M2 Technical Topics > Suspension | Brakes | Chassis > Rear Ohlins damper keeps clicking (problem)
      03-10-2024, 04:48 AM   #1
rpriscu
Drives: M2 16
Hi,
Have Ohlins R&T on the car for 4+ and about 50Kkm years, never touched the setup actually as it felt OK (was bought like this from previous owner about 3 years ago).
Recently wanted to reset the clicks to check how stiff/soft it is and one of the rear dampers kept clicking (beyond 20 clicks...) never reaching the "end".
The other damper stoped clicking at 10 clicks for full stiff, as were the fronts.
Is it a serious problem? needs a rebuild? Would appreciate if someone can share some insights
      03-10-2024, 08:42 AM   #2
Westersund
Westersund's Avatar
Sweden
500
Drives: BMW
Probably the nut holding the adjustment knob that's come loose.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      03-10-2024, 08:52 AM   #3
rpriscu
Drives: M2 16
Is it something that I can try to sort out myself? where is located?
      03-11-2024, 12:20 PM   #4
gsrbri
gsrbri's Avatar
Drives: F87 6MT
Ran into the same thing. According to Ohlins, the adjustment approach is as-follows:
1. Tighten to full stop (0 click)
2. Rotate counter clockwise (from bottom) to the desired damping (1-20)
3. Clicks beyond 20 don’t materially affect damping
I reset all 4 corners and the car feels great (15 on the street).
Good luck
gphung193.50
