11-28-2023, 06:55 PM | #529 |
Rep 7,321
Philly_sweden618.50 |
11-28-2023, 07:50 PM | #530 |
New BMW owner
328
Rep 845
First time using Castrol Edge EURO 0W40 A3/B4 and my car got a notice to add a quart of oil after a few months. Maybe I didn't fill it up properly the first time...or used up. Anecdotal.
ericold1.50 |
11-28-2023, 07:56 PM | #531 |
Rep 7,321
Hard to say, the oil level sensor is not giving you the most precise reading either I think.
11-28-2023, 10:40 PM | #532 |
New BMW owner
328
Rep 845
I don't think I've ever seen mine in the middle.
Takes 2s to measure w/ a dipstick....and a ridiculous amount of time (2-3 mins) to get that inaccurate reading (pollutant coz the car's not even moving).... why BMW, WHY?! /rant over.
ericold1.50 |
11-29-2023, 12:17 AM | #533 | |
Rep 67
one of them is a friend of mine. i said maybe the combination between my engine and these brands 5-30 is not the right one. friend of mine had the same thing with motul oils.same engine. |
11-29-2023, 12:35 AM | #534 | |
Rep 67
be careful what you reproduce, don't put words in my mouth i never said! your investigation is irrelevant. you have lost it completely trying to summarise . there is nothing general rule in oil and engines.as an expert here you should know that.and as an expert you should know that shell and mobil oils have the lowest NOACK among 5-30s. Motul has the highest 10% ! what is working for me maybe doesn't work for others.i don't generalise like you do. all oils as i already said were same viscosity 5-30.both these with consumption and others with no consumption. now your answer justifies my arguments. if you really want to help ,lets make an easy conversation.its for everybody's interest to talk these things.this is what forums is all about.maybe this speculation i have, and i am not the only one from what i read in other forums and personal inquiries ,will help other drivers who have the same thoughts. we are all together in this forum. |
11-29-2023, 02:48 AM | #535 | |
Rep 7,477
Are you sure about that? Because that sounds like another baseless deduction. Motul xclean 5w30 is 10% https://bobistheoilguy.com/forums/th...k-list.274856/ Pennzoil is: PP 5W-30: 12.5% PUP 5W-30: 6.6% PPPP 5W-30: 10.1% PUPPP 5W-30: 11.5% https://bobistheoilguy.com/forums/th...values.286960/ As you can see, depending on the type of pennzoil/shell oil, the NOACK rating can vary drastically - which is EXACTLY what I told you before.... So like I said, saying the oil weight alone and not factoring type of oil used on both sides leads to inconclusive deductions that are meaningless. You also have to factor in oil viscosity, because the thicker the oil the less likely it will be bypassing gaps (likely piston rings) in a poorly toleranced or worn engine and that means it is going to more likely be burnt. Again not all oils despite being 5w30 have the same viscosity (kv40 and kv100).
11-29-2023, 01:25 PM | #536 | |
Rep 67
bmw tpt ll04 5-30 (shell branded) has about 7,5 noack
mobil 1 esp 5-30 has about 7,9 noack if i can recall. i cant find links right now it will be ages past to find them on bitog. so,no NOACK IS NOT the issue. bmw tpt ll04 5-30 kv 100-12,7 kv 40-70 mobil 1 esp 5-30 kv 100- 11,9 kv 40- 67 again we are talking about almost identical oils regarding viscosity and NOACK. funny you mentioned bitog.so any argument from bitog will be right for you.works for me too.bcs. if what i claim as an argument here about GTL and consumption is on bitog then you are WRONG and my arguments have a real BASE cant seem to attach the other comments so i will quote them from bitog : Quote:
11-29-2023, 01:30 PM | #537 |
Rep 7,321
What is the point of posting all this crap? Plenty of people here run PP Euro 5W-40 with GTL base on N55 and S55 and have zero consumption issues.
11-29-2023, 04:59 PM | #538 | |
Rep 7,477
At the end of the day, if you don't want GTL oils that is your choice, you seem to like motul so stick to it. As for the large majority of us - myself included, we don't experience any oil burning whatsoever running PPE 5w40 which is a GTL oil. So it is very likely your engine has large tolerances and is one of those oil burning engines.
