04-26-2022, 06:12 PM | #23 |
Rep 128
Curious to know what was the outcome? I’m hearing that same 0.5-1sec weird ‘grinding’ metallic sound on every pull when initial rpm is low (say below 2250 or so). 2021 dct m2c
04-26-2022, 07:07 PM | #24 |
Rep 547
I used to think it was rattling exhaust valves, every time around 1900rpm on acceleration only (DCT). Unplugged the exhaust valves and made no difference to this sound (although the exhaust sounds nicer ).
I believe mine is turbo wastegate rattle. Seems to be a common S55 trait. |
04-27-2022, 04:40 AM | #25 |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
Any other 6MTs with similar sounds?
M2CS,
The second coming of ///M! |
04-27-2022, 06:07 AM | #26 |
Rep 908
Drives: 2018 M3 Competition
I forgot to have service check it out, and I can't remember the last time I heard it.
It's more of a metallic rattle than grind. I don't think it's waste gate rattle, which I had on my old 135i. That was much more pronounced and was always there. This is definitely intermittent. I'll listen for it next time I take the car out. |
04-27-2022, 07:27 AM | #27 |
Rep 577
I have the exact same thing - possibly always been there but just started to notice it about 3 weeks ago. I am 6MT as well.
Metallic rattle, sounds like it's coming from directly under the car IMO, it is at very low RPM, like first gear and gently pulling away, or a lazy 1-2, and not giving hard throttle, hear it in 2nd as well. It happens for a second and is gone. Seeing the heat shield comments makes me believe that's what it is - I definitely do not think it's coming from under the hood or at the very back of the car - really sounds to me like it's right under me in the middle of the car.
Instagram: @MinionM3
Current Garage: 2012 M3 ZCP, Mineral White, DCT: Track Build 2020 M2CS, Misano Blue, 6MT |
MadBimmeRad7124.50 mfarrzhp1497.00 |
04-29-2022, 11:49 AM | #28 |
Rep 38
Those of you that hear this sound, do you also have Auto Solutions SSK? Might have this rattle too and it only occurred after install. Naturally thought is was a heat shield as well.
04-29-2022, 03:41 PM | #29 |
Rep 2,211
Drives: G81 M3 Touring (Frozen Black)
It's not clear to me if you're referring to an ongoing noise or a sudden one? If it's a brief one and sounds like a light metallic tap at low rpm, some here (myself included) have noted the exhaust valves opening and closing as you release your throttle - most notably when the efficient engine throttle setting is activated.
04-29-2022, 04:40 PM | #30 |
Rep 48
Based on the descriptions here, I'm thinking this is similar to what I captured in this video.
https://youtube.com/shorts/L3NLo4_3Ycs?feature=share Another forum member in the UK was experiencing the same thing on his M2 CS and his dealer ultimately determined this was being caused by a scored camshaft after several weeks in their shop and multiple consultations with BMW UK and BMW HQ. I shared this info with my dealer and multiple videos like the one linked above but unfortunately have been told multiple times they can't replicate the noise. I've continued to drive my car with the noise coming up intermittently and choosing not to worry about it since I've tried to get it resolved with no luck so far. This has also made me consider an extended service contract just in case it does escalate into a bigger problem down the road but I haven't pulled the trigger yet. For those wondering, my M2 CS is stock with a DCT and windows closed during this recording.
F87 M2 CS
E90 328i xDrive Sold - F87 M2 Comp, F87 M2 LCI, F22 228i, and E90 328i |
04-29-2022, 05:18 PM | #31 | |
Rep 908
It is similar, but mine is even lower RPMs and is gone by 1500 RPMs or so. It's intermittent, or at least I only notice it intermittently. My car is stock other than H&R springs. |
TwoTwentyBlue117.00 |
04-29-2022, 08:00 PM | #32 | |
Rep 2,211
04-29-2022, 10:47 PM | #33 | ||
Rep 128
https://youtube.com/shorts/gGP0Tbv-fD8?feature=share https://youtube.com/shorts/ddk-ihBVpDo?feature=share |
04-30-2022, 02:29 AM | #34 | |
Rep 4,008
This happens when I try to play your vid
M2CS,
04-30-2022, 12:14 PM | #35 | |||
Rep 908
It gave me a reason to take the CS out this morning. I tried to replicate and record the sound, but it didn't happen. It's been months since I've noticed it now. It either went away after a couple thousand miles or it's mild enough that it has to be the right RPM frequency and driving with the right surroundings to have the noise bounce back to my ear. That makes me think it's nothing internal, but rather something that is or was a bit loose, like the heat shield. |
05-02-2022, 09:34 PM | #36 |
Present:
111
Rep 33
I've been running this fuel (101 Octane) for a few weeks. The CS motor seems to like it. If you're in So.Cal there is probably a 76 station nearby that has it
MadBimmeRad7124.50 |
05-07-2022, 06:48 AM | #38 |
Rep 128
Just found a post with a better video in which we hear the exact sound I get
https://www.bimmerpost.com/forums/sh...php?p=25304937 |
05-07-2022, 10:07 PM | #39 |
Rep 1,065
05-07-2022, 11:51 PM | #40 | |
Rep 547
04-22-2024, 09:51 AM | #41 |
Rep 5
hello everyone i have a vibration/fast rattle, like a metal on metal sound like a loose bolt, coming from (not sure) engine/passenger side underneath (lhd)
Only happens when i rev from a stand still in neutral, doesn't matter how high i rev, when the rpms drop at around 1800/1500 i hear this noise, any guesses? already checked for shield but didn't find anything TIA |
04-22-2024, 04:54 PM | #42 | |
Rep 71
04-24-2024, 07:44 AM | #43 | |
Rep 128
05-07-2024, 09:52 AM | #44 | |
Rep 71
Are there washers on both sides (link and DP) or do they share the same washers? Aka am I buying 4 or 2? Is there any other hardware that should be replaced other than specifically the washers? Do you by any chance have a part number? Thanks in advance for any insight. |
billypopo68.00 |
