M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 N55 drivelogic fully working
      12-22-2021, 10:26 AM   #1
beppeM3+123d
beppeM3+123d's Avatar
205
Drives: bmw m3 dct + 123d e81
Hi guys after tons of hours developing one of mine best retrofit here the first worldwide M2 pre lci dkg fully working Oem cs drivelogic software, mdm and gear speed adjustable manual and Drive. Zero issue. Zero error!
As requested i try pre lci kombi and didn't work.
      12-23-2021, 05:38 PM   #2
F87source
F87source's Avatar
Drives: Bmw M2
Awesome!
Could you let us know what coding you did to make this happen?
ZM2
This is an option if you want to be able to control the dct even more than what thor allows.
      12-24-2021, 01:28 AM   #3
beppeM3+123d
205
Awesome!
ZM2
Thor is shit. They stole money.
This is oem retrofit. Need wiring also not only coding.
      12-24-2021, 01:31 AM   #4
F87source
F87source's Avatar
Drives: Bmw M2
Would you care to elaborate?
Thanks
      12-24-2021, 01:39 AM   #5
beppeM3+123d
205
Thanks
Here the zero issue picture
      12-24-2021, 02:04 AM   #6
F87source
F87source's Avatar
Drives: Bmw M2
Could you let us know how it was done coding wise - hardware wise that should be easy?
My guess is there is a possibility of FA coding in most if not all of the competition pack features because VO must be different between the og and competition, otherwise a comparison between the egs ncd files will tell what must be done. If there are more modules that must be put in then coding will be done accordingly.
      12-25-2021, 02:05 PM   #7
MWelt
MWelt's Avatar
70
Drives: 2016 Mineral Grey DCT
You reference pre-LCI, Photos obviously show to be M2 C cluster and shifter.
Are you indicating that you need to change these items along with this process to achieve this ?
      12-25-2021, 02:54 PM   #8
beppeM3+123d
205
To reply to all the right questions done:
Yes mine is pre lci, i retrofit m2c cluster not related to this retrofit but because i didn't like the pre lci colors setup. During days is very hard to focus speed and at night all orange is very non M car…
I am 99% sure that m2 lci kombi just need to perform update at least 11/18 istep.
About pre lci kombi is in my mind, even for me is useless, try to make it work. As soon as i had time i will try it.
About the whole job is flashing plus coding, as egs4 can only be flashed. And rewiring the center console. My setup as unfortunately is a hardware change the gws, is with also gws conpetition. I found it at good price around 250eur. Same as before is possible that just to know i will try also oem n55 gws.
In that case flash it is not recommended if meeded because of hardware change. I generally avoid this kind of flashing to prevent ecu damaged.
      12-25-2021, 03:12 PM   #9
MWelt
MWelt's Avatar
70
Thank you for more insight ! This is a beautiful cluster …how does this work as far as Tach ect being N55 vs S55 ?
Some of us on this Fourm have spent oodles of cash on our beautiful F 87’s as I know I have invested to much but what is it to continue to enjoy this platform lol!
Why not if we enjoy all of these Mods !
Would you like to elaborate on this Mod further please as I would like to preform this as well .
Cheers ! Peace & goodwill to all !!
:cool!
      12-25-2021, 03:33 PM   #10
beppeM3+123d
205
:cool!
The cluster except for 8k limit on rpm is totally identical but better and modern.
      01-12-2022, 07:33 AM   #11
beppeM3+123d
205
Some of us on this Fourm have spent oodles of cash on our beautiful F 87's as I know I have invested to much but what is it to continue to enjoy this platform lol!
:cool!
The Pre Lci kombi doesn't show the gear speed. Lci is supposed to be ok
      01-16-2022, 05:14 PM   #12
shaneguags
shaneguags's Avatar
Drives: 2017 Big Turbo BMW M2
2017 BMW M2  [9.42]
:cool!
can you make the oil temp show the numbers ?
      01-17-2022, 05:28 AM   #13
beppeM3+123d
205
:cool!
In the old one no! In the new one you can choose!
      01-17-2022, 09:52 AM   #14
AdventureNoodle
Drives: F87 BMW M2 LCI
Following
      02-20-2022, 09:55 AM   #15
Strandh
Drives: M135i, Quaife Diff
Impressive! Well done
      02-20-2022, 03:32 PM   #16
beppeM3+123d
205
Guys after several months of testing I must say that competition software is more balanced in confort and sport use.
I Run CS oem sw but is very very aggressive at speed 1 is like speed 3 in competition to make idea.
Cs level 3 is so aggressive, i think is sensed if the car run stage 3 500 hp so I decided to come back to competition sw and is definitely my favorite setup.
Last never never any issue in both software. So is defintely a very nice upgrade the car is another car now you can choose the perfect speed for the driving situation
      04-24-2023, 12:31 PM   #17
tinger_kwak
tinger_kwak's Avatar
Drives: 2018 F87 M2, 2023 G82 M4
Hi. I also want to make Drivelogic fully work in M2 LCI.
I've read several times of your whole post and what I understood is like below.
-Update the Istep version to the latest firmware
-Change the cover trim of gear selector to the F8x part which has drivelogic switch in it
-Need 3 wiring to the shift pattern switches
-Some codings and flash to EGS4 module
But I couldn't get instrucions about wiring, coding, and flashing.
Q1) Can you offer more details about wiring?
Q2) Do I have to flash EGS4 firmware of M2 Competition?
Q3) What kind of codings needed?
It would be really helpful if I can get further informations about these.
      04-27-2023, 07:42 PM   #18
AdventureNoodle
Following
      02-20-2024, 03:54 PM   #19
MySeLf.M2
Drives: M2 LCI 2017
Sorry for taking this thread out from the grave but I would really like to do the same to my car.
@beppeM3+123d any chance you could give us a step by step tutorial? Or maybe a video?
Detailed wiring / coding / flashing instructions would be really appreciated.
Fingers crossed.
VGSON208.50
      04-16-2024, 09:17 PM   #20
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
beppeM3+123d Any update on how you did this?
      04-16-2024, 09:39 PM   #21
F87source
F87source's Avatar
Drives: Bmw M2
I'd talk to Enabled about this, he's excellent at retrofit coding.
samsamdar584.50
