04-18-2022, 08:53 AM | #1 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
Stiff Brake Pedal on Cold Start
Recently I started noticing that my brake pedal has been super stiff when cold starting my OG M2. Is this normal ? I daily drive the car and when warmed up, the brake pedal feels way less stiff. I just got my brake fluid change done recently and only have 18k milage on the car. If anyone has fixed this please let me know!
04-18-2022, 07:03 PM | #3 |
Rep 1,243
04-19-2022, 12:32 PM | #5 |
Rep 1,243
04-19-2022, 01:05 PM | #6 |
847
Rep 1,962
Try a different shop. That it's stiff says the brake servo isn't working properly (or you have some surprising mechanical binding problem in the linkage or hydraulic system when cold).
To be clear, the brake servo is designed to work just fine no matter how cold the weather is, and if something is binding in the linkage or hydraulic system that needs looking at. Given the mileage, take it to BMW. |
04-19-2022, 05:55 PM | #7 | |
Rep 1,243
1BC004 zero gear sensor, adaptation: not learned (MSA disabled) 1D3810 clutch switch: Positions mutually implausible I'm assuming this is why the pedal is acting weird. do you know what the hell this is ? I never had this codes before the brake fluid flush. I hope that isn't what caused it. |
05-27-2022, 04:37 AM | #8 | |
Rep 8,972
Maybe you have a vacuum leak which takes a few seconds to recharge after start up. The could have knocedk something when doing the brakefluid flush its all round that aread with the servo etc. How long after start up is it before pedal goes to usual feel? |
05-27-2022, 08:27 AM | #9 | ||
Rep 1,243
