05-18-2023, 08:27 PM | #45 | |
Rep 4,183
I’ll check for it in a bit |
05-18-2023, 09:37 PM | #46 | |
Rep 161
Drives: 2015 535i
2015 F10 535i
FBO BM3 Pure Stage 2 Dorch Stage 2 HPFP E50 tune by Cary Jordan EOS EkP Module Walbro 525 LPFP Variant Argon 20? Wheels E60 M550i Sold “Im a crazy car guy” If it has a motor, it has my attention |
05-19-2023, 12:46 PM | #47 | |
Rep 316
Im not sure on restriction of the cold side. turbo to throttle body…bigger is always better, but the inlets and outlets of the intercooler will need to be upgraded if you’re going that route. Fabbikg those parts to use more secure silicon and tbolt clamps would be more beneficial i believe vs using the factory c clamps…Although….People redid the outlet side of the big boost kit and seen benny’s..So dig into that Honestly, a few psi will make up the difference..Once you’re getting 24/25psi from fhe turbo and its moving 600hp worth of air..then i would look at lowering restrictions..Meaning lowering psi levels but increasing grams/sec of air…much like porting s head. Im not there yet, once i’ve maxed out my current fuel system, then i’ll address whats next. Like lpfp, injectors, & an intake. Just have to wait and see..Im already spinning tires at the top of 2nd gear, sooo we’ll see what 24/25psi is like in 3rd and 4th….Probably going to 18’s and wider/softer tires:.. Last edited by VGSON; 05-19-2023 at 01:03 PM.. |
InHousePerformance113.50 |
05-19-2023, 01:49 PM | #48 |
Rep 161
Drives: 2015 535i
So I just did a boost pressure test again after making some adjustments. The leak is much smaller. But after calling and talking to Turbosmart about my 50/50 blow off valve leaking during this test they said their will be some leakage from the vent to atmosphere areas but nothing the turbo cant over power. So I just did three tests so tell me what you guys think. These were all leak down tests starting at 30psi.
30psi-20psi = 8 secs 30psi-10psi = 22 secs 30psi-0psi = 47 secs I think this should be ok what do you guys think?
2015 F10 535i
mwpa7119.50 |
05-20-2023, 09:05 AM | #49 |
Rep 161
Drives: 2015 535i
Well put the car back together and still cant hit target in 1st-3rd waste gate opens and I start losing boost. Then I tried in 4th and 5th gear and it gets closure to target only 1 psi off and holds from 3600-5200rpm (when I let off). Seems more normal. I did another leak down on the whole system minus charge pipe and it held 25 psi longer then when I just did the turbo, inlet and intake in my previous post. I wonder if I have a leaky manifold seal or map Oring or something. Im gonna take that off today and check everything.
2015 F10 535i
07-04-2023, 07:45 AM | #50 | |
Rep 74
07-04-2023, 07:48 AM | #51 |
Rep 161
Drives: 2015 535i
Not anymore I designed a block off plate for rhe stock diverter valve location and lut a tial 50mm BOV on my charge pipe.
2015 F10 535i
07-04-2023, 07:53 AM | #52 |
Rep 161
Drives: 2015 535i
UpDate: I found my issue. It was the exhaust its to restrictive. The collector where my down pipe exit was 3.25” and it went down to a single 2.5” before going to dual 2.5” exhaust. I removed my exhaust and I was able to hit my targets with 88-89% wgdc.
I started building my new exhaust yesterday and will finish it today. I opened up the bottom of my down pipe to 3.5” and did a single 3.5” to the axle and then dual 3” out. I will post pics later today.
2015 F10 535i
07-04-2023, 08:19 AM | #53 | |
Rep 4,183
What was WGDC before on the 2.5 and what it’s at after the exhaust. |
07-04-2023, 08:29 AM | #54 | |
Rep 161
Drives: 2015 535i
Pure 750 5th gear log old exhaust After I actually hit target Im able to maintain 22-20 psi with low 90% wgdc Pure 750 5th gear log just down pipe Cary clearly has a taper built in to the tune so once the exhaust is done and he sees these logs hell be able to make the right adjustments.
