09-06-2021, 07:40 PM | #97 |
3883
Rep 54,457
Drives: F80 M3
Looking for SPL suspension parts and live in Santa Barbara, Ventura or San Luis Obispo Counties? HP Autosport, Inc. is your local source.
We install everything we sell. www.hpashop.com |
01-02-2022, 08:30 PM | #107 |
3883
Rep 54,457
Drives: F80 M3
SPL PRO Rear Endlinks F8X BMW
SPL PRO rear endlinks for the BMW F8X chassis feature massive Teflon lined FK 1/2" bearings to provide the highest load capacity for use with stiffer aftermarket sway bars. Custom heat treated chromoly high misalignment studs connect to the sway bar and offer extreme articulation capability (65deg) to prevent the endlink from binding when used with different adjustment holes on aftermarket sway bars. SPL end links are length adjustable to eliminate preload on the sway bars, which can result from uneven settling of springs or uneven suspension heights from corner weighting. Black anodized 6061 aluminum turnbuckles work in conjunction with the left and right hand threaded rod ends for simple and precise adjustment. These end links are perfect for street or race applications. Sold as a pair. Made in the USA. |