ZM22827.50 |
11-30-2023, 01:25 AM | #539 | |
Rep 67
anyway, i understand you got lost ,to what i asked and what was my initial question. which was: which oils are not GTL based? bcs, i noticed that when i use them I have a little consumption. so others. i never said that GTL oils are crap generally,these are your understanding,your words not mine.thats why you misunderstood and got upset and said all the wrong arguments. i didint speak only for motul.i said i am not a fan boy and i certainly i dont represent any company.i said i also used castrol .i used fuchs and redline. i never had a little consumption like i did with shell and mobil. again i already said that these are 2 of the best oils out there,i used them in my previous cars and they were all ok. you are trying to get right when there is no reason for.its not a competition. we got to honest. i am. what do you mean i have a burnning engine and big tolerances? if i did then i would have had consumption with all oils not just some. what about all these drivers from bitog the forum you praise so much? and they are very experienced members if you look into. do they have burning engines too? they stated that with this oil in SOME engines they had consumption.in the same family on of them in different cars had one with consumption and one with no. experiences is one of the 2 important parts in the oil forums.one is scientific knowledge.but this is how good it looks on paper.the second one is experiences. the majority of drivers who write here evaluate an oil from personal experience. thats what i did. if you blame me for that then you should blame yourself to. bcs. you and chris do that all the time. if the topic of oils was just to place scientiffic knowledge by quoting specs from companies then what are we all doing here?just quote the motul,shell,mobil, etc, specifications and don't comment.in oil-club.de they have a topic they do that.but they have a topic with personal experiences too. personal experiences is not important?, or just the experiences that agree with the 2 of you? this is a known phenomenon ,some engines work better with some oils, others don't. this is the only general rule with oils.and you being an expert you should know that.you just got carried away with your ego and you try to change your mind to others even though you know it is true. |
11-30-2023, 01:40 AM | #540 | |
Rep 67
try to post that there,i dare you p.s i am glad that you agree with me too. you were carried away with your ego too and you cant see that i said the same thing from the very begging. p.s 2) Code:
.vrooooom First time using Castrol Edge EURO 0W40 A3/B4 and my car got a notice to add a quart of oil after a few months. Maybe I didn't fill it up properly the first time...or used up. Anecdotal. so sad to hear from a mecahnic to not know the golden rule of oil: some engines work better with some oils, others don't. cheers! |
11-30-2023, 02:18 AM | #542 |
Rep 7,477
chris7197365.00 |
11-30-2023, 12:11 PM | #543 |
Rep 67
oh i get it. i am glad that he did it. forums is an opinion exchange.if he has nothing to argue then is better to be quite.
if he is so proud for that action and posts it in public, the only one who gets embarrassment and humiliate is himself. and he is worth it. what i know dear chris and f87 ,is when someone like you in a forum is arguing about a subject and prove him that he is wrong , to enhance that ,to prove him that he is wrong with his own arguments and then he answers with a simple '' this is crap'' for an ''argument'' then we all know that he was wrong, he lacks of arguments and cant accept it. and it all makes sense then |
11-30-2023, 02:42 PM | #544 | |
Rep 7,321
12-21-2023, 09:21 PM | #546 |
Rep 7,321
I decided to dump it early at around 3k miles and sample it:
https://bobistheoilguy.com/forums/th...-miles.377261/ Very thin. You beat me to this post already on BITOG lol, nevermind. |
12-21-2023, 09:24 PM | #547 | |
Rep 7,477
12-22-2023, 12:58 PM | #548 |
Rep 882
I always use Aral Supertronic 0W-40 in my M2 which is a true synthetic oil and not the hydrocracked mineral oils that are usually label synthetic. Starting to get hard to get a hold of though. Still have 20L luckily.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
12-23-2023, 12:22 AM | #549 |
Rep 7,477
From what I can see via the spec sheet, the aral supertronic 0w40 oil doesn't have all of the super critical certifications like porsche A40, MB 229.5, and BMW LL01. There isn't much out there about their HTHS either, so I'm leaning towards the idea that this isn't really an oil on par with the likes of Pennzoil platnium euro 5w40 (shell helix ultra 5w40 in Europe), Motul xcess gen 2 5w40 (has to be gen 2 because Gen 1 kind of sucked imo), and mobil 1 FS european car formula 0w40.
12-23-2023, 02:22 AM | #550 | |
Rep 882
I'm not an expert on oils but we have a guy over at the Swedish BMW forum that's an absolute nutter (in a good way) when it comes to oils. If he recommends Aral Supertronic I'll follow. It used to cost 6$/L but nowadays it's about 10$/L because of the smaller production volume.
