M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Lag between shifts...
      04-22-2020, 03:55 PM   #67
PackPride85
I would be hesitant to tune this out (if its even possible) without knowing why BMW engineers did it in the first place. They no doubt felt this issue during their own tuning/driving and chose to leave it in....
      04-22-2020, 04:02 PM   #68
Nezil
Nezil's Avatar
1404
Drives: LCI '18 6MT M2
They also left in the clutch delay valve, which only makes shifting rough with 6MT.
I'm of the opinion that BMW engineers left it in from DME tuning other less highly tuned cars in an attempt to reduce the amount of stress on the drivetrain if the shift is done badly.
I also find it funny that many people believe that manufacturers of products have done a huge amount of testing. Yes, they do a lot of QA testing, but it's focussed mostly on longevity, emissions and safety. I work in a completely different industry, and I know that so many things get found by the aftermarket enthusiasts that we just weren't aware of or didn't have time to focus on.
I also believe that because DCT is seen as the more advanced transmission, and sells more globally than the 6MT, especially in Europe, the 6MT is something of an afterthought when it comes to tuning, both from BMW and from aftermarket tuners. The DCT is unquestionably, undoubtably faster, so if you're a tuner going to build a fast car, why would you focus on daily drive ability of 6MT...
Having said that, any time you tune your car, you inevitably risk parts wearing faster and / or breaking. That's a risk I'm happy to take in this case, even if it means that my turbo dies early; I wanted to upgrade it anyway!
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods:
BruceM984.50
      04-22-2020, 11:53 PM   #69
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
[QUOTE=Nezil;26083209]They also left in the clutch delay valve, which only makes shifting rough with 6MT.
Agreed. BMW engineers good cars, generally, and the M2 is no exception. But they are not perfect, and mods will improve them. Nezil is looking for a needle in a haystack, but he's relentless about improvement, and I admire his tenacity. And, since I have a 6MT that I've tweaked considerably as well, including particularly the shifting experience, I'm hoping to profit from it eventually..
      04-23-2020, 12:05 AM   #70
Nezil
Nezil's Avatar
1404
Some say I'm a pain in the ass, my wife says I'm tiring... I don't mind, I can't change how I am and I get a huge sense of achievement if I'm successful!
Appreciate 5
BruceM984.50
chris7197334.00
AndrewC198910931.00
seanyx11234.00
      04-30-2020, 10:30 AM   #71
BruceM
Hey Nezil, have you seen this from Dinan? It's their new (non-M2) N55 flash. The only reason I thought it might be of interest, maybe, is that near the bottom of their features bulletpoints for this flash is "no hesitation between shifts." It might be worth a follow-up with them to see whether they have addressed your issue in their recent tune...
https://www.dinancars.com/products/s...V1utY2xZDIA7K4
      05-01-2020, 06:18 PM   #72
Nezil
Nezil's Avatar
1404
Thanks for the suggestion... I think I'm on to something at the moment though. See next post.
      05-01-2020, 06:22 PM   #73
Nezil
Nezil's Avatar
1404
It's too early to give a conclusive report, but I can say that I'm already seeing a massive improvement in the maps I'm trying with the tuner I'm working with.
Not only is the waste-gate behaving correctly after the shift, but boost is even being held for a short time between shifts. It's not 100% consistent yet and more work needs to be done, but the feeling of a shift when it all comes together is incredible. It truly feels naturally aspirated, and I'm confident that it would be much much faster than a typical 6MT car that needs over a second to build boost between shifts.
Appreciate 9
chris7197334.00
BruceM984.50
asbrr544.50
widetyres279.00
Altra265.50
SeanWRT3179.00
AndrewC198910931.00
gphung193.50
      05-02-2020, 03:35 AM   #74
widetyres
279
Drives: M3 E92 DCT, 2012
Great news Nezil! I bet it feels fantastic.
Is your tuner on the bm3 platform? Be great if so as it'll be easier to share the tune (or variations of it) once sorted.
      05-06-2020, 08:33 AM   #75
Nick2016M2
Nick2016M2's Avatar
Drives: 2016 M2
2016 BMW M2  [0.00]
I've just read through this full thread and tried to follow along with the log graphs posted. I 100% agree that there is an artificial lag induced by the ECU when you don't shift at redline. I too have been playing around with driving styles since I got this car 4 years ago and it is my single biggest disappointment with this car.
Shifting quickly at a 5500 RPM shift gives the clunky-ness associated with the rev-hang. A slightly longer shift can be smoother, but in either case there is a huge lag when getting back on the throttle. More than just turbo-lag, which can be measured by simply going to 0% throttle and then back to 100% in the same gear.
Thinking it was safety (traction) related, I've tried DSC OFF and it performs the same way. I, too, am convinced the lag is to protect the drivetrain.
The only way I've experienced no lag is a quick shift at redline with DSC off. It's to the point that I don't enjoy daily driving the car and have considered an E36 or E46 for more daily enjoyment (both of which I've owned before).
I applaud all of the work Nezil has done here and it is the first thread that really tries to use data to get to the root of the problem. If a fix is discovered I am on board.
One question though - If SeanWRT suggests that the lag may be introduced on the 6MT to prevent overboost because of turbine speed and a drop engine RPM, how does the ECU on a DCT live with that with instantaneous changes in engine RPM? Seems that would only make it worse..?
