06-19-2023, 01:22 PM | #89 | |
Rep 7,431
06-19-2023, 03:08 PM | #90 | |
Rep 4,146
The mufflers does jack all for gains: Last edited by AmuroRay; 06-19-2023 at 03:14 PM.. |
06-19-2023, 04:05 PM | #91 | |
Rep 7,431
Claims of crank horse power doesn't mean anything because you can't accurately calculate drivetrain loss. The only important number is the before and after wheel horse power measurement.
06-19-2023, 05:19 PM | #92 | |
Rep 4,146
If you look at the results I posted previously, they have the claimed power and compare it against their dyno measured power. SuperSprint diameter is 80mm, AWE is 76mm
Mods: Yes.
06-19-2023, 05:37 PM | #93 |
Rep 1,065
The bottleneck for thr n55 and most f30 cars lies in the downpipe and resonators. The m235 is a true 3” ID but smooshed for clearance past the downpipe and expands again for the resonator + muffler. I have f30 n55 resonator as I was going to put it into my exhaust setup to get rid of the small drone between 2600-2700 at 75-85 mph or so
MY13: TTE400 Stage 2 turbo.
e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block Build Thread: https://f30.bimmerpost.com/forums/sh....php?t=1742413 IG + YT: Sqwin_n20 |
AmuroRay2282.50 |
06-19-2023, 05:44 PM | #94 | |
Rep 7,431
06-19-2023, 05:55 PM | #95 | |
Rep 4,146
edit: https://rennlist.com/forums/gt4-spyd...o-experts.html
Mods: Yes.
06-19-2023, 06:59 PM | #96 | |
Rep 7,431
06-20-2023, 04:00 PM | #98 |
Rep 7,431
Getting close!
Can't wait to see the results!
AmuroRay2282.50 |
06-21-2023, 04:56 PM | #99 |
Rep 4,146
I picked up my car today - she's all buttoned up and drives wonderfully. I haven't been able to push it yet, as I was carrying a passenger and the roads weren't open enough.
However, I'll say the VRSF Race intercooler is FANTASTIC. IATs can go as low as 5F over ambient, and I've held <10F during some lower gear pulls. During low speed cruising, I saw as high as 15-20F, but I stepped on the pedal and it immediately dropped down to around less 10F or less. It was 89-90F out according to my display, so this IAT control was welcome. Also - Zero Lag. As for the tune - I can't really gather anything from it yet. While it was hot and sunny this afternoon, it's already raining out - so data logging will have to wait
Mods: Yes.
06-22-2023, 09:48 AM | #100 | |
Rep 81
06-22-2023, 11:30 AM | #101 |
Rep 4,146
Depends on your plans - I have high ambient temperatures and plan on doing more track days - so I felt it was worth it. The little CTS will not hold up in those situations.
Mods: Yes.
06-22-2023, 01:34 PM | #102 | |
Rep 7,431
So my advice is to run a high enough octane (ethanol mix) that high iats won't be a problem. Then potentially run water injection to help suppress iats.
06-22-2023, 02:17 PM | #103 | |
Rep 4,146
Mods: Yes.
06-22-2023, 02:30 PM | #104 |
Rep 3,696
Let’s expand on the IC/track topic over here: https://f87.bimmerpost.com/forums/sh....php?t=2024707
I still don’t know the best approach. Another guy I know running a Stg 2 tune, full CSF cooling pack, and the ER IC had coolant temp issues (IATs were fine), as well. |
F87source7253.50 |
06-22-2023, 03:02 PM | #105 | |
Rep 7,431
But that's the simplistic answer, if you look at it from an air flow perspective the m2 has a fairly good ducting system from the factory. It takes all the air from the lower inlet and expands that outwards to a larger volume while ducting that to the radiator and intercooler. This expansion drops the air speed and increases air pressure which is very vital because higher pressure allows better air flow through radiator cores, and the lower speed allows better thermal exchange. This is the principle behind race car ducting - the expansion. When you shove a massive intercooler there, that expansion no longer takes place and all the air ducted to the radiator now has to go through an intercooler. So yes it's absolutely blocking air flow to the radiator, because the duct can't channel air there anymore. This is effectively what the stock m2 duct is doing: Here's what the duct looks like: https://www.ecstuning.com/b-genuine-...r/51748062165/ It takes all the air from the center opening and tries to expand that and duct it to both the radiator and the intercooler. It can't do that if a giant intercooler is in the way. The duct itself is also "ok", it could be so much better if it was a single solid piece of carbon or plastic or metal, with really good flow attachment - like a diffuser.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 06-22-2023 at 03:10 PM.. |
06-22-2023, 04:56 PM | #106 | |
Rep 4,146
Mods: Yes.
06-22-2023, 05:41 PM | #107 |
Rep 4,146
The issue Zm3 is likely having is the DCT cooler and tall intercooler are blocking airflow to his radiator - there is no cooler there on my car.
Mods: Yes.
06-22-2023, 05:55 PM | #108 | |
Rep 3,696
It’s all about the larger aftermarket IC’s blocking air to the radiator on tuned cars. That’s where you run into coolant temp issues on hot track days. I’m fine with IATs 40F above ambient on hot track days since I’m running E50, but IDK which IC is best to have at least that much control over IAT on a 480whp car while keeping as much airflow to the radiator, or if both are even possible. Hence my thought for the smallest IC that has decent IAT control and blocks the least amount of airflow, and I can supplement with simple, non-tune dependent water injection if needed. |
F87source7253.50 |
06-22-2023, 06:04 PM | #109 | |
Rep 4,146
Look how much space you have available: Vs Ooof. Sorry for the low quality picture - I was in the garage with low light. But according to this video - All they removed was the front duct that just ducted small intercooler. The top of the intercooler was (and is) still sealed, at least on my car.
Mods: Yes.
06-22-2023, 06:17 PM | #110 | |
Rep 3,696
