M2 Technical Topics > Suspension | Brakes | Chassis > Alekshop l 700 miles M2 Track Setup
      01-18-2017, 04:18 PM   #1
Alekshop
Alekshop's Avatar
Drives: E30 M3 l E46 M3 l GT4 l 991 RS
This M2 came in shortly after it was purchased. After it was completed it was a blast to slide it a few times around the block once it was setup.
We didn't spend much time focusing on painted reflectors but decided to add Fall Line monoball bushing anywhere they fit
The new AP Racing kit is great and car stops on a dot now.
KW CS 3-way to complete the setup and we went with 18x10 on all 4 corners with RE71R. We are not big fans running 275 on a 9.5 due to side wall flex so going with 10" wheel was a must.
Car weighted 3609 with 160lbs driver weight and 1/2 tank of gas. Not too bad.
Enjoy!
Aleks.
      01-19-2017, 03:45 PM   #2
kiysersosae
kiysersosae's Avatar
436
Drives: 1M, M2CS, M3CS
Car weighted 3609lbs with 160lbs driver weight and 1/2 tank of gas. Not too bad.
That is one heavy M2, it's way heavier than M3/4. Was it manual or DCT?
Excellent job by the way, the car looks brilliant with those upgrades. I had the same shocks on my 1M and they are amazing.
      01-20-2017, 02:06 PM   #3
Alekshop
Alekshop's Avatar
M4/M3 in 3800lbs range. We have done many of them and none were in 3600lbs range.
M2 is a DCT.
      01-22-2017, 11:51 AM   #4
MerlinPurple
MerlinPurple's Avatar
Drives: M2 LBB
Are you running Apex EC7's?
I see you have 18 x 10" all round, but what concavity profile do you have (1,2,3).
I had ARC-8s on an E46 and loved them, those wheels look great on your M2!
      01-22-2017, 01:13 PM   #5
CommitConfirm
475
Drives: The Bus
1636KG
      01-23-2017, 11:36 AM   #6
Alekshop
Alekshop's Avatar
They are EC7 18x10. I am not sure about concavity profile as it wasn't important during setup.
      01-24-2017, 02:35 PM   #7
clubsport
Drives: LBB
You guys do great work.
One of the 3 Agate grey GT4's that I've seen at Laguna has a small white Alekshop decal on the rear bumper. Passed me in turn one like I was valet parking. I was stock but it showed how well you guys set up cars.
My question about the KW's is...Just from the pics, They look like a total PITA to get to the adjustments, wheels on.
      01-24-2017, 04:06 PM   #8
Paul2x
Paul2x's Avatar
Drives: M3CS, GT3, Macan, Tesla
Very very nice. Looks like my clone 🤘🏻
Who's rear toe arm?
Would be face 2.
      01-25-2017, 10:55 AM   #9
Alekshop
Alekshop's Avatar
There isn't an easy way to get your car quick but it's pretty quick to get it adjusted. All 4 corners can be adjusted in about 15min or so ...
      01-25-2017, 10:57 AM   #10
Alekshop
Alekshop's Avatar
Who's rear toe arm?
Would be face 2.
They are from Fall Line
      01-25-2017, 10:59 AM   #11
Alekshop
Alekshop's Avatar
Car ran at Laguna past weekend with absolutely no rubbing. This setup seems to work very well.
      01-26-2017, 08:48 AM   #12
paradoxical3
Drives: BMW
Hi, I am about to purchase that AP racing kit and have a question for you - why did you go with the CP9660 caliper instead of the CP9668? I really want the larger caliper but I also want to run EC7 wheels and am not sure if they will fit.
Thanks!
      01-26-2017, 12:26 PM   #13
MINI135i
Drives: 2019 M2C and 2013 FR-S
What are your camber settings? And what offset are the EC-7's?
Thanks
      01-26-2017, 12:57 PM   #14
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
What offset are you using on those 18x10 EC7? Is it close to rubbing the fender or shock/spring?
I have a set of 18X10 EC7's with 275 Hoosiers from my E90 M3 and they don't look like they would fit my M2. How much negative camber are you running in the front?
      01-26-2017, 01:35 PM   #15
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
Looking bad@ss Aleks, and thanks for the BBK purchase! Do you mind if I share your pics on our blog and Facebook? Thanks!
      01-26-2017, 10:16 PM   #16
MayorAdamWest
MayorAdamWest's Avatar
Drives: 2017 F87 M2
Thanks!
This is my car and I chose the 9660 because the added weight and concern over 18" wheel figment didn't seem worth the difference. I'm also guessing it has better pad selection. If you're not running a 24 hour race , why would you need the giant pad?
      01-26-2017, 10:17 PM   #17
MayorAdamWest
Drives: 2017 F87 M2
Would love to put the rear kit on and make the pictures look even better 😀
      01-26-2017, 10:18 PM   #18
MayorAdamWest
Drives: 2017 F87 M2
ET33
      01-27-2017, 01:44 PM   #19
jritt@essex
Patience Grasshopper! We're waiting on the caliper delivery from AP. The new rear caliper is incredible, and I'm sure it will be worth the wait for you. We did the test fit on an M2 the other week, and it looked fantastic. Thanks again for your business and your patience!
      01-27-2017, 01:58 PM   #20
jritt@essex
The CP9660 vs. CP9668 question is one we frequently get from customers. The two calipers are interchangeable in most of the kits we offer we these calipers. If you are endurance racing, the CP9668 with the 25mm thick pad is a no-brainer. If you're really lazy and don't ever want to change your pads as often, then the CP9668 is a viable option.
For 20-30 minute HPDE sessions or 40 minute sprint races, the CP9660 kit is more than ample, will give better wheel spoke clearance, weighs less, and costs $400 less.
Both are the business though, and you can't go wrong with either.
Here are some family pics that give perspective on the relative size of each caliper: CP9668 (largest), CP9660 (smaller front), and CP9449 (rear)
Here are our two front caliper options next to the OEM front caliper:
Here are the pads from left to right:
CP9660, OEM front, CP9668
Here's what I like to refer to as the CP9668 pad burger pic. Inch thick pads kind of mess with peoples' heads when they see them for the first time.
omasou2088.00
      01-28-2017, 05:31 PM   #21
f87chas
Would love to know your alignment settings?
      01-28-2017, 10:01 PM   #22
MayorAdamWest
Drives: 2017 F87 M2
Camber is -3.4F and -2.4R. Drives like it's on rails.
2017 F87 M2
2016 Range Rover
2014 328d Sports Wagon
Past: 991 GT3, 991S, F10 550i, 987 Cayman