2015 F10 535i
07-04-2023, 08:34 AM | #55 | |
Rep 316
07-04-2023, 08:39 AM | #56 | |
Rep 161
Drives: 2015 535i
I made this downpipe myself like 4 years ago and it was 4” at the turbo and then had the stock exhaust collector size which was 3.25”.
2015 F10 535i
07-04-2023, 07:53 PM | #57 | |
Rep 74
I am still sorting out my wmi.. but I am seeing 25psi at 90 even.. 750 pwg, port wmi, forged, 9.5 comp. |
07-05-2023, 01:15 AM | #58 | |
Rep 161
Drives: 2015 535i
Im also running wmi even tho I took my direct port off Im still running a 500cc injector in my charge pipe with a 50/50 mix. Much need in Az right now. As for my build Im also 750 but I am EWG, forged with 10.2 compression and E85 with M5 injectors and Dorch lift kit and stage 2 hpfp. I do know that PWG cars and EWG cars have very different values when it comes to wgdc. aEWG cars tend to be high then PWG cars for a number of reason.
2015 F10 535i
mwpa7119.50 |
07-05-2023, 02:55 AM | #59 | |
Rep 74
How are you finding it compared to ps2? |
07-05-2023, 03:01 AM | #60 | |
Rep 161
Drives: 2015 535i
I think Ill really know once I get my next couple revisions and we can start doing 25-28psi and clean up the boost through the RPM range. Ive been dealing with this issue for a few weeks now so just happy to figure it out and keep pushing on! How about you? Or did you just go straight to the 750?
2015 F10 535i
07-05-2023, 03:18 AM | #61 |
Rep 74
Hard to lean on it when it's hot for sure.. hopefully all goes well for you pushing ahead with higher boost.
Had ps2 for 5 years....ran amazing without a hiccup until I took it a little far....chipped an exhaust blade. Made great power and very resposive. To early to say with the 750..its spools slower for me. I am only on base map though..have been dealing with boost leaks... pcv issues .. and now wmi leaks so I haven't got to far.. Waiting on some parts from uk.... |
07-05-2023, 08:40 AM | #62 | |
Rep 161
Drives: 2015 535i
Damn sounds like what Ive been going through. Trying to track down boost leaks and pcv issues as well. Did you block you PCV ports in your cylinder head? I feel like I got it all sorted now as the system holds 30psi well and leak down with the engine is minimal when I do a full shsyem pressure test.
2015 F10 535i
mwpa7119.50 |
07-05-2023, 08:59 AM | #63 |
Rep 81
07-05-2023, 03:36 PM | #65 | |
Rep 74
Car ran perfect on Ps2. Was off the road for almost 6 months waiting for 750...was expecting a straight swap and go but hasn't worked out that way. Didn't block ports...thats how I found my pcv was stuffed,, all the pressure when boost testing went out through the oil filler cap hole... Mines holds well at 25 lbs. Are you spooling quick as ps2? Ps i did a big build on a Subaru years back...100 plus dyno tests...the exhaust merge caused major back pressure...as we went bigger , power jumped massively...actually silimilar to your size. |
07-05-2023, 03:49 PM | #66 |
Rep 161
Drives: 2015 535i
Same!! My car ran strong on PS2 and had only little isses here and there over time but nothing major but this build and swap over to the 750 has been a journey with trying to get this thing dialed after the build.
I dont know if you follow my youtube or instagram In House Performance YouTube but Ive had to pull the motor twice and thought I had blow by when I was pressure testing but it ended up being those damn pcv ports in the head that was leaking out of the oil fill cap. And then the exhaust issue so yeah its been exhausting but hopefully got it all figured out. Got a revision from Cary did some pulls today but its to hot even with meth Im still in the 100s IATs so Ill get some better data tonight when it cools down.
2015 F10 535i
mwpa7119.50 |