      05-06-2020, 04:07 PM   #76
PackPride85
DCT shifts are so quick it doesn't need to bleed off boost like with manual. No drop = no overboost.
      05-07-2020, 06:06 AM   #77
Nick2016M2
Nick2016M2's Avatar
Drives: 2016 M2
2016 BMW M2  [0.00]
The principal here is that engine RPM = Flow and turbine speed = flow. With a sudden change in engine RPM, you have a sudden decrease in engine airflow. With the turbo spinning at the same turbine speed this would create an overboost. Unless it is quickly regulated at the point by the wastegate. My point is: If the wastegate can react that quickly on the DCT, why does the drivetrain need to be babied so much in the 6MT?
      05-07-2020, 06:22 AM   #78
PackPride85
Have to look at it with PID tuning in mind:
https://www.google.com/url?sa=i&url=...AAAAAdAAAAABAY
The chance of overshoot error where turbine speed drop is minimal during DCT shift is small since you are not far from steady state (desired full boost). Large loss of turbine speed during *most* manual shifts requires significantly faster response time and thus higher chance for error over target during rise. It's much easier to control steady state error when closer to steady state.
chris7197334.00
      05-07-2020, 09:10 AM   #79
asbrr
545
Drives: 2014 335ix M-Sport
I would add that this is what a bypass valve / blow off valve is designed to help with, so the compressor doesn't stall and you don't run into overboost. The wastegate absolutely works in concert here..
      05-07-2020, 02:09 PM   #80
chris719
Drives: '08 M Roadster
Definitely true from a control systems perspective. The question I would have is why does this not happen on every turbocharged 6MT car then?
      05-07-2020, 02:18 PM   #81
Nezil
Nezil's Avatar
1404
A lot of talk on this topic which is great... I'm happy it's getting attention because I too agree with these statements:
It actually shocks me that no other 6MT N55 or S55 owners have picked up on this issue.
Anyway... I'm pretty sure that a tuner doesn't want their 'secret sauce' spread about, and I have no intention of doing that with the tuner I'm working with, even if they were to tell me... which they're not.
What I will say though, is that the N55 in the M2 (and probably other vehicles) has two ways to control boost pressure... one somewhat crude way, because of latency etc. is with the waste gate and the diverter valve. The other, which is the way BMW does it typically, is with the throttle plate. If you take a look at logs of the manifold MAP sensor vs the pre-throttle MAP sensor there are times with the stock map that the throttle plate closes to control the pressure in the manifold, causing the pre-throttle pressure to increase. With a stock charge pipe you may not want this to happen because any spike in pressure here could cause it to fail, but with the aftermarket charge pipes most of us are using, a boost spike can be tolerated by the engine (by using the throttle plate) and by the charge pipe (because it's uprated).
      05-07-2020, 06:00 PM   #82
PackPride85
I think it's a little more complicated than that. There's more map data tables in the boost group for BMW than I've seen in any other car. There's a reason no one has really figured this out yet....no one 100% knows how this logic all ties together.
      05-07-2020, 06:06 PM   #83
Nezil
Nezil's Avatar
1404
Oh I know it's more complicated that I said, I was just making the point that it's entirely possible that a solution can be found... but might take a lot of trial and error.
I was also making the point that it's definitely worth doing. I can say for certain that when it does work, the feeling of throttle response and performance is massively improved.
      05-07-2020, 06:45 PM   #84
PackPride85
Even though it's likely we won't be able to extract the solution from your custom tune, I'm hoping it will spur on PTF or MHD to give it another shot if they see it works.
      05-07-2020, 06:47 PM   #85
Nezil
Nezil's Avatar
1404
I was thoroughly disappointed that they weren't able to or interested in working on this with me, but it is what it is.
My personal feeling is that working on this is more important than working on power for a 6MT car. For DCT I totally understand that this wouldn't have even been considered, but for 6MT, having more power only makes the delayed feeling more apparent and annoying.
chris7197334.00
      05-08-2020, 03:30 AM   #86
chris719
Do you think there is a turbocharged 6MT BMW without this lag? I'd be curious to see what logs look like on an older N55 like a 135i if the effect isn't there.
      05-08-2020, 01:47 PM   #87
Dasnub
I will add this rather significant piece of information to the discussion:
Prior to my 2017 6MT M2, I had a 2015 6MT M235i. I bought it at 5k miles and had no idea it was tuned until about a year of ownership, when the dealer pointed the JB4 to me. That car had at minimum a new charge pipe and downpipe as well. It may have had an intercooler. I ran the JB4 bypassed, Map2, and Map5. That car NEVER lagged between shifts the way my M2 does. Power hit hard every time regardless of RPM or shift speed. It was noticeable immediately when I bought the M2 on the 200+ mile drive home from where I purchased it. It has driven me crazy ever since. I’m glad people are working so hard to find a solution... because the M235i was much more violently fast.
Now, this could be the JB4 software making a change that overrides a BMW setting. It could also be that the unrestricted flow of the catless downpipe made some sort of impact. But there is no doubt a difference, somewhere in the chain.
chris7197334.00
      05-08-2020, 04:54 PM   #88
asbrr
545
My guess would be that in a stock state of tune, the 235i is making a significantly less amount of power and torque than a stock M2. And if the theory is the lag is there to prevent shock to the driveline in high load situations, then perhaps this was written into the M2 software specifically....
