M2 Technical Topics > Track / Autocross / Dragstrip > Trouble finding 2nd gear under load
      09-25-2021, 07:20 PM   #23
KHAP13
Originally Posted by Daytona_550 View Post
Update: the 2nd gear lockout issue popped up again a couple of times this weekend while braking hard at Sebring's Turn 7. Both times were on 3-2 shifts while straight-line braking (no lateral load).
Sure you’re not pushing the shifter too far to the left (past the resistance) into the area where you would grab reverse? Can’t engage 2nd from there and it will feel as if it’s locked out.
ashmostro1254.00
      07-18-2022, 10:46 AM   #24
alkatraz
53
Drives: 2016 BMW X5M
Any updates?
      07-18-2022, 10:52 AM   #25
Daytona_550
Daytona_550's Avatar
Drives: '20 M2C / '08 550i / '23 330i
Originally Posted by alkatraz View Post
Any updates?
I still have the issue when on track. Not sure what else I can do to address it so will try to do more of my braking in straight line with less trail braking on corner entry.
      07-18-2022, 08:07 PM   #26
TUNEDM3
Stay Ripping
60
Drives: 1M
Stiffer tranny bushings will fix this…tranny is moving under heavy load.
THE GOBBLER- S.O.H
      07-19-2022, 12:45 PM   #27
Daytona_550
I already have the Rogue Engineering mounts on the car. Anything stiffer is more NVH than I will tolerate on a car that I still drive on the street.
      07-19-2022, 05:04 PM   #28
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
I had started another thread on this topic (forgot to search). I have the exact same problem. I'm also running the Autosolutions SSK, but it sounds like that's not a factor based on the stock shifter folks who also have this issue.
I don't have a better solution so far other than just sticking with 3rd gear. I only needed 2nd in turn 1 at Atlanta Motorsports Park, and after trying that turn both ways, I think staying in 3rd might actually lead to a faster lap time since I don't have to upshift 2>3 before braking into turn 2.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
      07-21-2022, 06:52 PM   #29
m2c_6mt
Drives: 2021 M2 Competition
How much more NVH did the mounts create? Compared to the Autosolutions SS?
      07-21-2022, 07:58 PM   #30
Daytona_550
Hard to say because I added the Turner rear shifter bushing at the same time. I have a noticeable whirring sound but not too bad.
      07-21-2022, 09:11 PM   #31
fleetfoot
fleetfoot's Avatar
FWIW I added the Autosolutions SSK with 80a bushings and didn't notice any increase in NVH.
      07-22-2022, 12:24 AM   #32
m2c_6mt
I have a little bit of the whirring sound with the autosolutions alone. The shop that does my installs told me to stay away from the trans and engine mounts, but I hate all the slop in the drivetrain!
      07-22-2022, 09:57 AM   #33
bentom2
I did the Rogue trans mounts and Turner shifter bushing at the same time a few weeks ago. Stock shifter otherwise.
Only undesirable changes of note are that the shifter itself moves around a bit more over bumps or in corners, and that I can hear a bit of whirring when the car is in neutral. If I depress the clutch, it goes away.
On the positive side, the shifter feels much more positive and finding the gear I want on track has been easier. Well worth the minimal trade off.
Next up is engine mount inserts. The fluid in the left side mount liberated itself at some point, so I need to replace them anyhow. I went with the ones from Bimmerworld, but Vargas makes them too. I looked for solid rubber mounts, but no luck. I definitely am not going to jump to urethane (the only other option I found) as I still drive too and from the track and on the occasional backroad.
I’m hoping these inserts prolong the life of the hydraulic mounts and stiffen things up just a bit at the same time, without adding too much NVH. Will report back when installed.
      08-21-2022, 10:24 PM   #34
Heronween
Heronween's Avatar
Drives: M2C 6MT, X6M
Same issues with oem shifter. One time after saving myself from a spin with hard braking, I was stopped and couldn't get the shifter into any gear except reverse. After about 5sec, was able to get into 1st. Sometimes after real hard braking, I can't get into 2nd even just before turn entry, but problem is more consistent while trail braking
Anyone know the problem or solution?
