M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 Charge Pipe ??
      01-06-2019, 01:41 PM   #1
M2C AW
Drives: 2019 M2C Alpine White
M2 Charge Pipe ??
How essential is it to upgrade the M2 charge pipe when upgrading the FMIC with a Stage 1 or Stage 2 tune ? Anyone actually blown their M2 charge pipe ?
      01-06-2019, 01:48 PM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
From what I've gathered there are reports of people blowing stock charge pipe even on stock tune.
With extra boost from a tune it's pretty much a crucial upgrade
      01-06-2019, 02:23 PM   #3
M2C AW
I’ve heard of folks with CP issues on their M235...but haven’t actually seen anyone with a M2 failure. Any body ?
      01-06-2019, 03:49 PM   #4
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
It's cheap insurance. I'd just do it if you're already in there.
Motorcity BMWCCA Member
Instagram | YouTube
      01-06-2019, 03:53 PM   #5
nioh_lbbm2
nioh_lbbm2's Avatar
1717
what detroitm2 said.
M235 and M2 have the same pipe. If it can break on the M235 it can break on the M2. There was somone last year on the M2 forums that posted about his breaking on stock. Search is your friend.
      01-06-2019, 05:13 PM   #6
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Here's one example- only mod was sport cat (and mpe)
check your charge pipe https://f87.bimmerpost.com/forums/sh....php?t=1494417
      01-06-2019, 05:33 PM   #7
codylikerice
69
Anyone have a recommendation for a stronger charge pipe?
      01-06-2019, 06:47 PM   #8
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Any aftermarket one will be better.
Check the sponsor classifieds.
Active Autowerke and VRSF are a couple of them.
      01-07-2019, 07:31 PM   #9
mike@x-ph.com
mike@x-ph.com's Avatar
Charge pipe upgrade is a must when tuning the car
https://x-ph.com/sale/
Phone number 702-494-9435
      01-08-2019, 07:20 AM   #10
Tricki
Tricki's Avatar
215
Drives: BMW M2 Comp
I have an M2 with intercooler and DP with stage 2 tune but stock CP. I've been running this for 15000kms. And waiting for the pop. 😳
      01-08-2019, 08:12 PM   #11
magha
magha's Avatar
93
Drives: '18 M2 AW 6 spd
happened on my Oner and it wasn't fun. car crawls up the revs everrrr so slowly when the pipe is off!! pop can be freaky too if you're not aware of the CP being the usual suspect
getting the VRSF pipe installed along with FMIC & DP in the spring before upping to stg 2
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2
Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe
      01-09-2019, 09:13 AM   #12
mike@x-ph.com
      01-25-2019, 01:57 AM   #13
Shih
Drives: E92 335i
Change it. It will happen one day, why wait.
      01-25-2019, 04:27 PM   #14
serrated
I used vrsf and it was an easy install. Different brands put the split (they're all 2-piece) in different locations. The vrsf one splits down near the intercooler and I was able to easily access both clamp bolts from under the car. The evolution one splits up near the top but the clamps would be pretty hard to get to and the pipes are hard to plumb through the engine bay when it's one piece. (getting the oem one out is a little tricky unless you don't mind cutting it in half)
      01-25-2019, 04:40 PM   #15
///Cardia
///M Power
///Cardia's Avatar
Drives: N55 F87
VRSF.
2018 ///M2 LBB 6MT (Exec Moonroof Apple)
Mods: 3M Tint ~ IND CF Mirror Caps ~ Eibach Springs ~ JR18 Gloss Black Rims ~ CTS Turbo Intake ~ VRSF Chargepipe ~ Raze Canards ~ Fabspeed Sport DP
BootMod3 Tune ~ IND Black Chrome Front and Side grilles ~ IND ///M Emblem ~ Vorsteiner Reardeck Spoiler ~ Eventuri Air Scoop ~ Acexxon Rear Delete
      01-25-2019, 05:41 PM   #16
akkando
akkando's Avatar
5865
What tools would I need to do this myself?
      01-25-2019, 05:46 PM   #17
Altra
Drives: 2016 AW M2
UltraMagneticAL made a DIY video I bookmarked way back. Just in case I ever decide to tackle this myself.
He installs both FMIC and charge pipe in the clip.
Here's the thread:
https://f87.bimmerpost.com/forums/sh....php?t=1382280
      01-27-2019, 02:16 AM   #18
serrated
Ramps or jack stands, socket set, socket extension(s), and that's really about it. Removing the OEM charge pipe is the hardest part. The skid plates are annoying but they're easy. Just a bunch of low torque trim screws.
I took a ton of pictures so I made a quick video. My video is more of a supplemental video with tips to make the process easier. I linked the video that I found most helpful in the video description.
      01-27-2019, 03:30 AM   #19
pooyab
pooyab's Avatar
330
Drives: 2011 BMW M3 2020 BMW M5C
2011 BMW M3  [0.00]
My M2 has 1800 miles on the clock, and was running between stock and stage 1 tune. Dyno'd it and found out I had a boost leak, no codes or any error messages. Swapped to ER CP and CSF FMIC and gained back almost 50whp.
My friends 135i CP blew up running stage 2, had to limp mode the 2 hour drive back home, but good thing the new one was waiting for him there.
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
      02-13-2019, 04:06 PM   #20
Happy Motoring
Happy Motoring's Avatar
Drives: OG M2
2017 BMW M2  [10.00]
Would you happen to know how AA is designed? Thinking of getting it over VRSF as both are same price.
      02-13-2019, 10:51 PM   #21
serrated
no idea, unfortunately
      02-14-2019, 09:08 PM   #22
jclaib7
jclaib7's Avatar
142
Drives: 2018 M2 Black Shadow Edition
Turner Motorsport recommended this one to me. I'm having it installed in March.
http://www.evolutionracewerks.com/node/313
