a single track weekend without negative camber can do it. Adjustable camber plates pay for themselves in that regard, as it is better to acquire the benefits that camber plates provide for ~$500 rather than rifling through your expensive tires. In the long run, it way more expensive without them. It is important to mention that there are camber setting that are palatable for street/daily driving and the occasional track day. As long as you leave your toe settings neutral (factory), you are not going to see excessive wear on the street. Furthermore, by installing a true rotatable square wheel & tire fitment, you now have another way of ensuring tire longevity. - Ryan
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 08-25-2017 at 01:36 PM.. |
08-25-2017, 01:40 PM | #56 | |
BMW Newb
581
Rep 903
I'll keep your camber plate recommendation in mind! |
08-25-2017, 01:45 PM | #57 | |
1423
Rep 2,660
- Ryan
08-25-2017, 05:25 PM | #59 | |
1423
Rep 2,660
- Ryan
