05-24-2018, 08:14 PM | #45 |
Rep 3,712
I got it used from an M4 guy in Toronto. It’s actually the AP Factory kit with the larger 378x36mm disc.
I wouldn’t be too worried about going with the Pro 5000R kit from Essex. You can add the anti rattle clips. Theirs do not have dust boots, but they rebuild the calipers for cheap if needed. Sorry for thread jacking, everyone. Just wanted to give my experience. |
07-04-2018, 09:12 PM | #46 |
Rep 295
Picked up production prototypes today. Installed without TOO many hitches.
I stripped one of the retaining screws in front and spent about 1.5 hours drilling it out. Otherwise they fit perfect and are great quality. |
07-05-2018, 07:18 PM | #47 |
Rep 3,712
Nice. When are you hitting the track next and what track pads are you running?
07-05-2018, 07:56 PM | #48 | |
Rep 295
Threw on the XP20 to bed the rotors and save some time. Typically use those on track and 1521 for street. |
07-22-2018, 08:15 PM | #50 |
Rep 3,402
It is interesting, not sure what the magic number is but a buddy and I run very similar lap times we run together in the same group both have M2, same Cup 2 tires and same Pagid brake pads, the last weekend we ran his turned dark green almost black and mine are still blue. I am sure its a matter of time for mine but 8 pretty hard track days and they are still blue for me. I am sure he is generating more brake temp then me but I am not sure how much more.
07-26-2018, 11:59 AM | #51 | |
Rep 295
Never had issues with discoloration on previous cars, either. Religious about cool down laps and it's never insanely hot here in the PNW to begin with. |
07-30-2018, 01:12 AM | #52 |
Rep 165
08-28-2018, 04:33 PM | #53 |
Rep 17
Hey everyone,
I've found out after 1 trackday that my front discs had a 0,1cm warp. So now I'm replacing them but I want to keep the original caliper. Would someone know what's the biggest rotor I can put in? Brembo sells only 380x34 and APRacing 380x34/380x32/380x28. Would a 32mm thickness fit the original calipers? |
08-28-2018, 06:14 PM | #54 |
Rep 81
08-28-2018, 07:05 PM | #55 | |
Rep 295
08-28-2018, 07:06 PM | #56 | |
Rep 295
08-28-2018, 08:16 PM | #57 | |
Rep 132
2011 BMW X1 28 (sold)
2013 BMW 328 Sportline (sold) 2018 BMW M2 LCI (current) |
08-29-2018, 02:28 AM | #58 |
Rep 17
Warped.
First trackday I did.. I believe it was a combination of not the best braking technique, which led to really hot brakes and discs and fadigue, and also periods of light rain hitting the extremely hot discs. I am sure that it was after that day that the car started to vibrate like hell when brakes become warm/hot. And, I measured one of the front discs which had 0,1cm warp. Now, I'm interested in changing to something that will give me better performance. I'm yet to understand what are the sizes that one can fit. |
08-29-2018, 07:17 AM | #59 | |
Rep 132
08-29-2018, 09:27 AM | #60 | |
Rep 1,124
08-29-2018, 04:15 PM | #61 | |
Rep 3,402
08-29-2018, 04:17 PM | #62 |
Rep 3,402
I have 12 days on track with my M2 and a buddy as double that, they hold up just fine to track work if you do the proper prep. My bet is this guy used OEM pads which is not compatible with track braking temps.
08-29-2018, 06:45 PM | #63 | |
Rep 132
08-30-2018, 06:32 AM | #64 | ||
Rep 17
Well, I believe it's a true warp since the mechanic used a machine to measure the "bend". If it would be a coating there would be noticeable material on the top of the discs I believe? Also I did a few more hundred Km since then and there's no big improvement. Anyway, what is that cure? |
08-30-2018, 11:23 AM | #66 | |
Rep 3,402
Best of luck |
rich8566608.50 |
