M2 Technical Topics > Cosmetic Modifications > Which OEM Rubber Floor Mats best suits a LBB m2
      11-29-2018, 07:23 AM   #67
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
Originally Posted by Lotus99 View Post
What do you mean exactly by "pull your gas pedal"? Like remove it? Or are you just putting a piece of plastic under the mat, in front of the gas pedal?
Do you have a picture of what you did?
All mats intentionally leave a big gap between them and the pedal for safety reasons I'm guessing, so there's no chance of the mat pressing down on the gas pedal. I'm sure they could have left a smaller gap if they wanted. Same thing happens with my BMW mat.
The gas peddle is plug and play. unscrew from the floor and slide the plastic sheet under it then screw it back down. In reality you have to remove the gas peddle to steam clean the carpet properly anyway and this prevents this completely and really takes 5 minutes....
"I would rather cry in a BMW than smile on a bicycle." Ma Nuo
      12-04-2018, 01:33 PM   #68
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
Nice. Thanks. Where did you get this piece of plastic? Just wondering what to look for…
      12-04-2018, 01:51 PM   #69
///M TOWN
///M TOWN's Avatar
Drives: M GmbH
2018 M2  [8.83]
Originally Posted by Pol View Post
Those from the M2 MPerformance accessories are rubber too :
http://www.bimmerworld.com/Safety-Ra...235i-228i.html
The better match anyway.
I like those a lot I just wish they came in more of a black or dark grey.
However I bet they are super easy to take care of.
      12-04-2018, 06:04 PM   #70
GregoryK
GregoryK's Avatar
504
Drives: M2 '18
I just use a piece of thin plastic sheet off a roll I have at home. It want to be thicker than a plastic bag - but not by much. It is just to stop the water (and salt) from hitting the area around the peddle base. Even if the salt migrates off the plastic it is way easier than cleaning it around the peddle! Hope this helps.
Tags
floor mats
