07-02-2021, 01:29 PM | #1 |
Rep 288
Recaro seats and airbag coding
Hey gents,
I've recently replaced the seats on my BMW M2c. Since the pole positions do not have airbags I'm getting the annoying display on the Idrive system for both passenger and driver. I've tried to find the info in regards to coding out the airbags but can't seem to find anything for the M2c. Have any of you guys done this? I have bimmer code but once I put the system in advance it's gibberish. Any pointers are appreciated !!!! |
07-02-2021, 03:47 PM | #2 | |
Rep 1,263
https://www.codemybimmer.ca/product/...oding-session/
07-02-2021, 04:07 PM | #3 |
Rep 340
I can't speak for certain, but I believe Bimmercode doesn't allow access to safety-related aspects. Either way, E-sys is a better system for this kind of change.
If you're just removing the seats like I've done (pair of Recaro Profis), but keeping the factory belts and tensioners, see the attached. Doing this will send faults to the car so you'll need to clear those after coding has been done. |
ebisu81079.50 |
07-03-2021, 05:59 PM | #4 |
M///modifyer
2489
Rep 1,295
I used these guys remote service… https://www.codemybimmer.ca/
Cheap, quick, simple.
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 |
07-03-2021, 06:28 PM | #5 | |
381
Rep 731
At a Point above 7,000 RPM.
07-04-2021, 12:15 AM | #6 | ||
M///modifyer
2489
Rep 1,295
There's 2 or 3 sensors to code out. Used the oem electric slides & added electric lumbar supports too (pic below). Brey Krause make a Nogaro to M2 specific kit with side adaptors & all the info you need to wire up & install them. There's a good 'how to' on you tube here…
chief1richard381.00 tux2005234.00 |
07-10-2021, 04:24 PM | #8 |
Rep 1,263
Where would someone acquire those resistors? Are they PNP, or are there some mods that need to be made?
TIA, HAZMAT
07-10-2021, 07:37 PM | #10 |
Rep 159
@chief1richard Here's my thread on adding Nogaros, including all the brackets, etc.: https://f87.bimmerpost.com/forums/sh...php?p=25535027
@NY135ivishnu The info specific to coding coding is here (including instructions on downloading e-sys and getting it working): https://f87.bimmerpost.com/forums/sh...9&postcount=40. As mentioned, bimmercode won't work for this purpose. The resistors used are typically 3 ohm 1/4W--you can either cut the wires and solder one on, or re-use the connector and get some new pins to build a fully PNP solution. |
Daytona_550463.50 |
07-11-2021, 10:00 AM | #11 | |
381
Rep 731
07-11-2021, 12:34 PM | #12 |
Rep 340
Yes, you’ll need to code the seats back in when you place the stock seats back. The coding is easier than the physical swapping of the seats.
chief1richard381.00 |
08-20-2021, 03:39 PM | #13 | |
Rep 95
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
08-21-2021, 02:59 PM | #14 | ||
Rep 1,917
Matt
08-21-2021, 04:26 PM | #15 |
General
10445
Rep 40,774
Drives: 2018 Alpina B6 650ix GC
Your Receive PM function is disabled. PM me when working.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-22-2021, 07:26 AM | #16 | |||
Rep 744
I'm really looking at seats + roll bar + belts as the next upgrade.
08-22-2021, 04:05 PM | #17 |
Rep 95
Hi Shawn, not sure what you mean. I receive private messages all the time or are you referring to something different?
JJ
08-22-2021, 04:10 PM | #18 |
General
10445
Rep 40,774
Yes, apparently me being logged into f80.bimmerpost.com was not enough. I had to log into f87.bimmerpost.com to reply. PM sent.
08-26-2021, 12:03 AM | #20 | ||||
M///modifyer
2489
Rep 1,295
They are pretty much identical to the Pole positions I have in my RS275R although the harness slots are located a little better & the fact you can buy the BreyKrause M2 specific kit was a plus. The few small bits & pieces you need to make the whole system plug & play without having to cut wiring etc can be had on eBay with a little searching. Cost is never cheap for this type of quality although it was less than buying Pole positions & retrimming them. The driving experience is transformed once you get rid of the oem seats. The only real downside is lack of easy access to the rear seats although I've never had anyone in the rear seat so not an issue for me. I'm using the Schroth quikfit harness on track days & given this car is my daily I am trying hard not to ditch the rear seat & add a cage, although it is very tempting.
08-26-2021, 02:57 AM | #21 | |||||
Rep 744
Could you maybe PM me the details of who you spoke to and what the leather + stitching details are?
08-27-2021, 11:53 AM | #22 |
Rep 500
I'll probably be going with Nogaros as well and have been doing some research. This thread may help you:
https://www.bimmerpost.com/forums/sh...php?p=25535027 |
