03-13-2018, 11:39 PM | #1 |
Rep 719
Valve fob setup
I remember reading about a way to have a fob programmed to the mirror in order to open and close valves,
can someone share the info ? Thanks |
03-14-2018, 04:48 AM | #2 |
Mini Beast
188
Rep 361
BimmerCode app
M2 = big smile every time
03-14-2018, 10:20 AM | #4 | |
Rep 4,541
Drives: 2015 328d xDrive
https://www.ecstuning.com/b-cg-preci.../0001vsc1~cgp/ This will work with 2 valved exhausts as well. I have a remus exhaust and it was no problem. I had to custom order mine and wait a week because I wanted default open/ activated closed, but you can order any configuration you'd like. M0dBargains sells them as well. |
subliminalaudio313.50 |
03-15-2018, 09:41 AM | #6 | |
Rep 39
03-15-2018, 09:45 AM | #7 | |
Rep 4,541
What exhaust are you running? What configuration did you order? Open/Close? Auto/Close? Auto/Open? Do you hear/see the valve opening and closing when you press the buttons? Try doing it with the power on but the engine off to make sure you can hear it's working. |