      08-22-2022, 07:05 PM   #35
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
So I fixed my issue.
By upgrading to a Camaro SS 1LE. 😝
Sorry, not funny. Huge upgrade in many ways though. That Tremec trans is AWESOME. Thought I’d share.
      08-24-2022, 10:31 PM   #36
alkatraz
53
Dammit..
      09-25-2022, 09:17 AM   #37
Daytona_550
Quick update: spent last weekend at Sebring. I did not have the "finding 2nd gear" problem on Turn 7, where it had popped up for me before. Next event is in December, will update if any news.
      10-06-2022, 09:30 PM   #38
-Eidos
@lbb_kev
491
Drives: 2018 BMW M2 (LBB)
How do you like the stock mounts + metal inserts? Noises at idle? One would think the addition of the metal insert would add a lot more noise.
I just purchased the Revshift 95a mounts, but if the stock mount + insert combo is that good I may switch.
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage
      10-07-2022, 12:27 AM   #39
bentom2
There’s enough vibration through the controls under throttle in fast sweepers that I think I want to try something else. A friend found that Powerflex makes urethane inserts. He’ll be installing them soon and if results are good, I’ll probably switch.
When comparing to the M2 CS Racing inserts, the right side mount has a smaller shoulder OD than the left mount insert, whereas the Bimmerworld inserts are the same left to right. So I might also just get the P/S CS Racing insert and switch out the passenger side as well.
TBD until he gets the Powerflex inserts installed. This is mostly a track car for me at this point, so I could live with it, but I want to do something out of sympathy for the car. I would not leave them in a street car.
-Eidos491.00
      10-12-2022, 12:29 AM   #40
-Eidos
@lbb_kev
491
To document it here:
Just had the Revshift 95a motor mounts installed. These are paired with Rogue trans mounts and Schirmer's diff lift kit with their solid diff bushings.
I have no vibration at idle and it only becomes a minor humm when the AC is on. When I proceed to move in gear, there's heavier vibration (everything will rattle, butt massage, rear view mirror vibrates) from 900-1100 rpm. After 1100rpm, the vibration decreases significantly to a subtle but audible resonance in the cabin where you just hear and feel the motor (it's honestly nice and adds to the whole race car feel). It's definitely dailyable and the only obnoxious thing is the 900-1100 rpm band, but this is just based on my personal tolerance.
bentom2335.50
      11-27-2022, 04:41 PM   #41
ashmostro
Drives: 2020 M4cs | 2022 M550i
Originally Posted by KHAP13 View Post
For the 3-2 Down shifts you many be crossing over to the reverse area of the shifter gate...You know how you have to push hard to the left to get to reverse... I have found that this area of the shifter gate prevents engagement of 2nd for example on a 3-2 shift. On track it could easier to accidentally push the shifter too far left preventing engagement into 2nd.. Give it a try and see if this replicates the feeling.
This. Much easier to do this without realizing it than people think. It happened to me consistently at a track day and befuddled me until I realized what I'd been doing. Easy to get hamfisted when you are white knuckling it through the gears and corners.
      11-28-2022, 11:44 AM   #42
fleetfoot
fleetfoot's Avatar
I was re-reading this classic R&T article comparing all the 2-series variants and saw the following relevant comment:
"The M2's gearbox is so much better than the 1M's," he says, a sentiment echoed by everybody but me. I'm finding it a pain to come up with second gear in the second-to-last turn, because the reverse detent spring is insufficiently serious about its job.
https://www.roadandtrack.com/car-cul...mparison-test/
      11-07-2023, 11:06 AM   #43
Charles33982
Drives: 2021 Silver M2C
I know this is an old thread, but same issue here on my 13k mile 2021 M2C this weekend. 3rd to 2nd seemed locked out under lateral load and I'm still on Pilot 4s's....
      11-07-2023, 12:23 PM   #44
ashmostro
You're probably moving past the reverse spring detent like I mentioned above.
