View Poll Results: Do you always use the clutch when shifting with 6MT? | |||
I use the clutch every shift | 66 | 91.67% | |
Sometime I just slip it in... | 6 | 8.33% | |
Voters: 72. You may not vote on this poll |
12-21-2017, 10:47 PM | #1 |
Rep 2,134
Drives: 2011 E92 M3
To clutch or not to clutch?
As suggested, do you always use the clutch when shifting gears or do you just slip it in?
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
12-22-2017, 07:23 AM | #2 |
1Addict
3202
Rep 7,860
Just the tip.
12-22-2017, 03:54 PM | #10 |
Rep 2,134
Drives: 2011 E92 M3
I like to rev match and shift without it, especially on downshifts. German transmissions can be a bit clunky. Japanese transmissions are much easier to shift without the clutch I have found.
Try it some time.
12-22-2017, 05:13 PM | #11 |
Rep 3,235
Only need to use the clutch when starting from a dead stop or coming to a stop. Clutch-less for both up shifts and down shifts.
12-22-2017, 05:42 PM | #12 |
Rep 110
Think about it, my old truck needs a double clutch. That does not speed things up i can assure you.
BMW E88 125 - 2008
BMW F10 M5 - 2016 BMW E70 X5 3.0d - 2007 BMW R1150r Rockster - 2003 Mercedes LP2223 - 1970 (http://www.lp2223.com) |
01-28-2018, 06:37 PM | #13 |
Rep 2,134
Drives: 2011 E92 M3
Cruising in my Subaru today, I used the clutch about 4 times - at red lights. At this rate, the car will need a new clutch in 2077.
01-28-2018, 08:52 PM | #14 |
Rep 2,008
Or synchros in 2019.......
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
4
01-28-2018, 09:01 PM | #15 |
Rep 2,134
Drives: 2011 E92 M3
You actually do not load the syncros at all if you are rev matching. The key is to slip it in like a gentleman, not just ram it home!!
01-30-2018, 02:02 PM | #16 |
Rep 2,134
Drives: 2011 E92 M3
Surprising results. I would have expected more people to go clutch-less from time to time.
02-05-2018, 02:16 PM | #18 |
Rep 2,134
Drives: 2011 E92 M3
I am officially in the minority here I guess.
Happy clutching!
02-05-2018, 03:16 PM | #19 |
i'm just saying
5723
Rep 2,634
if its not a sequential, clutch-less driving is a bit needless.. one way or another you have to match the rev of the engine and transmission everytime.. up-shifts can work but downshift ll take more time actually like that..
02-05-2018, 09:48 PM | #20 | |
Rep 2,134
Drives: 2011 E92 M3
For getting around town, I am not that worried about the little lag that is caused by waiting for a 12:1 compression engine to slow down on an upshift (2-3). Downshift (3-2) requires a blip to match revs. If you are good at it (more of a challenge with drive by wire as the computer can get in the way), it is seamless and rewarding. This is one of the reasons I like standards. It takes more skill to drive them well. It is also a great skill to have if you enduro race. Track we run has ~11 shifts per lap and 75 laps in a 2 hour stint for 825 shifts per stint. Over the 24 hours, the transmission will be shifted ~9900 times. If we do not rev match and use some finesse, even though we have synchros, you will upset the car as well as wear out the transmission and clutch. Row row row your boat!!
02-05-2018, 10:07 PM | #21 |
11815
Rep 23,187
02-06-2018, 11:19 AM | #22 |
2202
Rep 2,476
Drives: Satan's Chariot 2.0
If I didn't want to shift, I'd buy an auto. Which is why I went auto in the DD Jetta...
