08-15-2023, 05:38 PM | #1 |
Rep 427
Fuel Starvation/Limp Mode
I just wrapped up my first weekend following installation of the Dinan fuel pickup mod and was disappointed to find it probably only gained me a few additional minutes of time before I'm at risk of an unintended parade lap.
I've resorted to ordering a 5 gallon fuel jug to take next time, but would love to hear about any alternate solutions. Has anyone tried hydramat in the tank or a surge tank in the trunk? Maybe something else? I'd prefer not to take up space in the car or deal with the stink of the fuel jug on the drive home if there's different solution. I'd love to get closer to 50 minutes per tank, rather than the current 35 or so before I'm at risk. |
08-15-2023, 05:45 PM | #2 |
Rep 422
Drives: F87 M2 DCT, F15 X5
Where are you at on the fuel gauge when you hit starvation? I’ve driven to the 1/6th mark with no problems. Granted, I’m stock power with 300tw tires.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
bentom2335.50 |
08-15-2023, 06:52 PM | #3 | |
Rep 427
It’s nearly 100% repeatable in a particular complex on my primary local track when the fuel level is low enough. Long right hand sweeper up a hill, hill crest that unweights the car, and then a fast left hander under full throttle, followed by a tight left under heavy trail braking. When I try to get back on throttle exiting the slow left, the car stumbles and usually goes into limp mode. Sticky 200TW tires definitely contributed to the problem, especially in 265 or 275 width. |
08-15-2023, 07:48 PM | #4 |
Rep 573
I think our experiences are similar with the Dinan kit. Here is a video of me running for 45mins and at the end I didn't get limp mode, but the car was telling me I had less than 10 miles of driving left and I was at maybe an 1/8 tank - which I am still very thankful for the extra run time. You can skip to the end of the video to see the fuel level better.
Warning about the Dinan kit: The hoses they sent me weren't good for gas. I never ran ethanol, but the hose(s) ruptured leading to an end to my day and almost needing a tow home. If don't replace the hoses and have the same situation as I had, you'll get fuel cut REAL early due to the rupture and will need a nearly full tank to get to your destination. Dinan didn't care about my experience because "racecar parts." |
bentom2335.50 |
08-15-2023, 09:03 PM | #6 |
Rep 427
08-15-2023, 09:09 PM | #7 | |
Rep 427
I’d love to get to 1/8th tank. That would be a satisfactory outcome. Unfortunately I’m a ways off from that mark. I have video from my last incident of the weekend on my Catalyst. I’ll pull it later this evening and add to the thread so folks can see the lead in to being stuck on the apex of a corner until I could get the air purged from the fuel system. |
08-16-2023, 04:37 AM | #9 |
Rep 573
08-16-2023, 12:58 PM | #12 |
Rep 427
08-16-2023, 01:03 PM | #13 | |
Rep 427
This track is around 10mins from the nearest gas station and we were running three run groups on 25 minute sessions, so not much time to relax if you run out each break. A fuel jug should get me through two sessions easily, but transporting it inside the car for the drive home is not something I'm too enthused about. |
08-16-2023, 02:33 PM | #15 | |
Rep 427
I'd imagine any high e-mix would be frustrating to stay on top of. You'd probably need your own fuel truck. |
08-17-2023, 09:02 AM | #17 | |
Rep 3,696
I fill my tank with e50 in the morning, and bring two 5gal e85 jugs with me to mix with pump 93 at the track. If I start to run out of e85, BM3 Multimap with the Flexfuel sensor automatically dials back timing for me and I run 93 the rest of the day. Next morning, fill the tank with e50 and the two jugs with e85, and go again. |
M2guru383.50 |
08-18-2023, 06:07 PM | #20 |
Rep 573
08-19-2023, 01:38 AM | #21 | |
Rep 427
I looked up the M2 CSR tank cost and … I don’t see that as a viable option. Might as well get a nice trailer and start towing the car everywhere with fuel jugs. |
08-19-2023, 01:51 AM | #22 |
Rep 427
I think there’s more to it than lateral g forces. I get limp mode on the same track in the same place every time I’m there if I let the tank get below half. There must be some track geometry at play as well and not just g forces alone.
